Between 265 & 485 SQ/FT The "Glendora Garage"
D
Dan in Pasadena
Pasadena, CA
Some activity here:
Finally, red paint on the footlocker project. I'm not overly happy with it. it's much rougher than the prior one I did but as Kay says it's a knock around truck bed box. It'll get a final sand and final coat. That'll have to be good enough. The corners on this thing are pretty rough. The angle iron around the top hides a lot of that. I wire wheeled it, hammered it flat, sprayed silver and it looks ok. I've done nothing to the interior. yet It'll be sprayed with truck bedliner. Then hinges, handles, etc. I won't post a pic of this wavy surface.
D
Dan in Pasadena
Pasadena, CA
The Fiat 500 "toad" has some flaking clear coat but fortunately only on the leading edge of grille below hood. Because the mirror came out nice I'll use the remaining paint to TRY to improve that area. I'm not sure about blending it in with the rest of the paint.
The break at the hood and even a body line below is where I'll try to blend .....but on the sides I expect the repair to show. Oh well. Not sure I have enough paint to do the entire grille. But it's a thought.
D
Dan in Pasadena
Pasadena, CA
And after a hot day or two, they'll be a total PITA to remove.
They’ll be off the truck the minute the event is over. There’s an “eagle” with “250” on the tailgate. But since the gate isn’t flat it didn’t want to adhere well. Didn’t transfer cleanly so we had to do it by hand. The pieces got stretched and it’s almost comical how it came out. I expect to go outside and see 1/2 of its fallen off!
D
Dan in Pasadena
Pasadena, CA
Good looking family, Dan. 👍
Did you rent them? 🤣
Nah, they bought me!
In this pic, Lulu to the right. 2 of my 4 granddaughters to the left. 12 and 8 years old. Other assorted cast of characters.
As I write this on a short ferry trip to St. Thomas airport. We’re hearing all sorts of delays in the east due to weather and smoke from Canadian fires. To DC then LA in the wee hours. Pups will be happy.
Last photos of St. John touristy area. All others seem very 3rd world ish compared to mainland.IMG_8280.jpeg
D
Dan in Pasadena
Pasadena, CA
Back to Garage Journal stuff:
Left on vacation 7/17 and had a relatively small die-off in a corner of our backyard lawn. 1/2 the size in the left corner of this pic. Didn't have time to treat it.
Came home to find much larger dead areas and the grass growing very unevenly - but still healthy - in other areas.
Mowed at the highest setting, then a bit lower. Heading out for granular insecticide for cinch bugs - something called bifenthrin which is supposed to be ok to spread near my avocado tree - Won't use it under the drip line area though SUPPOSEDLY it's ok to do it there - I don't trust it. We eat those avocados regularly.
D
Dan in Pasadena
Pasadena, CA
Might I respectfully suggest Gravel, Dan? 😉
If I don't get control of these cinch bugs it'll be on its way to a gravel yard all on its own!
I got the Bug B Gon granules today and spread them with my handheld spreader, watered it in well. But no idea how to tell if it's actually killing off the bugs so I can get some sod to fill the bare spots. I guess I'll try the "coffee can test" I've read about to see. Just gotta find an old fashioned coffee can!
D
Dan in Pasadena
Pasadena, CA
Also posted this in the "What Did You Do In Your Garage Today" thread.
Damn hot here today. Waited til after 8pm to wet sand the footlocker lid from way back in the thread. Only the lid is getting the smooth finish. The edges look crappy but they'll be covered by the perimeter angle iron that came on the box. It looks bright red but is actually the darkest red Rustoleum makes, "Regal Red":
Here's how rough this thing was when I started on it:
D
Dan in Pasadena
Pasadena, CA
See post #2624 above for the "BEFORE" photo:
Stainless strap hinges (what it had though rusty & bent). Plus a hasp latch and rusty strap handle. I'd originally planned silver paint and call it good. This slid down a slippery slope: stainless hinges, latches and handles are Chinese stuff - shiny but that's about all you can say for them.
Here are the "AFTER" photos. I like the smaller one I did earlier but that's because it had been my dad's. Not sure what I'll do with this one but I put it in my '55 just for the photo.IMG_8360.jpegIMG_8358.jpegIMG_8355.jpeg
M.Brane
1 hr N/W of LA LA Land
I like the texture it has. Lets you know it's actually wood. That's pretty close on the color match too. Red is notoriously difficult. My bikes are a hodge-podge of panels from different bikes that were all the same color yet all a little different to the trained eye.
D
Dan in Pasadena
Pasadena, CA
Thank you! If you see how damn rough it was when I started and the actual **** I used to fill the damaged surface it's surprising I got it as relatively smooth as it is.
The picture of the bigger one looks bright red versus my truck but it's the light. It is actually pretty close. The picture of the smaller one looks closer in color but it was the light that day.
D
Dan in Pasadena
Pasadena, CA
Also today, crawled around on hands & knees pulling dead leaves off our day lilies and the weeds that come up around them.....til it got just too hot to be out there. I usually say you can't tell I did anything at all. Today I took a picture just to show what I'd done before I cleaned it all up:
I had the pups with me and it finally just got too too hot for me and for them. When they began panting we moved into the garage to work on the footlocker. I'll sweat but I won't let them get hot enough to pant, ha ha.
D
Dan in Pasadena
Pasadena, CA
KINDA OFF TOPIC. I posted this on the "WTF Pictures" thread too.
I thought you guys would be interested. Walked through the weekly street fair in Glendora Village tonight and saw this vintage Honda Minitrail 50cc bike WITH TRAINING WHEELS! And they're mounted on some custom made fairly serious steel mounts. Though they are very small caster type wheels.
1st - Any "parent" that wouldn't see what's wrong about this for a child so young it doesn't yet know how to ride a bicycle is a *****.
2nd - My son commented laughingly that, "....maybe it's an adult little person's bike that never learned to ride a bicycle." Yeah, ok so "learning" on a bike capable of 25 to 30 mph so he can fall on his head and get killed? *****.
PugetDude
Superstition Mountains, AZ
Old midget Hells Angels don't ride mobility scooters, Dan.
D
Dan in Pasadena
Pasadena, CA
IS there such a thing as an "old" Hell's Angel?
I would assume they all croak relatively young - certain ly not MY age! - either on their bike, due to the drugs and a few get dropped by the Mongols, Vagos, Bandidos, Pagans. A lot of people gunning for them for certain.
D
Dan in Pasadena
Pasadena, CA
The thing about seeing this MiniTrail 50 reminded me of how much I was DYING to have a Honda CT70 when they came out - I think 1969. I was 15 and my mother was going to get me one for Christmas. My brother-in-law talked her out of it. Told her I'd likely get killed on it. I'd have been truly pissed to know that then. Now with 50+ years hindsight I can admit he was probably right.
But, I still went down the rabbit hole online looking for them. Apparently they run from maybe $3k to more than $10k for the desirable 4 speed with manual clutch.
I could get one and be thrilled the first day, first week. I'd ride it down to Glendora "Village" for lunch, then........crickets. Just not prudent to do it, take a chance at falling in general, or on my new shoulder. Damn, being older and sensible *****!
