Show your new tool arrivals
ElectroMechTech
N. Carolina
@ElectroMechTech “FPZ3” ? Where do you come across that size?
Kind regards,
Olli
We got a couple of large ***, oddball contractors at a site that has them. I'll try to remember to take a pic and post it. Truthfully a proper sized flathead will work. However we are rather OCD bunch at work, with a little weaponized autism sprinkled in. If someone bothered to make the screw, then someone probably makes a driver for it. Lol.
Beerhippie
Far NE Oregon
Kind regards,
Olli
The sets I've bought--Milwaukee--come with 2s and 3s. But I need 1s, too. Some items around the brewery--like Leviton NEMA L15 plugs and sockets--require all three. Some only need the #2 and 3, but some need the #1 for the screws that hold the two halves together.
I hate and despise FPZ, ECX and all the other alphabet-soup fasteners. Damned electricians--they even still use slotted and Robertson #1!
ElectroMechTech
N. Carolina
I remember years ago there was a torx varietal that had restricted sales distribution of both the screws and the tools to deal with them. Oh, you want right to repair? No problem. Here you go. You just have to jump through hoops and spend absurd levels of money to do so.
Beerhippie
Far NE Oregon
I recall when the posted (Security) Torx were like that. If you tried to buy the bits or drivers, you were treated like a criminal.
KnurledNut
n/a
With the screws designed to accept both types, is it that neither work well in practice, and hence the need for FPZ1? If so, seems the screw designers' plan didn't work out.
Sorry to continue the derail, but:
It depends on the combo screw and the way the head drive was engineered. Some are better than others. The convenience of using multiple drive systems often outweighs any sacrifices. There are some instances though where this is reversed and using the wrong driver causes permanent damage and even makes extraction difficult.
An example is receptacle strap screws that are notoriously thin and soft, yet have to be torqued fairly heavy during installation. Most of these end up cammed out and filled with paint or compound, furthering removal issues. The older ones were often just a slotted screwhead and could be easier to remove. The modern ones are a combination drive. The Pozidriv/slotted has an excellent fit and confident bite. Of course, these combo drivers come with their own aggravations, like when the driver slips out and you have to turn it 180° instead of 90° to reinsert.
Pinne
I bought this 7" Rockwell grinder last year, but don't think I got around to posting it. I just changed out the casters on the base so they actually roll. With the new casters I'm into it for $95 and it spins smooth as could be. I don't use the grinder all that often so to be able to roll it out of the way is great.
Hakeem
Chicago
Expensive month so far - grabbed this 3/8” digital torque wrench on sale. I’ve been encountering a lot of torque-angle specs, as well as a lot of <20ftlb torque specs, and this ought to handle both.IMG_0441.jpeg
They recently revamped the range from 20-100ftlbs to 5-100ftlbs (and can display units in inch-lbs) so it can handle a lot of the lower range stuff you’d normally need a 1/4” torque wrench for. A coworker has the 1/2” and it’s pretty nice - it has red-yellow-green lights on the side, vibrates, and beeps to let you know when you’ve reached the target value.
For 30% off, it was a no-brainer.
manwithtools
Lebanon, TN
What was the price after the 30% discount. My web search shows $359, is that correct?
Hakeem
Chicago
I don't really buy into the torque-angle specs thing, I bought my SO of the same ilk for the same reason but then seeing the differential in final torque I feel more comfortable going to final torque by the numbers.
i hear ya. On older stuff or when reusing fasteners I don’t always go to the full torque spec out of fear of breaking something, but I try to adhere to OEM torque specs whenever possible. I don’t have enough experience yet to decide when it’s ok to “break the rules”.
~$240 or so. So yeah I think $359 full price is about right. On sale it’s still not cheap but a hell of a lot better than full price.
Squankum
Southeast
Recent purchases of a few weeks ago:
1) Prothane brand jack pad. $18.51 Amazon
Had trouble finding it on Amazon this time around, but figured it out. Really wasn't finding it on the Prothane website, they're busy selling suspension bushings to the kids who .... like that sort of thing. Appeared to be in stock at Summit Racing, too.
Bought one of these about a decade ago and it's almost indestructible.
2) HF "BADLANDS" 3 ton jack. I bought it for the wheels! Seriously, working in a gravel lot sometimes lately. Not until I got it home did I discover it's a giant aluminum jack! Handle, too. Neat. The other reason I was buying it was that lifting my normal 3-ton jack into the car was a bit of hernia risk at 100 lbs and I was going to keep this in a shed at the remote location.
Not cheap, but there was a 25% off sale that weekend. I don't think I could have pulled the trigger otherwise.
I am not an member of the Inside Track cabal, but I see this today:
Also comes with a pedestal you can bolt to the normal jack pad, for vehicles with lots of ground clearance. A hex key for its bolts has a hiding spot on the jack, too. I'll be leaving all of that at home. The pedestal base/tube is steel.
A stamped metal 19mm wrench is included for the wheel nuts. Who buys a 3-ton jack and doesn't have wrenches? Just for that I installed the wheel nuts with a Snap On Dual 80 ratchet. (And I'll be re-doing the job, noticing the washers too late, distracted by the other stuff I don't care about which I think straps the pedestal in another spot on the jack when not in use.) Instructions about some of this are vague or absent.
Shown in the pic above but not at all visible is the plastic block preventing the pump-handle yoke from rising. Boy, did I feel like a caveman. Read the instructions and heard the tale of a mysterious plastic block to be removed, but only with goggles on. Ah, it's black plastic. Jerks.
Jack also has a fabric lifting handle loop. I've not hoisted this thing yet, so I don't have an opinion about it. It also has the side handles like the baby aluminum race jack. Also -- pretty neat -- there's a skid plate. I don't foresee using it, but I don't work in the... BADLANDS.
3) HUNH!
YesIHaveAHammer
My latest haul from Japan arrived. I'd been building it up for a while at Blackship's free storage.
I'll post it over the course of the week to avoid spamming the thread. Today - pliers.
Fujiya 50A-175 Angled Diagonal Cutting Pliers 175mm (7”)
This design is perhaps more often seen on smaller pliers. Looked interesting, not sure what I’ll use it for. Leverage ratio is relatively poor, glad I went for the largest version.
Keiba FCC-118 High Grade High Leverage side cutting [linesman] pliers 200mm (8”)
This has a brass bronze sleeved joint for smoothness. The grabbing area at the front has serration lines, whereas the standard leverage FCC-108 has cross hatching which I would prefer.
Merry JR60 Clip Pliers 155mm (6”)
These seem useful for more than just trim clips. Like a pliers version of human fingernails.
Merry HS175C Coupling Disconnect Pliers 190mm (8”)
While this was in transit from Japan, I snapped a locking tab on a sensor connector trying to remove it. These blue hard handles are pretty utilitarian.
Merry L60 Long Handle Bent Nose Pliers 200mm (8”)
These are for precision work, relatively light duty. I think someone put it as between a normal plier and a tweezer. Tips are smooth. There’s also straight (L50) and flat nose (L70) versions. I wasn't sure if they'd come with light blue, dark blue, or dark red grips.
Tsunoda EN-165S Thin Blade End Cutting Pliers 165mm (6.5”)
These are semi-flush, for cutting or getting under things
Beerhippie
Far NE Oregon
When it's "torque to yield", you're going to the far side of elastic deformation, so the torque does not go in a linear fashion up as the bolt stretches.
Or so I've been told.
Callelle
Depew NY
Make sure you mark your angles anyway. My 1/2" Icon always seems off and starts counting degrees the second you even look at it.
moemc
Torque-angle is one of the most precise methods for achieving a consistent target fastener preload/stretch. Because the thread pitch is known, the amount of axial fastener movement or stretch produced by a given angle of rotation can be accurately determined.
Direct measurement of fastener stretch is best, but usually not possible. The only place I see a lot of this in the real world is connecting rod cap fasteners, because you can easily mic over both ends. At any rate, torque-angle is the next best thing.
Turning torque # specs are not even directly measuring what you are trying to control when tightening fasteners (the amount of preload
or stretch). Turning torque cannot promise any amount of this because turning torque has to overcome variables that are not at all related to the preload or stretch. Friction is all over the place at every contacting surface between the fastener that is turning and the stationary part(s). So a turning torque number is just an indirect, roundabout way to get in the ballpark. And that is assuming you have adequate control over variables (mostly friction related). Think of molylube used for cylinder head stud nuts, this is used to equalize friction across all the nuts to try and even out the clamping load across all the studs.
When you are tightening a fastener, your goal is to achieve a particular amount of elastic stretch of that fastener (varies by fastener material and grade). Being in this elastic state is what keeps its clamping load during thermal cycles when things expand and contract a little, and keeps friction on the surfaces to stop it from backing out.
All this is why turning torque is used more casually, but torque-angle is a lot more typical for critical fasteners.
EDITED to add a little more detail since this comment was getting a lot of likes. I wanted to make sure it was more useful when people find it down the road.
LXCam
/me bows his head in shame
I um…well um…I’m not sure how to say this but
I bought these. I paid like $44 delivered. It um seemed like a good buy but I’d also just got done working 74hrs in five days and as much as it pains me to add….im fn old and wasn’t paying much attention
What did I buy, well I got a set of rainbow wrenches.
What are rainbow wrenches you ask…or not
Well the sizes are all colored in with all the colors under the rainbow.
They also have some feeble attempt at being a grip open end. If the notching were more consistent I’m almost tell you it was intentional. But I have my doubts
I will say the chrome is nice n shiny which adds a new dimension to the rainbow coloring.
They came in a nice box 😉
With high security packing. The screws were a wonderful touch
And now you too can gaze upon the glory that is a set of toolant rainbow wrenches
You’re welcome since I’m now saving all of you the embarrassment I must endure pulling these out some day on a project. 🥹
