help please, coax fitting broke out of tv.
wrenchguy
NW Indiana
i tried researching on my own... my geezer brain can't comprehend the madness i ran into.
my hd tv coax fitting came/broke out of port location.
i only use this tv for live broadcast local station channels in the shop.
i don't stream or get cable on the property, only wifi from a xfinity router for my lap top.
my roko tv has different "in" ports i guess you'd call them.
i originally programed my channels using the roko platform (i guess), nothing else added to my digital antenna.
1st pic showing coax with broke male fitting outa tv (on right).
2nd pic showing ports on tv.
3rd pic showing back of x router.
is there a converter/adapter for the coax to connect to one of the other "in" ports.
most are hdmi ports.
i never signed in/up with roko 4 years ago when i bought new.
PCustoms
VT
Not sure I follow what you're trying to watch, but this might work:
Edited to not confuse anyone else
W
wrenchguy
NW Indiana
thx so far, i don't believe its for broadcast tv antenna hook up.
this part i don't understand from its directions.
thx again.
"( Note: This signal converter ONLY works with CVBS signal , DOES NOT with AHD / TVI / CVI analog signal or SDI digital signal ,Does Not Support AHD / TVI / CVI and SDI )"
PCustoms
VT
Dumber than lumber
Looking at your TV I did not see any ethernet input ports. IF you have any, there also exist cables that connect from coax to ethernet.
Maybe that helps someone…..
wyliesdiesels
Modesto, CA
He is connected to an OTA antenna....
that will not work for OTA RF signals. you need a modulator for that like the one below.
EDIT: I mixed up modulator and tuner.... you need a tuner...
wyliesdiesels
Modesto, CA
thanks for any help.
wow did something melt your TV? what is all that tan stuff on the back?
the Xfinity router has no bearing on the issue at hand.
unfortunately there is no easy way to repair that.
best bet is to get the modulator i posted above
wyliesdiesels
Modesto, CA
thx again.
"( Note: This signal converter ONLY works with CVBS signal , DOES NOT with AHD / TVI / CVI analog signal or SDI digital signal , Does Not Support AHD / TVI / CVI and SDI)"
Those signals are CCTV type signals but neither of those will work for OTA RF signals.
W
wrenchguy
NW Indiana
lol... someone noticed the angle grinder w/ cutoff wheel getting to where the broke piece came from...
male piece was somehow cheap diecast tac welded to whatever it connected to.
it been causing issues few months back so i got it working with strong signal and glued the coax to the tv back.
it worked couple weeks and died.
thx, i'll look into modulator fixing it.
PCustoms
VT
dscheidt
That's the first thing I saw too...
But take a closer look. RF in, HDMI in RF OUT. Unless I'm missing something that does no good...
It won’t. He needs an external tuner, like linked in my previous post. The only other options are repairing the coax port, or buying a new tv. The tuner is cheaper than a tv, and easier than repairing it.
PCustoms
VT
I know it won't work.
After Wylie quoted everything else to say it won't work he probably should have looked closer
W
wrenchguy
NW Indiana
this is second paragraph of your link,
  • NTSC RF Output: Supports NTSC format output with CH3 (61.25MHz) and CH4 (67.25MHz), converting HDMI signals to RF for antenna TVs and RF-input displays. HDMI to RF conversion only, RF to HDMI not supported.
others have noted also.
so now looking into dcshdeidt recommendation..
thx.
justsam
Penngrove, California
You need an external tuner as stated. A modulator would need to plug into the very coaxial jack you no long have. Connect the output of the tuner to one of the HDMI jacks on your TV. The newer devices used in current turners can give you some better sensitivity so you may get a bonus of more available stations OTA. If your feeling plush, Best Buy has TVs for under $100.
wyliesdiesels
Modesto, CA
The link you posted will not work. no where on the box does it say RF. there is even a picture showing it will not work with RF on the amazon listing
The pic you posted here is of the item i shared. 2 different things here. youre mixing them up
here is the item you linked to
and the pic showing its not compatible with RF
wyliesdiesels
Modesto, CA
the modulator i linked to has HDMI output.
wyliesdiesels
Modesto, CA
thx.
yeah i mixed up modulator and tuner... my bad... what you need is a tuner... thats what i get for being in a hurry...
Cruzan80
Denver, CO
Eh, better late than never. Doesnt seem to stop most people from re-answering the question after skimming the middle posts (guilty as charged this time).
BillK
Beautiful Southern Maryland
I dont know how old your tv is or what size it is but as cheap as they have gotten by the time you buy all of that other stuff and go through the hassle of hooking it up you may be way better off just going to Walmart and getting a new tv.
theoldwizard1
SE MI
If you find a good electronic repair shop (possible even a PC/telephone repair place) they may be able to repair the coax input.
If not, HDTV are CHEAP. Buy a new one (shop Walmart) and sell the old one. 90+% of the world does NOT use coax inpput !
(I sold an old iPhone X that had a broken GPS receiver. Purchase gave it to her little kid to watch videos !)
75gmck25
Alexandria, VA
Go to Goodwill or Habit for Humanity and and look at the used TVs. Everyone donates them as they upgrade their home setup, and there should be quite a few available for a very good price.
djbmw
Ottawa, Ontario, Canada
You could just solder a new coax connector on. With that nasty hole in the back you probably dont even have to open it up! You could also cut a coax cable that has a female end... leaving yourself a 12" pjgtail to solder on.
