Above 1200 Sq/FT My new garage build! 30x50 !
X
Xti04
This week has been wild already and its only Tuesday! Yesterday a girl dropped her car off for service and was waiting on her boyfriend to pick her up. He got there and a truck pulled in behind him. I was not home yet, so she calls and asks if I know the truck. I look and it looks like my wifes cousin truck. He stops by every now and then if hes out my way so I call and asked him if he was at my place. Its not him. Now my doorbell cam is going off and there is a huge guy on my porch. I got on the cam to talk to him and apparently he wanted to give me a heads up about this girls boyfriend who supposedly ran him off the road because he was on his phone. We talked for several minutes about it and I assured him I would address it because these kids are barely 18. If that boy had mouthed off to this beast of a man it would not have ended well and I didnt want to have to hose blood off my driveway. 😅 i called the girl back explained the situation and the truck finally left and they were able to get out of the driveway. They were both very apologetic for bringing this kind of drama to my house and for me having to deal with it. Luckily I have had plenty of deescalation training over my nursing career and was able to talk the guy down and keep it respectful and cordial. What a mess though!
Up next was a massive F 350 dually. Had a seized rear caliper , but due to the giant service bed and tools in the truck I was not willing to put it on my lift. We did the job out in the driveway due to size of the truck. @madison069 I got to use my new brake line clamp which worked great. No dripping brake fluid on the driveway. The rear rotor is captured, so it required a trip to get the proper 4wd socket, and then seals which I had ordered already. Having never done one of these on a Dana 300 rear axle, it was a chore just due to weight and location. I try to avoid heavy work like this, but I also charge a premium for this kind of work. We got it back together, all torqued to spec and endplay checked. No pics as it was a greasy nasty mess with lots of gear oil and grease everywhere. The rest of the week is some small jobs that need completed before we leave for vacation on Saturday. Hoping to clear all these jobs off the list and be ready for a camper install when I return!
zmotorsports
Northern Utah
I had bid a job on a 2500HD GM years ago, a transfer case leak, and I suspected immediately based on the owner's description that it was caused by the infamous "pump rub". When the truck arrived it was also on a work truck weighing well over what my 10k pound lift would handle. I thought "damnit", I hate working on a creeper as the lift really spoils a person. When I crawled under it, I ALSO discovered he had a 52-gallon Titan fuel tank which made transfer case removal even more fun. :rolleyes: I now make sure to inspect the vehicles before offering up quotes and refuse to give estimates over the phone. Plus, after that job I also learned that I needed to steer away from flat rate quotes and just work by charging time and materials. That one job was an educational one for me. :LOL:
X
Xti04
Luckily I accepted this job as a no quote as he needed it back asap. I was able to charge my increased rate plus I added in the tool I had to stop and purchase and still made out well on it. I have been trying hard not to accept any work without loooking it over to keep from screwing myself over. Most vehicles have been thru my shop before so I know their general condition well enough to not get myself in trouble.
X
Xti04
Apparently its truck month here at my shop. Now thru the end of July you can stop in and stress me out with your big heavy diesel truck and its wonky issues. Last night we pulled in an F 250 with a " brake vibration" this thing is so violent, its like a death wobble but only when braking at high speed. I dont doubt there is some brake pulsation/ vibration, but the shake coming from the truck is awful. We replaced all the steering components on this truck a few months ago except the track bar. The track bar bushing has now developed a tear in it so I am going to retorque all steering fasteners and replace this bushing and see how it does. My reading on this condition yesterday also mentioned caster if all steering and suspension parts check out. Hes not in a rush but I wanna get it figured out or its going to haunt me all next week.
SilverJimmy
Prescott/Flagstaff, AZ
You might want to check the front rotors for uneven hardness and/or glazing. I had one of my tool trucks that I swore the front suspension and tires were fubar’d cuz it would shake so badly at times that it was almost an accident about to happen. Balanced the tires multiple times, replaced shocks and checked alignment, still shook like a wet dog!
Finally out of desperation I replaced the front rotors (which I had checked with a dial indicator, perfectly round and not warped!) and miraculously the truck drove like brand new! In hind site we realized that my employee had to panic brake when a huge herd of elk had run out in front of him one night coming home from the Grand Canyon. He had to stand that truck on its nose to not hit any of the 100 elk that ran in front of him.
That panic stop must have put so much heat into the rotors that they would slip and then grab while braking that it almost ripped the steering wheel out of your hands….. Death Wobble from Hell!
New rotors and pads, fixed! YRMV!!!
X
Xti04
We replaced the track bar bushing that was separating tonight and retorqued all the steering we had replaced previously. The bushing had to be done on the press but I had gone around it and tried to loosen it a bit 20260729_190024.jpgbut I didnt quite have a driver to push this out. I had to use a socket to get it out which worked well, but that ATM bearing driver set @zmotorsports keeps suckering people into buying here might have just gotten bumped up the list. It did not fix the shake and pull unfortunately. I ran out of time tonight to get it figured it out, but will try and dig into it some more tomorrow.
madison069
Monroeville, PA
I had the death wobble on my f250 and I changed the steering stabilizer and front shocks with Bilstein, the original stabiler was toasted. No more death wobble since I did that. But it didn’t need the brakes start the wobble so it could be a different issues. Just something to check into.
M.Brane
1 hr N/W of LA LA Land
It's not much more $ to replace the whole bar. Saves enough labor to make it worth it IMHO.
Owning an OBS Ford truck taught me to avoid cheap pads/rotors, and use the parking brake. If you don't the rears fall out of adjustment so then your only using the fronts, and they will glaze/warp from the added heat rapidly especially if they're cheapies.
X
Xti04
Normally I would have gone that route, but being unsure that the bushing was the solution I opted to just press a new bushing in since a bushing was under 10 dollars.
zmotorsports
Northern Utah
Not much to add as it looks like you are doing your due diligence with the investigation.
Two things I've found to exhibit "almost" death wobble symptoms are ball joints and/or wheel bearings beginning to fail with play which can cause a rhythmic braking pulse which then turns into a steering wheel shake when braking. Usually this can also be felt in brake pedal pulsation, but not always as evident as the steering wheel dance. Again, not as violent as full blown death wobble, but enough to be intolerable by the driver. Not sure if that's it or not, but thought I'd throw that out there as I have had a few of these over the years result in similar conditions to what you've described.
X
Xti04
We have brakes on hand in case thats the issue, but will also check wheel bearings tonight before replacing the brakes. Its not a full blown death wobble, but man it will pucker your **** when it happens. Customer wanted to try brakes and see if we had any improvement.
X
Xti04
Brakes ended up being the culprit, bearings were tight, steering good even temps on brakes side to side, but I could not believe how bad this thing shook and pulled when braking. After replacing pads and rotors, brakes were smooth and no pull. Truck picked up this morning and my vacation can officially start. Of course,as I prepare to leave town my tracking on the truck topper shows delivery driver has been dispatched to pick it up. Nothing I can do about it until I get back though.
X
Xti04
We made it to Florida uneventfully, which was great! Our flight had some crappy weather to go thru, but still arrived early. I had booked a rental car thru my work corporate account and had just picked a compact car. I should have read a bit better as to what qualifies as a compact car. I expected a Nissan sentra or corolla, but apparently those are now considered mid size cars. We got this
This lil hood rat Mitsubishi mirage. No hubcaps, no power, hell the engine is missing a whole cylinder. I might as well be driving my Kei truck with a family of 4 in it. We hit the interstate and I had the pedal matted trying to get up to speed. I dont think I will go small again. This thing is darty and was really sketchy with cross wimd as we got on a toll bridge across Tampa bay. We made it to our house finally and it is awesome. Looking forward to a week of relaxing, but I also have a couple of small projects to knock out for the owner. I got up bright and early to start them and was greeted by this20260802_075434.jpg
It was absolutely pouring when I got up. No coffee and nothing to do but watch it rain, so I decided to knock out some projects for the owner. I had her buy a tool kit and send it here so I opened it up and started my first project. 20260802_083728.jpg
This is an end table/ lamp that matches one she already had. I tore into it and in about 10 minutes I was done and bored again. By this time my youngest was up and the rain had slowed so we got out to explore. Anna Maria island is a predominantly golf cart style island so we set out on foot. We made it to the beach, and then back across the island to the bay side. Stopped for a double espresso coffee and some Philipino lumpia for the wife and headed back home. We spied a few good fishing spots along the way, and after breakfast hit the pool and the big project for the week. 20260802_083734.jpg20260802_113837.jpg
The fancy ploywood table broke down under the Florida heat and she had a warranty replacement sent out. We assembled the new one amd it went well until we found the instructions were backward and the wrong screws went into the feet. 20260802_115918.jpg
They popped out immediately when we flipped it over, so I had my older son pull the screws from the old tables feet. 20260802_115915.jpgabout 3/4 of an inch longer and with solid grip into the legs, we got it together and back upright right as it began to rain again. Wondering if stormy skies are gonna be the theme of the week.
OutlawDrifter
KS
When we have to do rental cars now, I've switched to Turo. Generally much cheaper and you know exactly what you're renting.
Enjoy your vacation!
X
Xti04
After working on my buddies 20 plus Turo cars I am not sure I would feel comfortable in a turo car. I have seen and smelled how they get returned and have no interest in a contact high from a rental car. Watching it rain and makong plans for a visit to the tackle shop to restring the rods here at the house. My son is gonna drive me mad if he doesnt get to fish soon.
Chrisb62
southwest fl
Probably …
This is the stormy time of the year for Florida, but on a higher note , no Hurricanes this week
Been a resident for 40ish years and a hour south of where you are staying…an hour south if you had a helicopter maybe 3 hours driving during the day.
:beer:
X
Xti04
@Chrisb62 Yeah we wanted to come back in June but I couldn't work it out. Explained to the kids how rain is a part of life on the coast, but when it cuts into their plans they dont like it. If I had brought my helicopter instead of this mirage I would blast down there for a beer with ya!
Put the grill to use tonight, hoping to slap some fresh caught fish on it this week!
X
Xti04
Down at the store I’m sure they sell “Fresh Caught” fish! 😂
I admire you when you’re able to fish in the ocean, I’m not really willing to try doing that when something I might drag outta the sea could kill me!
We have options here Sterling! Im 500 feet from a canal, 1 tenth of a mile from the bay side and 8 tenths from the gulf side. Im hoping for redfish or sheepshead, snapper and worst case theres a seafood shop about a mile from here !
kj_mustang
Harrisonburg, VA
Anna Maria Island is great. Spent a week there in the summer before Hurricane Milton. The hurricane took out some of the piers and restaurants. North Shore Cafe is great for lunch.
X
Xti04
Im like a 5 minute walk from North shore cafe. Its had a line around the building every morning so far so its been hard to get in there.
X
Xti04
Took my youngest son fishing yesterday and today, he got skunked yesterday, bit finally got into some snapper with the help of a local guy today. He gave us an aberdeen hook and 2 split shot, the same rig we use at home to catch bluegill and he landed 2 mangrove snappers in 5 minutes after switching. 20260804_133855.jpg20260804_135209.jpg
He was very proud of his bigger catch, and had to bring it home to show mom. I attempted to get my older son to come fish with us and hes not interested, I even offered to take him out on a charter boat and he said no. Feel like I should just book it and let him hook something good. Trying to toe the line between an overbearing dad and taking him out to have fun with me.
ptt49er
Rock Hill, SC
Book it. I drug my two out chasing reds with a guide just an hour after our youngest had 6 stitches put in his foot from stepping on an oyster shell (he still wanted to go, didn't force him). Thankfully the numbing didn't wear off for a few hours and we got on a school,it was a blast. It's been 3 years and they still talk about it.
X
Xti04
I was up way too early for vacation, so I ran down the street and grabbed a coffee and started on this mornings project. 20260805_072516.jpg
Penn model 60 reel. No idea how old this one is, but its gritty and nasty and has line wrapped up inside the reel. 20260805_072631.jpgafter pulling the cover and drum I found this mess. Sand, grease and fishing line tangled in the gears. I wasnt expecting to be able to get this thing apart, but pleasantly surprised nothing was seized I soldiered on. 20260805_072709.jpg
I have no brake clean or anything to clean with other than paper towels and a small screwdriver to try and get into the tight spots. I got the whole reel down to nothing 20260805_080733.jpg
Removed as much sandy grease as I could get out of all the crevices, gave all the parts and gears a good wipedown and slowly began to reassemble it all. I had one small spring that made me have to stop and look up the reel diagram to ensure I got it back in the right place, but otherwise it went back together pretty easily. With it all cleaned up, I went on a test fish. 20260805_084304.jpgLots of bites this morning but nothing came home for lunch. Its much better than it was, and I can feel better about the next time the owner gets to use it.
X
Xti04
Time off is exhausting. Im so beat from not working and travel that it makes me wonder if its worth it. Thursday we had some nasty weather blow in on us while we were beachin it up.20260806_153240.jpg I grabbed our stuff and we took off for the house. I made it there despite some crazy winds that had kicked up and even knocked over some trees right next to our place 20260806_153847.jpg
That one landed on a house about 4 houses down from where we were staying. It started raining shortly thereafter and continued the rest of the day until about 11pm 20260806_155838.jpg
I just grabbed a beach chair and sat in the carport with a beer enjoying the wind and splash of rain.
Friday I dug into my final project in this house which was assembling these 2 drawer units for the closet. This house got hit back to back by Helene and Milton and was gutted 2 years ago. Closets were the last thing on the list to get repaired so I put this stuff together for them. 20260806_204234.jpg
Only thing that sucked was not having my snap on drill driver to speed up all the screws that go into this unit.
Saturday morning we headed out and got to airport and checked in. As we were checking in I got an alert our flight was delayed. Damn. We hung around since the rental eas turned back in and then got pushed again to 7pm. The first flight back to Knoxville had gotten delayed from Friday night and by the time it was boarding had a lot of empty seats. I tried to get us bumped up to that flught but wasnt able to. We finally took off and like a child who has never flown, I snapped a few pics from my seat 20260808_184956.jpgcoast guard plane at the hangar
And just the absolute beauty of the sun reflecting off the gulf. We finally got home around 915 last night exhausted and hungry...... and then I got my welcome home presents! I opened the fridge door and water slung everywhere from the icemaker in the door. I looked at the floor and it looks like it may have been leaking while I was gone. I cleaned that up and checked the icemaker. I found all the ice had frozen together which along with the internet being offline tells me my power probably was out for awhile. I then opened my pantry door and noticed another puddle on the floor. A bottle of oil had been put on its side and some leaked past the lid. So after all the cleaned up leaks, and a quick dinner of pizza rolls and queso I called it a night and enjoyed being back home in my bed.
This upcoming week is busy, I have several scheduled for work since I was out, the truck has been dropped off to get the windows tinted, and best of all my camper setup has arrived! It showed up on Friday so I have to make my way over to my buddies dealership to get it after I pick up my truck tomorrow. I cant wait to get this truck setup!
pima67
Tucson, AZ
Some years ago in the evening I heard water rushing and looked at the fridge. Water was pouring out of the water/ice opening because the fill valve stuck open. Since then if leaving for more than a few hours I shut the house water off.
Another reason for shutting off the water. Some months ago I notices a bit of water in front of the fridge. Pulled it out and the water supply line was leaking a bit where a clamp held it on the fridge about half way up. Took almost 20 years for that to happen. Anyway I removed the clamp, cut a small bit of the line out and joined back together with a brass coupling/union (couldn't find one in plastic). The supply line maternal is very thick and tough.
X
Xti04
It has been on my mind so today I pulled the icemaker apart and found it needed defrosted behind the icemaker. I hit that with a heat gun and hopefully that has cleared out enough to help the icemaker get back working again.
SilverJimmy
Is the offending fridge a Samsung? If it is just go ahead and take it to the dump! That company should stick to making TV’s! Just my opinion, and like a belly button and that other thing, everyone has one!
X
Xti04
Nope. Its a frigidaire. I bought it a year before we built the house and its been great for the last 10 years of abuse by my wife and kids. I like Samsung products but their tvs are the worst. Both of mine have burned out ethernet ports in them within a year. One is now the shop tv and the other got stuck upstairs.
SilverJimmy
So, I’ve been lucky so far with their TV’s?! I know 3 people who have been burned by their fridges, local appliance repair hangs up on you when you say your broke fridge is a Samsung. My neighbor just had a less than 1 year old Samsung fridge die and after about a couple of weeks of going back and forth with their warranty department he got a check in the mail refunding his purchase price. Its really sad, in 1984 I bought a Kenmore fridge when I bought my first house, it died in 2016! That was when I discovered the joys of Samsung!
cccoltsicehockey
Charlotte, NC
Bummer about the travel delays and the weather at the end of the trip. Can't wait to see the camper top project get underway soon. I bet you are really excited to get that on the truck after the wait for it.
X
Xti04
I cant wait to pick up the camper! I have to grab my truck from window tint this morning, and finally got with my buddy about picking up the power unit for my midrise lift, so I will have a full truck bed when I return home tonight. I have made some space in front of the pontoon where I can assemble the topper and prep it for installation on the truck.
pima67
Tucson, AZ
The fridge mentioned above is a Kenmore/Fridgeaire. I have had to replace the ice maker, a thermometer in the freezer and one in the fridge section. In the very beginning we required a warranty visit.
Now every once in a while the ice maker gets confused so the little fingers that eject the ice get caught in frozen ice. Have to remove it and let it thaw out and dump he resulting water.
X
Xti04
I picked up the truck, tint job looks great, and mad I didnt do it years ago. Got the power unit for the lift and made the last stop to grab the topper. Forklift wasnt getting it into my truck so we grabbed the big service truck and used the crane on it to load them! Wish I had gotten a pic of it going in. Double wish I had them when I got home. 20260810_182003.jpgJeff and I got it out and onto the new midrise lift. Then we broke open the smaller of the two crates and unloaded it.20260810_192248.jpgI cant assemble it until I get the larger crate out. Engine hoist and lift will most likely be required to get it out of there. That is looking like a tomorrow project.
madison069
Monroeville, PA
I was going to say, how were you going to get those crates out of the bed?
Those kinds of moments are when I'm happy to have the car hauler trailer!
Glad the vacation was enjoyable, but your house was jealous that you were enjoying another home and just had to express her dissatisfaction.
X
Xti04
I wish I had put them on my trailer but its too small. I went to option 2 and called the guy who loaded them last night. He is swinging by with his service truck and is going to use his crane to lift the big crate out. It tipped over last night and damn near crunched my buddy Jeff in the back of the truck. There is a Subaru on the lift and even if it was out of the way, Im not real comfortable with moving it using the lift after last nights fiasco.
fouckhest
Greer, SC
Looking forward to seeing the topper come together. Are you going to get the bed wrapped before you start building/installing it?
Blackbyrd
TN
Wasted no time getting back at it huh haha
Ive got a samsung fridge and im getting ready to replace most of the icemaker.... the auger quit responding to the dispensing lever, and a month later it quit making ice all together.
