Best way to make a rough concrete floor smooth
Zaffer
Radiant, VA
I have an existing garage floor that has a brushed finish on it and I was wondering what I can do to make it smooth. It looks like when the floor was poured, they used a push broom to finish it for a rough/textured surface. While I like the floor if it gets wet, it would be nice to have a smooth floor for working on my vehicles and using the jack/creeper more easily. I’ve read some on renting a grinder for prepping a floor to coat, but would this work to smooth it? I realize I’m not going to get a polished surface, but would like a smooth(er) surface.
Concrete was poured in 1994 and unsure how thick it is.
Any advice would be great!
Wasn’t sure if I should post here or in the flooring section.
Nobody-named-Olli
Easiest & least mess: self-leveling compound.
Apply primer with brush, then pour the self-leveling compound.
Grinding is obviously possible, but if not done with the right setup/tools - it’s one big mess and never going to be anything close to level. You either want a dry setup with dust extraction or do it wet.
No matter what you decide to do, you want the garage/ floor space empty.
Kind regards,
Olli
Z
Zaffer
Radiant, VA
I’m not expecting it to be perfectly smooth and it’s not perfectly level, either. My concern with self-leveling is I’d be afraid it wouldn’t hold up, but I have VERY limited experience with it.
The space is 12’x22’ as the other half of the garage is keep rough for now as that will be my main engine rebuild/parts cleaning area for a little bit. I’ve never used a grinder before, but always willing to learn. How similar is it to a floor sander? I’ve used a concrete polisher before, but that was 28 years ago😂
jack stand
Lakes Region Maine
Having a concrete grinding service give you a ballpark price would be a big part of my decision on how to proceed.
Explain your desired results for your 12'x22' broom finished slab.
You don't seem super picky (4 letter word to contractors) about being re contoured and made level, just knock off the majority of the broom texture.
You can't "un grind" this if you try this yourself. The grinder doesn't care if you're experienced or not.😉
I've learned by watching the other trades on the job for decades, that even the simplest of jobs are made to look simple by someone with some experience. 👍
JuncleJohn
Omaha, Nebraska
I couldn’t imagine laying on that floor while working under a vehicle. Not to mention how much better a smooth floor will be to sweep clean.
I suggest grinding the entire floor.
John
Z
Zaffer
Radiant, VA
Jack stand,
I mainly want it smoother so things will roll more smoothly across the floor. I usually use at least cardboard to lay on while under a car, so me laying on it is not as much of an issue, however sliding under a car quickly isn’t happening😂.
I just wasn’t sure if a grinder would knock it smooth, but I don’t mind learning on the “job”🤔
marak
Anchorage, Alaska
What about a product like Mapei Planipatch? I found it to be a pleasure to work with and have had great results with it for leveling out a basement floor that is used as a woodworking shop. I epoxied it afterwards and even with metal casters under the cabinet saw there are no signs of wear.
Mikes61
The guy that just polyurea coated my 960 sq ft garage floor used one of those floor cleaners with carbide sanding bits in it before he painted. He was done smoothing the floor in an hour.
The floor cleaner looked like what they use in the supermarket late at night to polish the linoleum floors.
drmarkr
Tucson
That makes me think of the “clinker” tiles we had at the BMW dealership. Not a bad idea, actually…..
Properly installed, harder than cement. And buddy.....there is NOTHING nicer than lying down to work on your vehicles on tile!!
Hank11
Tennessee
I don’t think a scotch bright pad is going to cut that concrete smooth
I have not tried it, but I will this fall when the heat breaks. I asked my concrete floor finish guy about what I wanted, which is to knock off the coarsest part of a broom finished porch before applying a sealer. After we talked about it a bit, that was his answer. It won’t make it smooth like grinding, but it will take lots of the roughness down. Think about brand new rough sandpaper compared to worn out sandpaper. This comes from a guy who makes his living grinding and finishing concrete.
CMB41
california
Grind it. Costco grinds their floors to an 800 grit finish out here In CA. I hired the actual guy who does the Costcos. Great experience and result. That was 10 yrs ago at $3.00 a sqft “friends and family“ pricing. Two guys to do 1800 ft in 2 days. No idea what it costs now. Would 100% do it again. YMMV
Z
Zaffer
Radiant, VA
The more I think about tiling, the more I like the idea. It’s something I can do myself (I’ve tiled plenty of floors in the past) plus I can decide on color/pattern.
I appreciate all of the advice so far. It probably won’t happen this year due to everything else I have going on, but definitely good things to think about. I guess I could also do a heated tile floor…..
