Torq screw drivers and wrenches for electrical work?
cdoublejj
MO
any though opinion, and preferences welcome and appreciated. i see HJE has some available
C
cdoublejj
MO
Torque screwdrivers? Torx screwdrivers? Torque wrench? Torx wrench?
Electrical work of what sort? What is a "though opinion"?
Torque! ....as in: "The screw terminal wasn't torqued down causing high resistance and substantial heat just before the house burned down."
um...uh... "T"...... "O"....."R"....uhhhh......"K"
C
cdoublejj
MO
Cant go wrong with Wiha for any type of driver but you'll also get ten other opinions, as always.
i have noticed those don't take regular bits and gotta buy the ...shafts... separately but, i think they are insulated unlike the Torque drivers from Wright/ for the bigger lugs i see some guys use the 1/4 torque wrenches.
manwithtools
Lebanon, TN
Nope, you can get them that accept the typical 11/4" hex bits. This plus a 1/4" torque wrench will take care of anything Joe homeowner will encounter. One thing to note, look for the widest and thickest flat blade bit you can find. Some of the clamp screws you will encounter on breakers or panel busses can strip out if you use a narrow bladed bit and try to achieve the listed torque.
Example: SoftFinish TorqueVario Screwdrivers
C
cdoublejj
MO
looks like it's out of stock ATM. also eyeing the HJE tools Wright 2464 it looks identical to the snap on. oddly the snap on is the same price.
C
cdoublejj
MO
it looks like wright is also rebranding the CDI,
which explains why wright and snap on are the same price
badmatt
Canada
Wiha makes a nice one.
C
cdoublejj
MO
good luck finding a Craftsman CMHT68130 it's looking promising so far, need to see the accuracy numbers on the capri
EDIT: capri did better than vortex, wonder if it's variation form the factory and as vortex and capri are the same unit
C
cdoublejj
MO
i got the Capri, wasn't gonna buy TWO $180-300 Torq screw drivers to make up for one. i've have bought the CDI if it was 10-50 in lb range.
