Below 265 SQ/FT DRIVESITFAR IS GETTING ORGANIZED in his 9x15 portion of 2 car garage. DIY’s & COOL VI
All workspaces below 265 squarefeet.
Nobody-named-Olli
Drives, my normal recommendation with carbide blades is to use cutting paste/wax as coolant when cutting metal/ screws. Most of your carbide blades seem to be for nails embedded in wood from what I can make out in the pictures, except for the one still in its package. Generally speaking, everything that says wood & metal or wood & nails is pretty much the lowest tier of available blades. You might have better luck with that blade that is still packaged & cutting paste/wax as coolant.
My go-to carbide blades are the Bosch: https://www.boschtools.com/us/en/starlock®-oscillating-multi-tool-carbide-plunge-cut-blades-43933-ocs-ac/
I do not know right now if these blades are compatible with your generation of Fein multitool or if an adapter is going to be needed. Let me know if you want me to find out/ look into it more closely.
Slow (tool set to 3 or 4 tops!) and as much movement while cutting as you can + the cutting paste/ wax.
That should do the trick. The cutting paste/wax can soil the siding, so keep a rag handy. ;)
I would not recommend that diamond disc on the angle grinder for this, that is unless it is one of those “cuts all” site universal/demo diamond blades.
Kind regards,
Olli
D
drivesitfar
Ollie thanks for your very detailed and educational post. I really appreciate the information and I’ll definitely keep this in mind next time.
I didn’t see Ollie’s post before I attacked the siding prep today and there are good minutes and not so good snd more than a few swear words and a fall from a precarious position to remind me I’m not 30 any more.
I ended up using my fien Multy tool with the Diablo nail embedded blade and I’m guessing if it was cedar siding I might have started a fire. There were only 4 screws and sometimes I push the blade hard and sometimes I just let it grind away. I thought the diamond blade on my grinder was a bad idea so no go on that one.
I did manage to get the screws and old unnecessary tar paper out of my way so I can slide up a new piece of siding when I get to that point.
Instead of hammering in 1x4’s for backing with construction glue I had some tap cons that worked great after drilling holes with my new sds plus Diablo 3/16th bit on my Milwaukee plug in roto hammer drill.
I got both sides of the stairs prepped for new hardie plank siding and Azek trim now. IMG_1385.jpegIMG_1387.jpegIMG_1388.jpegIMG_1389.jpegIMG_1390.jpegIMG_1392.jpegIMG_1395.jpeg
Denwood
Thunder Bay, Ontario, Canada
Woody: thanks as always for checking in on my doings and for posting a few good words too.
Maybe I didn’t explain myself correctly but I already own 2 Fein Multy tools and maybe a 18v Ryobi too. The issue is finding a great metal and especially screw cutting blade. Diablo seems to make decent ones for nails and wood but I can burn thru blades quickly trying to cut a few screws.
Anybody have suggestions please post them here and I’ll buy a few and give them a test. I think my diamond blade on my Dewalt 4.5 grinder would work but since screws are behind siding I’m not sure of kickbacks if I can’t see screw.
It’s hot here (96) today so watered lawn and light duty stuff for this old guy cause it will be under 80 tomorrow.
Ah, so well equipped :)
I always a have a pile of blades on hand, but the best for metal are carbide blades, designed for metal cutting, like this: https://diablotools.com/products/DOS125CF The bi-metal blades seem to wear out in less than one cut...
From your pic though, you already have these...
D
drivesitfar
Woody: I walked into HD and checked out their sale Diablo blades display and picked up a couple more packs of their nail embedded wood Multy tool blades which seem to work the best. I’m going to check to see if Ollie’s Bosch blades will fit one of my Multy tools and see if his method with greasing and slow cutting works better. I swear that these blades could cause a fire if you’re not careful so all of you bee careful.
I was going to buy a Diablo hardie plank (cement board) 7.25 blade for my skill saw and found a 5 Incher that should fit my Ryobi 18v saw so I can cut up the 10 or 12 foot boards in the parking lot to just throw in my Honda and have less chance of breaking a long piece on my trailer.
P: thanks and I agree All the plug in Milwaukee power tools I own work great and I just never found deals on their 18v tools which probably means they work great too. Still a bit of work to do with siding and trim install but I’m making progress.
Did I mention my bride likes to eat well and she’s a great cook so obviously I benefited these last 40 years with her around. Today it was 3 scrambled eggs and a couple waffles with lots of fresh fruit. I’m good til dinner.
I’m having a couple issues with electrical mostly outlets tripping so I need to do a little modification and replacing almost 20-40 year old outlets. I upgraded about 90% of the wiring from old knob and tube when we moved in 40 years ago and I’ve changed out all the outlets and switches at least once and in most cases twice to modern ones. That said the 40 ish old service panel has some old breakers in it that probably could use and upgrade. I like simple good working ones and some of the new gfci breakers look like maybe they might be a problem later. Anybody have favorite dependable breakers to recommend? The big box stores have some great, good and cheap choices but I think I’ll head to the local electric supply store to get a bit better quality. Platt is the one in our area unless someone knows of another?
BTW we still love this waffle maker we bought about a year or so ago for I think around $50.
Have a great weekend!!
D
drivesitfar
I’ve owned Ryobi 18v tools for maybe 20+ years and dewalt 18v for maybe close to 10 and I’m still learning about them.
The small hardie plank 5 inch blade I was going to put in one of my Ryobi 18v skill saws didn’t work cause hole is about 3/4 inch and Ryobi blades usually have a hole about half that size. I thought maybe finding a washer to fill the gap might work but closest I found was a copper lock nut but I would have had to dig out a grinder (I have mine in storage at the minute) so I installed without anything and it might have worked for a few cuts but remembered I also have a dewalt skill saw. The dewalt blade is a bit bigger than the Ryobi blades (6.5 to 5.5) and hardie blade is 5 inch but dewalt uses the same size hole. Even though it doesn’t look correct I think it will work nicely for the few siding cuts I need to make. While I had the old Ryobi blade off I installed a Diablo blade with a few more teeth so I can cut azek trim if I don’t want to pull out a miter saw.
I found the electrical issue before tearing into the service panel to check and or replace old breakers (still looking to do this in future). I had installed a gfci on the inside outlet where I pulled wire to outside one that wasn’t working (pushed the little button in and good to go to power up outside gfci). It’s not easily seen so I did turn on and off all breakers a couple times before I figured it out. I also changed out an old outlet and put in a new waterproof gfci and cover and I’ve got a couple more to do this summer.
My bride is making French toast so we won’t starve and also scrambled eggs do we get our portion of protein too.
D
drivesitfar
We tried a different nursery for our tomatoes plants this year and the cherry size sun golds are pathetic but the big heirlooms are Jurassic World size. Anyway same gardener and just different varieties that can make all the difference. These two separate planters had their plants planted within days of each other. Soil and types of plants can make all the difference cause both have been getting plenty of sun and water.
Heading to the first of a few dump runs now that the deck restoration is nearing its end. Lots of to do’s and honey-do’s to do still and maybe guest on list now is building a new gate. I need to figure out a good way to install a couple 6x6’s next to our garage. IMG_1415.jpegIMG_1410.jpegIMG_1420.jpegIMG_1419.jpegIMG_1417.jpeg
M.Brane
1 hr N/W of LA LA Land
Don't write off the cherries just yet. When we've planted them they eventually try to consume all available space, and keep sending up volunteers long after you've ripped them out.
Deck is looking fantastic.
You have concrete there. I would fab up some square tube support posts, and fasten 'em down with anchors. Then you can attach whatever gate you choose.
Prospecter
Maine
I second M.Brane's thoughts on the posts. Your deck, gardens, and house are spectacular. Just gorgeous.
My cherry tomatoes just haven't done anything this year. (Sweet 100). Odd because they are usually first, and most prolific. However, between drought, neglect, weeds, deer, and groundhogs, the garden has languished.
Love the flowers mixed with the tomatoes.
Always satisfying to clean up and head to the dump.
D
drivesitfar
MB: fabrication skills are yet to be attained in my skill set but good idea. Thanks for the good words and idea!!
P: the flowers under cherry tomatoes are marigolds that we buy every year with our tomato starts to keep bugs away. In Jurassic type garden are the flowering ones are actually cilantro that will be a spice (forgot which one at the minute) for our homemade chai we drink daily. My bride makes two batches a week that are amazing. We have one big glass a day usually around 5pm with whole milk or cream and cold.
My thinking on attaching the 6x6’s to concrete next to garage so far is using a few (2 for each post) 6 inch 3/4 inch bolts with the concrete sleeve on them and attach 6x6’s to each pair unless I figure out a better way.
I have at least one mole ringing around our planting areas and he’s popped up a couple times in the middle of my front yard. I am pretty sure he’s not finding grubs under the grass cause I use grub killer in April and September but I was a bit lat (May) this year cause of the new seeding. I may have to relocate him to mole heaven but for now he’s behaving ok.
rharman
SoCal
@drivesitfar - On your question about circuit breakers.... It's not an issue of "favorites". You're going to be limited to those that are approved for your panel. Look at the info sheet usually attached to the cover of the enclosure. On some, you'll have to remove the panel cover itself as it may be on the inside.
Besides the big box stores or electrical houses, one online source I know of (but have not used) is CircuitBreakerWarehouse.com
Also, what brand panel do you have. If it's a Federal Pacific (FPE), you would want to replace it.
Federal Pacific Electrical Panel Issues <=== Link
D
drivesitfar
RH, thanks for the information!!! It’s not simple to see the name on my circuit panel where it’s located in my garage but I’m pretty sure it was a square D panel.
I’ll pull a couple breakers when I get time after my summer projects and take a few pics and let all of you see and I’ll do some research too.
I did replace all my old outside outlets with new gfci outlets and new covers. AND I just picked up the azek trim that they sell in lumber measurements. A 1x4 pvc board is 3/4 x 3.5 inch. I need a few boards at 5 and 4-4.5 so I picked up a couple 1x10’s I’ll rip with my new track saw. I also picked up a few 12 foot hardie plank pieces and brought my 18v Dewalt with the hardie blade so I could cut off 4 footers I’ll need and do 8 footers could fit inside my Honda pilot. I can carry 10 foot material inside my Honda but if my bride is with me I won’t put 12 footers inside.
Having a great weekend and we had two of our young granddaughters over last night for a sleepover and they loved the new deck to play on.
D
drivesitfar
Fires are over an hour away but winds have brought heavy smoke into our area the last few days so outside work has been put on hold.
Mid 80’s still so probably would be closer to mid 90’s without the smoke but that would be awesome if it blows away (or stops burning).
Plants and grass are growing like crazy with just a bit of water and harvested our first big sweet onions and beets. Broccoli and celery are starting to show their potential too.
D
drivesitfar
I almost forgot the figs, and lemon cucumbers (tasty and size of a baseball) and pics so here’s a few.
With prices in quality deck and patio furniture more than a bit spendy I found a decent quality two year old set on offerup that will work great for us.
For any of you thee as t don’t know about sunbrella fabric there is a reason why it is two or ten times as expensive as other outdoor fabrics. These simple looking chairs swivel and rock which is what we really wanted. IMG_1469.jpegIMG_1468.jpegIMG_1466.jpegIMG_1467.jpeg
Prospecter
Maine
Those lemon cucumbers are delicious! I also plant Boothby's Blonde, which is a local heirloom I like even better than the lemon cucumbers. I generally plant both for the sake of redundancy. Never seen lemon cakes as large as yours though!
Sunbrella is good stuff.
What are the boards leaning against your foundation in the second photo?
D
drivesitfar
Thanks for the tips on cukes!! Our 4 year old granddaughter eats lemon cucumbers like an apple after we wash it.
Those are removed pieces of hardie plank I cut on different joints so I could stagger the repair. I’m using a few of them either on shorter replacements or ripping them at 2 inches to put under bottom rows.
Hope you aren’t getting any of this smoke residue cause it dampens an otherwise awesome summer weather we are having.
Any buyers giving you the “offer you can’t refuse” yet on your house/farm?
Prospecter
Maine
We only had a few days of smoke early in the summer from fires farther east. Nothing like you folks are enduring.
Lots of saves, lots of showings, but not The One yet.
D
drivesitfar
P: good luck on your sale and I’m praying and crossing fingers and toes for you. I bet it’s nice having all your tools and tractors and accessories at one place now.
Woody: I’m not sure what you are looking for but I’ll try to document a few things on the siding repair. We changed our old 4 inch 3 steps from upper to lower deck to 2 6+ inch ones so I needed to pull off about 5 rows of 6.25 inch hardie plank siding. I think we opted and installed these planks with a 4.5 inch reveal.
Getting the old siding out was pretty easy on one side cause I just needed to pull off a nailed in piece of 1x1 inch cedar trim to expose the screws. Then taking the top rows off and exposing the lower screws made they pretty easy. I did cut some of the long planks in place with my Dewalt 4.5 inch grinder with diamond wheel which is my tool of choice. When we installed the hardie about a decade ago I used a sort of scissors made to cut concrete board that I gave to my brother in law that helped and he does construction for his day job. The hardie plank was to replace the failing LP siding I installed another decade or so before that so I just made sure the 1x4’s were still glued and nailed or tap con screwed or ramset nailed to my concrete block home.
The other side of our old steps siding was a bit more difficult taking a strip out of the middle and I talked about it with some pics last week.
There are many choices I could use for the trim that will be painted. I originally installed cedar trim 1x3’s and 1x4’s and the new trim around our deck will be Azek pvc trim. Since I originally had 1.5 inch treated wood decking and I was planning on replacing with clear cedar until my bride convinced me that we didn’t want to restain it every couple years at our age. So with the timbertech being an inch our new azek needed to be 4 inch and believe it or not the pvc products 1x4 is actually 3/4 by 3.5 go figure. Anyway I decided to use my new track saw to rip the 1x10 (3/4 x 9.25) to get my 4 inch and 4 inch plus trim pieces.
Hopefully by the end of next week trim will be installed and ready to paint now that it’s a lot less Smokey around here.
Hope you are all having a grand weekend!!
