Question about Converting R22 to R32
exmaxima1
Midwest
My Lennox Elite 13 is now 26 years old and probably living on borrowed time. I'm looking into upgrading from the R22 system to a newer R32 refrigerant. Many installers are quoting installation using my existing R22 copper lines. They claim it is normal to flush and reuse the lines.
Is there anything wrong with using the old lines?
Firebrick43
West central Indiana
Depends where and how they are ran. The old ones could be significantly corroded where it passes thru concrete or touching organic mater/certain chemicals are allowed to touch it and could cause pin hole leaks.
Or it could be perfectly fine.
If you do replace them insist on a good line set with black rubber foam insulation like mueller. There has been enough evidence that the cheaper poly foam (white) is breaking down quickly and causing pin hole leaks.
bob smith1
It is normal, but lineset should be visually inspected as much as possible. Let your pocket decide on a new line set if it looks good. I have no issue with it. BUT, demand that the lines be 'pigged' or swabbed to remove any residue or oils. It's a great time to clean them up, NOT just blow some N through and call it good.
E
exmaxima1
Midwest
One more issue. My system is 3-ton and it honestly does the job though it runs quite a bit at times. The online calculators say I need 5 tons for my 3000ft2 2-story house. Would the same lines handle a 5-ton unit?
bob smith1
You need to lean on your installer more than some online calc. It is NORMAL and PREFERRED that a system run nearly non-stop in the heat. Sounds like 3T is sized right and 5T is an insane jump!
fitter30
Peace Valley,mo
Nothing wrong with flushing a line set. Insulation outside should be wrapped with line set wrap to keep it from deteriorating. When changing refrigerate its not the refrigerate its the oil. There not compatible.
American Locomotive
Rhode Island
I know I'm going to get some hate for this: But if you are the type of person who can tough it out if the AC breaks down, I'd recommend keeping your current system until it dies for good, and wait until the subsequent fall/cool season to replace it. I'm hearing A LOT of problems with newer systems and coil failures/leaks.
bob smith1
I figured that was the plan unless there is drama going on.
danski0224
Near Naperville, IL
Imagine being a guy that has not had normal AC for 6 years and in extreme cold, has frost on your blanket and floor, and no running water in extremes, yet HVAC licensed and serve others "need".....lol I swear it's odd but I fought to keep assets after a covid explosion, instead of being comfortable. My computers tap out before I do, so 85* sounds pretty good to me.....lmao.....
Good for you, you are in the top 0.5%... I would guess... as far as living without AC is concerned.
I have met several that claim to be close, but flip 180º when the AC breaks.
75gmck25
Alexandria, VA
Another option is to purchase one of the roll-around portable A/C units, preferably with dual hoses (usually a little more efficient). Use it now to cool your garage, and then move it into the bedroom or family room if you lose A/C and are waiting for repairs.
