Show your new tool arrivals
Ohio Andy
Columbus, Ohio
If you don't "shake rattle and roll", hex-drive bits tend to stay where you drop them.
For me they usually fall out near the edge of a table or something and then they hit the floor and just go wherever. You know how cats always land on their feet and toast always lands jelly side down... That sort of thing.
willf650
Normally you can dump extra bits into the top (more than comes with it) but they are not organized
You can hold fewer bits but they are easier to sort and a random bit won't tumble out and roll away.
I’ll stick with dumping bits in the palm of my hand and buy 2 margaritas at my favorite Mexican place during 1/2 price margarita night.
We all have our priorities.
Ohio Andy
Columbus, Ohio
You make it to the middle of Ohio and the Margarita is on me....
Edit to add.... And I don't mean go to the middle of Ohio. Buy a margarita and send me a bill. I mean go to the middle of Ohio. Tell me you're in the middle of Ohio then we go to get Margaritas.
wire
Williams Screwdriver Bit Holder, I can print that for just about nothing :ROFLMAO:
Looks like there's some remixes to improve it.
everett464
Had one of those days where multiple eBay packages arrived, and I incidentally found a Snap On truck in the wild. Overspent at SO on toys I don't need, but I have no regerts.
The adjustable is a FADH8C - which is an 8" flank drive. Both ratchets have surprises... the multi-position is a 3/8 drive, 1/4 body (FHC72MP ), and the tiny guy is a 1/4 hex drive (TM72). Slip Joints are the newer hose clamp pliers (HCP48BCF).
Then we got the wild Vessel JIS 2-way speed handle 11-piece (SLH2-1U), and the EZRed 1/4 Stick (4S12L).
Finally, a couple of vintage USA nut drivers to finish off my mismatch MUSA SAE nut driver kit. The Crescent Bridgeport appears to be NOS. I might try to attack that rust in the handle of the MAC, but I also might not.
CHI_Tool&Die
Chicago, IL
Spent some money this week. Grabbed the fixed extensions off a Matco BOGO promo on the last flyer. They were on backorder for about two weeks. While picking those up, I grabbed the Matco wobbles on promo. I have two long 3/8” wobbles on extended backorder still.
I needed a new jack and was lucky enough to have a 25% coupon for HF. I wanted yellow but my HF seems to hate yellow and the cashier and the manager really, really did not want to order one so I grabbed purple. Now I just have to wait for the parking lot sale and I can grab some purple Jack stands. Also, this was the first time in a while where my local HF actually had stuff in stock. It felt nice seeing things on the shelf.
willf650
This tool has been posted here before but it seems to be an excellent tool for the price. It's as cheap or cheaper than all the Chinese Xyfoo or Zxfi brands on the jungle but has replaceable batteries.
Hopefully Walmart keeps the batteries around as it's their store brand. I would consider trying another 12v tool from them at the price points they sell for.
Used it twice already at home and will take this to work to blow out the bottom of control panels. It's a lot smaller to carry in than a cordless shop vac.
YesIHaveAHammer
Metabo SSEP 18 LT BL cordless reciprocating saw
Finally went for this, and entered another battery platform. This has switchable orbital action yet still only weighs 3kg (6.5lb) bare. It fits well in the hand with the angled grip and narrow front, and the battery is tucked away compactly underneath. There is also an "LTX MVT" variant which is more powerful, has a vibration damping system, and a speed selector dial - but is also 1kg (2lb) heavier. As far as I know, this original brand will continue here in Europe. Made in China.
Metabo basic set 2x LiHD 5.5 Ah batteries & ASC 145 quick charger
These are Milwaukee Forge equivalent in power output, but surprisingly affordable. The CAS battery alliance has about 50 other brands, which are almost all for some quite specialist tools. The charger is air cooled. Batteries made in Hungary, charger in Vietnam.
Metabo metaBOX 145 L
The saw came in this, and I have a few of these already. They're especially good for an included box - stackable, interlockable, two handles for carrying vertically or horizontally, and not too bulky for the internal capacity. Quite a few sizes are available so you always get one appropriate for the tool. The plastic insert is designed for the bulkier LTX MVT variant of the saw, so doesn't quite fit this right.
Bosch reciprocating saw blades, flexible for metal - 24tpi (S 922 AF), 18tpi (S 922 EF, S 1122 EF), 14tpi (S 922 BF)
Bosch Expert reciprocating saw blade, carbide for thick tough metal - 8tpi (S 955 CHC)
Bosch/Metabo reciprocating saw blades, flexible for wood & metal - 10/14tpi (S 922 VF equivalent, S 1122 VF)
Bosch reciprocating saw blades, top for wood - 6tpi (S 644 D)
Bosch reciprocating saw blades, progressor for wood - 6-10tpi (S 2345 X)
Bosch reciprocating saw blades, top for green wood - 5tpi with gullets (S 1531 L)
Should cover most things. I'm sure I could have done with fewer types, but the wrong blade/abrasive can make a lot of difference, and they were on discount purchased with the saw. Made in Switzerland.
Bosch Tough Box for Accessories large (2 607 011 826), small (2 607 011 825)
These are the total opposite of having a plethora of loose blades, bits, discs, and fasteners in your power tool cases. I'll probably ditch the molded plastic insert in the saw box and leave the charger out to make room for these. Caught an Amazon flash deal so the price was ok.
Makita D-19021 SDS-plus chisel 20x400 mm (13/16" x 16")
Makita D-19015 SDS-plus bull point chisel 400mm (16")
For deeper or confined spaces where the drill is obstructed. Not many options at this length or longer without going to SDS-max.
willf650
Gesundheit!
Agreed, I love how small it is:
It does go though batteries quickly, but I like the USB charging. I will pickup another pack at some point.
Do anyone have the HT installation driver by chance? It's like the Temu/Wish.com version of the M12 installation driver :ROFLMAO: :
At that price point buy it to get you the second battery your looking for. The tool is less than twice the price of the battery by itself.
Steel_Rain
I guess they revised it with 4 heads now? And type C charging, plus an upgraded motor. Cannot find a single review of the revised version on YT.
You’re right on the price. It’s damn cheap.
cody1325
Southwest Virginia
Gesundheit!
I have the last-gen, and it's done everything I want it to. However, I wish I'd just waited around a year, as the new one is brushless, and has the off-set head the Milwaukee and Bosch ones do.
I have the impact, reciprocating saw, installation driver, inflator, and a drill (which I still have in the package--my Bosch does just fine for that); and for light duty, they're all great; even though all are the older brushed tools. Their place is for light duty jobs I don't want to drag 20V tools and batteries around (DeWalt or Craftsman V20). I'm getting the blower, oscillating tool, and die grinder tomorrow. Probably 3/8 impact as well.
Caa311
Virginia
Those pro tough boxes are sweet but the price is steep!
willf650
This is what happens when you’ve been thinking about getting another workbench to cover with **** along with the other 3 benches you have so you still can’t use it as a workbench. You do an online purchase as none are available in store and then change your mind and cancel it. You look at it again 2 hours later and it’s magically $150 cheaper than the price of the order you cancelled.
Home Depot is the instigator in this situation.
Now I have to try and get this up on its wheels and get it out of the trailer with a 6 week old hip and help from my girlfriend. I suspect no good will come from this endever.
Edit: It's assembled and out and I'm icing my hip. This was in part thanks to to DeWalt construction jack. One of those tools you never knew you needed until you have one. I've used it several times in the couple months I've had it.
I know this isn't a super high end box but if I ever move to industrial maintenance towards retirement this will probably come to the plant with me. This box actually had a 3/16" thick channel iron frame structure in the base and 6" casters. It's made to be moved around a plant compared to my other boxes.
It also has long item storage under the top. It will fit a 48" pry bar under there with a little room to spare.
a6hux
Newton Township, Michigan
