Craftsman fence help
Modagger
Hamden, Conn.
Greetings!
I’m in the restoration home stretch on a Craftsman 103 24280 bandsaw. (Photos when it’s completed).
My dilemma is that it didn’t come with a fence or fence guide rail. I picked up the rusted hulk of a 103 .0204 table saw with a rail and fence. The rail was not salvageable but the fence is.
Going over it today, I noticed that the cast jaw that tightens to the table is broken.
Does anyone have the part that can take measurements and a few photos for reference? Any help would be great.
Thanks and be well
Jeff
The Cobbler
that should be fairly easy to replicate by guess & by gosh .
I would guess it was just a tab that extended, with perhaps a slight tweak to it so it clamps firmly on the rail
that other piece looks like it's bent a tad too
M
Modagger
Hamden, Conn.
Well, by gosh Cobbler, I was fixin’ to do just that but thought I would dip a toe into the fount of knowledge first.
Definitely been ridden hard and put away wet.
Thanks!
Jeff
Cruzan80
Denver, CO
I think I have the same fence, that I will be mounting on my 18" Craftsman bandsaw. Will try and take pictures soon. If not identical, should be very similar.
Edit: The following was for the later 24260. The "original" fence was basically the same as the jointer (4", IIRC), with a t-slotted bracket for it to slide along and tighten up against.
I have an OEM fence for the 24280 that I can also take pics of to compare with the OP. I sold the 24260 fence when I sold that machine.
Cruzan80
Denver, CO
So, backing up from what I said earlier. I actually have THREE different t fences that I took pictures of. The one in the OP closest resembles the one that is on my Long C Scroll-saw (why someone would want a fence on a scroll saw is beyond me, but I believe it is origi nal to the machine).
The first four pics came off a later model TS, which is the one I was planning on cutting down for my 18" Parks/CM. The second set of four pics is the OE fence for the 24260 (the top knob tightens the back gear, the front pushes a set-screw against the front of the fence). The last set is the one on the scroll-saw. I can get measurements or better pics of any of these, but present a "plethora" of options so as to help those needing details about any.
Cruzan80
Denver, CO
Sorry, pics decided to load out of order. The second pic is the 24280 OE fence, the last one is the "scroll-saw" fence that I think matches yours (overall view is 3rd/4th pic).
M
Modagger
Hamden, Conn.
The pics confirm what I was thinking of needing to create.
Thanks again
Jeff
