Robot Man is surprised.
Probably will start making these, but not from cedar. It was tough to adjust the fit because even two strokes of sandpaper takes too much off.
Cedar would be the selling point, smells great and keeps bugs away.Looking for things to make for the farmers market besides bird feeders, Soma puzzles, and pencil cups. So I made this cedar box just to see how much effort it was:
Gotta love old Hondas, if they got oil in em they’ll damn near run forever.
I hope it was a quality axle…Not my vehicle, the owner has 4 kids in college and is on a tight budget.
If it were my vehicle and I was preparing it for the after life, I would do "everything" while I was in there. Peace of mind and efficiency are more important to me than the cost of a few parts.
After digging in a bit yesterday, it does have a rubber layer on the upper wheel. Just grimy and a bit hard. Will work on that and see if I can clean it up.Can't tell from your photo, but it looks like the upper wheel is missing the urethane bandsaw tire...
That and there should be a tension adjustment mechanism at the axle on the upper wheel...
Does your phone need an update? I know I've had some wonky app based stuff before when I was behind on updates.Hooked up the tilt trailer as the avatar beetle is going in for a conversion to alternator. Decided to retrieve the Ford 2000 tractor from storage. Fought the effing Curt Echo bluetooth brake controller and after 90 fun filled minutes quit and went ahead without the controller working. Picked up the tractor, loaded, went past the gas station, filled it up and home. Offloaded and put in the shop. Then proceeded to load up the yellow bug. Did nothing else as my mood was pretty sour. In the 90 minutes I downloaded and erased the app 4 or more times, checked the connection 4/5 times, watched troubleshooting videos, etc. AND yes I'm still pissed.
PS I'm sure it is something I am doing, like always the user!
How did they contaminate a 2500psi cylinder of argon!?
Very low chance of contamination, standard practice is to pull a vacuum on the cylinders before filling. Are you sure it is labeled as welding grade argon?
I used a heated paper clip to make a hole once. ONCE! Now if I need to drill a hole in a nail I got a nice little pin vise and a sharp bit, nice and slow till it starts to ooze.lol
Now that I have it figured out, I can probably do it in ten minutes,
I use copper ferrules on my walking staves. Not noisy and excellent grip on most surfaces, including slickrock.Also, put a rubber cane tip on that; a raw wood or metal tip is asking for a slip, and is also noisy AF
So you're saying it's a I-DOT-10-T error?Hooked up the tilt trailer as the avatar beetle is going in for a conversion to alternator. Decided to retrieve the Ford 2000 tractor from storage. Fought the effing Curt Echo bluetooth brake controller and after 90 fun filled minutes quit and went ahead without the controller working. Picked up the tractor, loaded, went past the gas station, filled it up and home. Offloaded and put in the shop. Then proceeded to load up the yellow bug. Did nothing else as my mood was pretty sour. In the 90 minutes I downloaded and erased the app 4 or more times, checked the connection 4/5 times, watched troubleshooting videos, etc. AND yes I'm still pissed.
Brakes seem like the absolute worst use case for Blue Tooth.Hooked up the tilt trailer as the avatar beetle is going in for a conversion to alternator. Decided to retrieve the Ford 2000 tractor from storage. Fought the effing Curt Echo bluetooth brake controller and after 90 fun filled minutes quit and went ahead without the controller working. Picked up the tractor, loaded, went past the gas station, filled it up and home. Offloaded and put in the shop. Then proceeded to load up the yellow bug. Did nothing else as my mood was pretty sour. In the 90 minutes I downloaded and erased the app 4 or more times, checked the connection 4/5 times, watched troubleshooting videos, etc. AND yes I'm still pissed.
It’s really effective when the turd is in a nice, thin plastic bag: the whole thing slings like a frisbee until it unloadsMostly yard and parking lot today. I was weed whackin' the verge of the parking lot when I hit a concealed dog turd bomb--nice and fresh, too! Spattered me head-to-toe.
I'm going to get you--and your little dog too!
What is the deal with these people taking the trouble to pick up the turd in a baggie, but then leaving the damned bag right there?It’s really effective when the turd is in a nice, thin plastic bag: the whole thing slings like a frisbee until it unloads
We have the same a**holes here. Why would anyone do that? Instead of the rain and weather eventually washing it away.What is the deal with these people taking the trouble to pick up the turd in a baggie, but then leaving the damned bag right there?
It's a hazard I've learned to look out for--but this one was bare and hidden in a clump of cheatgrass.
One of my pet peeves: I live in a rural area. I really don’t care if someone’s dog takes a dump along the side of the road by my place, but it REALLY pisses me off when they put it in a bag and then either stealthily drop it on the side of the road or worse, throw it in my pasture. In my mind it’s all part of the BS poser environmentalist movement. In town no one wants a dog turd on the sidewalk. In the country many think they will be looked down upon if they don’t pick up the turd, so they do, but they don’t want to carry it home so they toss it, making a very minor issue a much bigger oneWhat is the deal with these people taking the trouble to pick up the turd in a baggie, but then leaving the damned bag right there?
Yeah, mixed gas (other than Argon/Helium) would not work on aluminum. Does the cylinder have a label on it?Some argon is premix Argon/CO2/Other so maybe not actually contaminated?
I thought you were supposed to put it in a paper bag, light it on fire on their front porch and ring the doorbell.Eventually I'm going to spot the A-hole(s) that does this around her, and I plan to follow them home, note the address, and then start picking them up on leaving the baggies on their doorstep, on the windshield of their car, in front of their garbage cans so maybe they step on it in the dark... Oh yes! on their roof!
When I worked on a factory construction job in the 70’s several guys decided to have a fart contest. One ended up blasting in his pants and had to ride his motorcycle home 5 miles to change clothes. He got named Spatterpoot after that incident.Mostly yard and parking lot today. I was weed whackin' the verge of the parking lot when I hit a concealed dog turd bomb--nice and fresh, too! Spattered me head-to-toe.
What did you end up shooting? .22 flansch boden is scarce in these parts.**.22FB was the caliber marking, which I am taking as .22 flansch boden, or flanged base.
From now on, I'm calling .22 LR zwei zwei flansch boden. Mostly because I don't remember twenty from my high-school German.Heh. .22lr is the Americanisch name for it.
zwei und zwanzig (spelling?)From now on, I'm calling .22 LR zwei zwei flansch boden. Mostly because I don't remember twenty from my high-school German.
