sonnycrockett84
- Joined
- Dec 15, 2012
- Messages
- 10
Not really wear. I'd call it patina. It does look like it was "sharpened" after it was etched, but that may have just been the process of creating the flat.At first glance, it's too perfect to be real.
I'm thinking "presentation piece", maybe?
Like an "Annual Award for Best Screw Turner" or something?
Maybe a salesman sample?
You see any sort of wear on the business end of the thing?
The Cobbler said:looks wood lathe toolish to me
Looks like a lot of my bigger turn screws, not the little ones so much that may have been factory made. Pix later.^ agreed. the handle doesn't look at all like "production screwdriver handle". (at least not to me.)
piano tuning wrench is just a tiny socket on a handle, generally. some are double-headed (two sockets). some use interchangeable sockets.piano tuning equipment
It's not.looks wood lathe toolish to me
I agree, it doesn't have the quality of typical hand engraving.Firearms are generally engraved with a graver- basically tiny chisels. That piece was chemically etched, probably with ferric chloride, after being coated with a masking agent, which was then scraped away by hand, to create the pattern.
That lends credence to it being a one-off and DIY/shopmade, as anything produced in quantity would likely have been punched/stamped, not etched, and anything done professionally- as a presentation- would have been a lot more consistent and, well, professional, in the symmetry and evenness of the etching.
We could even argue that it either is, or a very close cousin to, wrought iron, as the close ups of the etching strongly suggest a 'grain' to the metal, which is characteristic of WI.
Doc.
