Between 705 & 1200 SQ/FT The Texas Barn in PA
M
madison069
Monroeville, PA
The shelves came in yesterday and I got them assembled and installed in the shed. I condensed the smaller gas cans down to one can as they were two cycle fuel and I needed multiple cans for different properties back in the days.
Now to organize the lawn tools on the back wall, bring the lawn stuff from the bunker into the shed, and continue to purge.
M
madison069
Monroeville, PA
Looks like your boy is definitely a “Tidy Cat” man! 😂
Funny thing is I collected those buckets from recycling days from the neighborhood before I got my boy. But he does use Tidy Cat, but from a cardboard box style while I transfer the litter into a plastic bucket just because I like the bucket more than an open cardboard box and the cardboard box style is cheaper!
Those Tidy Cat buckets are nice cause they are square and easier to store, I think. Along with those buckets are the ones I used for removing the bunker dirt, so they earned the right to hang around a little longer.
M
madison069
Monroeville, PA
After doi ng some small jobs, I got more yard stuff out of the bunker and in the shed. Now atleast I have it so in one place and I can organize it.
After that task I got two mowers fixed and cleaned to post for sale.
I got this 2 cycle lawnboy next as it’s my last mower to fix.
I haven’t repaired a 2 cycle mower before, so it will be interesting to see how this goes.
M
madison069
Monroeville, PA
I’m sorry future self if you ever have to get this door sill plate out.
I called up the metal shop close by and was able to get a 1/4” plate cut to the dimensions of the bunker door sill.
I decided I would do anchors to hold the door sill in place. So I welded some big bolts and put nuts and washers on the end of the bolts.
Weld looks ok.
Heat got through too.
Prepped the door sill, cleaned it and chipped any cement mortar that was on the surface. Then taped the top flat surface.
Here we are filled in. I left the holes that got the anchors a little low for displacement when putting the anchors in them.
Then removed the tape and applied loctite adhesive, overkill? Probably. I just hope I never have to remove it.
Just like that, the door sill is in place and pressed down with wood and a high lift jack.
Hopefully this doesn’t come back to bite me.
Once it’s cured I’ll work on the side frames, decided to just use pressure treated wood. Once I have it all framed out I’ll measure the opening and start designing the door and find the hardware for the door.
M
madison069
Monroeville, PA
Got to love old cable installer jobs. Instead of removing the junk, they just put new on top of old.
Here is what I started with.
After pulling all of this cable off the wall, it was looking cleaner.
Here is the finished results.
When I get ready to run new electrical wires through this attached garage I’ll also clean up the walls and patch all of the holes with cement patch.
For now, this will hold over.
Why did I even do this now? Well the internet connection was really crappy on the other side of the house and the garage. So I wanted to run a new cat6 line from the router to the new location of the WiFi extender. Not much to write about there except I got a new wire fishing stick set for the job. Went with the Milwaukee 15ft glow in the dark sticks, works pretty slick!
Oh and I did get the air compressor switch wired up and working now since the WiFi was stronger in the garage. The switch that the remote relay uses can’t go far in the garage, guess it’s due to the concrete and ground. I can use it as long as the switch is above the air compressor location. But the app it comes with is pretty nifty and it works great once I got the internet network split into 5ghz and 2.4ghz instead of the Self Organizing Network and also turned on the internet of things network too.
Here is what you see on the app when using it to turn on the air compressor.
This will allow me to see if the air compressor is on from the house and can be turned off without going to the bunker!
Tomorrow is cleaning day since it’s trash day Tuesday. Hope to toss more stuff to the trash guy.
M
madison069
Monroeville, PA
Much cleaner.
Did you retain the surge protector and ground at the cable entrance wherever it was relocated?
It wasn't even connected to the ground. Along with the RG6 cable isn't being used throughout the house since they installed the fiber optic line. When they did the fiber optic install, they disconnected all of this stuff and just left it on the wall.
M
madison069
Monroeville, PA
Much cleaner.
I should have also added that the TV and internet in the house have gone away with the RG6 cable, they are all connected via Cat6 cable or WiFi now. Hence why I relocated the WiFi extender to the side of the house close to the garage. So, if I even left the RG6 surge protector on the wall and actually hooked it to the ground rod outside, it wasn't going to do anything.
I'm trying not to be a hoarder, but I'll keep the surge protector and ground cable in my box of data/RG6 cable parts and nick knacks as a just in case deal.
