I have no experience with Konnected GDO Blaq, but I'm guessing they use the ESPHome integration to HA? - I have configured my HA to crack the garage doors when the inside temperature is warmer than the outside temp. I went with the Ratgdo32 solution which uses the same interface and was pleasantly surprised that in HA, you actually can make the door move in any direction after it has been partially opened.My one minor complaint is that if you stop the door on its way up, you have to finish it going up before you can put it back down. It is a minor quirk but since it has the ability to set opening at times based on the percentage of open, it would be nice not to have to open it all the way before closing in the summer/winter if opened to vent for a little.
