Vintage Dymo embossing label makers - because the new ones are useless.
oled
Denmark
I wanted an embossing label maker to label some spice jars. The modern electronic labelmaker, which I use all the time in the workshop, just doesn't have the vibe of the old type. The only embossing model available was the Dymo Omega. I ordered one of those, and it came with a roll of tape. Everything was good, or so it seemed - because this is where the story gets a little bit interesting.
My short product review of the Omega would be: it is utterly useless. The letter spacing and letter height are both horribly inconsistent, apparently because the forward "tracking" motion of the tape doesn't work, it keeps slipping and losing control of the tape. When you have cut the tape, more than half of the times I tried, the tape didn't come out again, it simply was stuck inside the machine after cutting. There's also something weird about the trigger, it is hard to control the amount of force you apply to it. The included tape is stiff and doesn't emboss easily. The letters are not clearly visible. I'm not sure if this is the fault of the tape or the machine, or a combination of both.
I don't get it. A company, which has made well-designed embossing label makers since 1959 (or thereabout), completely looses it and redesigns the thing to not work at all. And they don't seem to offer any other, better, more expensive models either. Except for the 3000, which makes metal labels.
Anyway, what to do? I found this lot with three vintage label makers at an online auction. A 1700, a 1710 and a 1750. The first photo below is the actual auction photo, where you can see them with one roll of tape. But they came with several extra rolls, plus all three machines have vintage tape rolls in them. I tried the green 1700, and it works perfect. The tape doesn't get stuck, the tape is softer and more flexible, resulting in a label with consistent letter spacing, and clear, easily readable letters. I'm happy.
But I would like to know more about these models, How old are they? What's the difference between them? I can't seem to find any online resources for this. Can anyone here tell more about the history of these labelmakers?
They look like 1970s era to me. I suspect if you were to go to Google books, and search for
Dymo 1700
And it's brethren. You will probably find magazine ads for each, allowing you to pin it down.
mikedodge
I have 2 of those, they're both orange 1780. One was my mom's the other I bought a year or two ago off facebook and came with a pile of different colored rolls. Which is great because I needed that.
I also have a couple small ones from when I was a kid, one looks like a dog, the other is a little compact one.
I don't think they care that the new ones ****, it's probably only people buying them for nostalgia or artsy stuff. Everyone is using the newer style printed labels now.
Aaron_W
Vintage ones still work and they are pretty cheap on ebay. I found a really early one with a cast metal body and a leather carrying case for under $30.
Agree probably late 60s or 70s.
Bummer, many of the links in google books are snippet view, but having his name, I found several patents here, apparently might be more than one, or he changed fields. Not all are relevant to tape guns.
From there you can’t click on Dymo to see what all was assigned.
If you google
USPTO patent advanced search, follow the first link
And click on the right advanced search button
Type in (AS is the assignee field)
Dymo.as.
And hit search, it says 138 things were assigned to them. Slightly odd, only showing me 102, ending in 1971 on my iPad
Hit the top left button in the right window, and you can see the patent images.
I found this page from the book "Analogue - a field guide", suggesting the 1700 was introduced in 1961.
Not sure I am on board with that yet. In the other references in Google Books, the news blast, same article text in three publications, shows a 1969 date. Wonder if the author simply went on his early tape patent, which wasn’t issued til 1962.
The 1710 showed up a year or two later.
His 1961 patent looks nothing like the 1700. In Google Patents, it shows Dymo as the assignee, but not at the USPTO site.
Two Sheds
In my opinion, the 1570 is my favorite for general use. The original "Dymo-Mite" is much cooler looking, but the 1570 is easier to use. It uses both 3/8 and 1/2 inch tape. And somewhere I have some other font disks for it.
