OldSchool500
I'm building a large pole building, most likely 60x120, on a very tight budget. The finished building will be nothing but a thin sheet metal that will sweat and let noise in and out. I want to cover the interior with the thinnest possible layer( 1"?) of foam, so I can do the whole building. I'm mostly interested in it's ability to seal everything up, more than insulation value. This also makes the steel panels stiffin up and not so entirely flexible.
With that said do you think it would be stupid to have such a thin layer of spray foam? Should I really bite the bullet and get 3-4" while they're at it?
I am in North Carolina, the temperature outdoors is not often very extreme - it's the humidity I have to keep out. It's currently 70 degrees outside and 100% humidity.
I'm not going to air condition the entire building, but I will dehumidify and have some smaller rooms that will be climate controlled. (and they will likely get more rockwool insualtion)
Please don't say anything about foam "popping loose" and causing rust, this is not how spray foam works, even though many who have never seen it happen say it happens like 100% of the time. Stop saying that. The foam sticks like **** on a blanket, it has to be mechanically removed.
