niget2002
Nothing. "feels like" temp of 106f is hot even if the ac in the shop is on.
I was hoping to take the kayak out too, but dang.
Mine will retort back to have you used it in 6 months? A year?I tried to envision yet another reorganization,
trying to tell that voice in my head that says,
"You might use that someday..."
to stfu.
Ya but that’s actually true.one thing I can say is a gearhead never can have enough retractable ratchet straps or hitch pin clips!
Looks like if used correctly, the GF could make you smileGF joked about me hanging a swing from the mezzanine so she could hang out while I’m working. Whaddayaknow, two days later I got the green light to order some custom slings for an upcoming job from a local rigging supplier. Threw a sketch together and picked this up Friday. It’s ridiculous as was the cost but it made the GF smile.
Heat lamps are your friend...
Find a quart of ARCO Graphite oil and get them hot and put that on. You will get a dark gray stain that doe not peel or rust...
Ask me how I know...
ARCO Graphite oil was a 70's thing, and actually worked well. Just don't spill it.
I remember changing a few engines at the time that had graphite dropped out, blamed at the time on mixing of different oils.I used that stuff because it was cheap at the time.
I had a random leftover quart that sat around for a couple of years. Opened it for use in the lawnmower, and found the graphite had dropped out of solution and settled to the bottom.
I think it disappeared from store shelves at about the same time.
Typical corporate blame game.I remember changing a few engines at the time that had graphite dropped out, blamed at the time on mixing of different oils.
Did pretty much the same. Stacked up my solvent, used oil drums, buckets, and funnels. Don't know if they'll stay there, but after work that's pretty much all I had for motivation.Tried to do some cleaning. I didn't make it far.
Little time staring at them in the rolling chair and got a plan together.
Stretch Limo. Will be adding drivers seat back to splice locationSo it's to be a Pedal El Camino/Ranchero; or fitted for adult legs?
Joke rejection is real.It was meant to be a joke. I’m batting 0 lately.lol
It was just too hot and I didn't want to wait for the AC to cool things down. Plus I was tired/lazy from work.I can't seem to recall having ever made it very far. My FSD is tenacious.
Once I cured the LSDA* disease, the FSD went away on its own.I can't seem to recall having ever made it very far. My FSD is tenacious.
Not supposed to start with cleaning the beer fridgeTried to do some cleaning. I didn't make it far.
and FSD?Once I cured the LSDA* disease, the FSD went away on its own.
*Lay stuff down ANYWHERE.
If it were me, I'd leave the existing roof and I'd be really tempted to put a loft back in after complete. If not a full loft, at least a partial/half one. The one thing I can never seem to have enough of in my shop is storage. I have quite a bit of stuff where I only need it a few times a year. When I do need it, it's a life saver. But it all takes up shelf/floor space the rest of the year.Started some work on my old dilapidated shed. She needs a new roof and siding, but it needed a new doorway and header first. Front foundation was almost nonexistant after all these decades, so I framed and poured that first. Went a little wider on the doorway so my side by side or even my jeep would fit in a pinch. I added the lean to a couple years ago on an existing concrete pad, now just really have to fix the existing shed. Trying to decide whether to just re roof what I have, or tear it off and do a sloped shed roof away from the lean to. It had a full loft in it that wasn't really safe, so I removed that years ago. As always, I'm open to suggestions.
I left about 6 feet of loft or so in the front for now, it just seems to be a catch all for things I don't want to deal with ha. I'm leaning towards leaving the roof pitched as it is just for the amount of demolition it would take to change it. I'd like to take it down a ways and slope it as it would take less upper siding and at the moment it's all open space anyway, but I'm not sure the juice is worth the squeeze. I probably won't have much time coming up to work on it anyway, so I'm gonna ponder a while. It may end up being a next spring project either way.If it were me, I'd leave the existing roof and I'd be really tempted to put a loft back in after complete. If not a full loft, at least a partial/half one. The one thing I can never seem to have enough of in my shop is storage. I have quite a bit of stuff where I only need it a few times a year. When I do need it, it's a life saver. But it all takes up shelf/floor space the rest of the year.
You must have read my mind - I've got some chromed lense material from old MC helmet that may work, or I've got some various plexi sitting around. Probably going to have to work in some kind of cupholder for the juice boxes. This one's gonna be at least a 2 seater.Got it! - gonna need smoked glass though! Grey plexi maybe?
Heats back here today. the fay is starting at over 70 deg inside and out.. and no AC except for the small window unit in the kitchen.
A little structural love goes a long way!Started some work on my old dilapidated shed. She needs a new roof and siding, but it needed a new doorway and header first. Front foundation was almost nonexistant after all these decades, so I framed and poured that first. Went a little wider on the doorway so my side by side or even my jeep would fit in a pinch. I added the lean to a couple years ago on an existing concrete pad, now just really have to fix the existing shed. Trying to decide whether to just re roof what I have, or tear it off and do a sloped shed roof away from the lean to. It had a full loft in it that wasn't really safe, so I removed that years ago. As always, I'm open to suggestions.
Flat Surface Disease. A lot of members here are victims of this scourge of indiscriminate piling.and FSD?
