Between 265 & 485 SQ/FT Basement Bike Cave and 3D Printing Workspace
K
kppolich
Eastern Iowa
Wired ethernet to the garage. A few drops of sweat were spilled this afternoon but overall a pretty simple job.
1.) find the wall chaise to the basement.
2.) Stick a 15 ft fish stick down there where you see light
3.) Pull it back up and cut the end leaving some slack in case you need to re-do anything.
4.) Re-do something
5.) Fix it -- yep I guessed right that I messed up the first RJ45 near the switch.
6.) Tidy Up things
7.) Voila
K
kppolich
Eastern Iowa
June house update, time for some tree's in the backyard. 7 Mountbatten Juniper's are what the wife liked, and we were in and out of the nursery in less than 30 minutes a week ago with an appointment to have them planted this week. Previously, we had some small dogwoods that didn't grow well at all in the area, hoping these more mature evergreens flourish for years to come.
2 young lads came and took care of business, planting the 7 trees in just under 90 minutes. Well worth the extra coin to not be out there myself arguing with the wife. Plus, if they install them the warranty on the tree is much better. 7 tree's 9.5ft apart as they will eventually be 12/15ft tall and 6/8ft wide.
All I had to do was put some flags in the ground where we wanted them to be planted and they took care of the rest. I helped them out by snapping a line with mason's string as well.
Installed
Then I put the Timemaster to work and cleaned the lawn up before firing up the Recteq and making a little Old Fashioned with some Blue Run Rye to ease the pain dropping 2 grand on some trees. Is this what getting old feels like?
K
kppolich
Eastern Iowa
Tree's are in and doing good, but I want more control over watering them. Slower watering mostly and being able to water them all at once.
Irrigation Project queue'ing up!
-Had to get 100ft of main line, but I'll only use ~65 ft.
-Had to get 10 of the 2 gallon per hour flags, but I'll only use 7 of them.
I think I'll dig a shallow trench and bury the main line ~3 or 4 inches under the ground and have it run 4 to 5 inches away from the trunk while coming up out of the mulch then going back down between trees.
I'll probably do something to hide where the hose will connect, so I can just hook it up 3 days a week and set a 2 to 3 hour timer.
Xti04
I did drip irrigation for my trees when they were all new. Helped get them established. I had bought distressed trees and between watering, holly tone and mulch they came out pretty well.
K
kppolich
Eastern Iowa
Well it finally rained here which helped soften the ground a bit. I then soaked the area a bit to help myself out digging the small trench for the 5/8 poly pipe. I still think I need a regulator, but its in and working great as far as I can tell.
Hose female end
Laying the pipe out over the fresh trench. I then used the small hand shovel to widen things out as needed.
Poly in trench, then I stitched the two sides back to gather to cover things up and gave it a good soak too. I expect some damage here short term, but I'm OK with that.
Poly pipe coming up to the surface, I parted the mulch and got it running by the tree stem/trunk then packed down the mulch/dirt around it.
Voila - 2 gallons per hour right where I want it.
K
kppolich
Eastern Iowa
Back to the 3D printing space today after work. I had a buddy wanting to use his Apple Watch as a cycling computer when pedaling around town and his wrist wasn't going to cut it.
I found a model or two, remixed them both to work with his Garmin out front mount vs the Wahoo mount it was originally designed for.
Both versions are---OK. One you have to screw together, the other is nicer and 1 piece but its a PITA to get that watch out of there which I guess isn't a bad thing.
Wahoo Original 44mm
Garmin Version for 44mm
I also remixed it to account for 46mm Apple Watches vs the 44mm.
Screw together Version, 44mm, Garmin
K
kppolich
Eastern Iowa
I got absolutely poured on last night, so let's share some pics and the process I use for re-waxing a Silca waxed chain. Usually get around 200-250 miles or so out of each chain and have 2 chains that I rotate on my road bike.
The process goes from left to right in this instance due to about 20 mins of road grime/down pour, etc
Chain gets wiped down with some degreaser on a microfiber to get the big stuff through the then goes into near boiling ultrasonic for 10mins or so to get the rest.
Chain is removed, wiped down with isopropyl using a different microfiber from our friends at Harbor Freight and then gets ready for wax. Menwhile, I removed the cassette and dropped it in the ultrasonic as it was still hot and ready.
Chain goes in at 125, swished around for a bit, sits for 5 mins, then I drop the temp to 100 for another 10 mins or so before dropping it to 75 and I remove it when the temp reaches 75 then I let it sit and drip dry for 15 mins or so.
Then I run it thought my 3D printed wax breaker pulley thing for a minute or two then reinstall it on the bike.
boyboi
MPLS
Are you doing the ultrasonic clean on the chain every time, or just when things are in particularly bad shape? which model do you have and do you think a mtb cassette could fit in it? looks like your red cassette might be maxing out the basket.
Are you racing core 4 this weekend? I am registered, but it looks like you're getting 5 days straight of rain so i might bail.
K
kppolich
Eastern Iowa
I only use the ultrasonic if the chain is in bad/shape/rained on.
Otherwise a dip in boiling water to melt off the old wax and wipe down with isopropyl does the trick for me.
The model I have is pretty small (JX-010S) ~2 Liter
Yeah, biggest cassette that goes in is my 10-28 usually but my 10-30 that is on the kickr also fits.
Otherwise I can fit the XPLR (10-44) stuff in sideways and flip it every 5 mins. I like the small form factor but a little larger like 4L wouldn't hurt as those usually have a drain on them as well.
K
kppolich
Eastern Iowa
Tonight I did some scientific beer pouring and in turn, beer drinking.
Its been little warm in the garage, 80-85 according to the smart thermostat out there and well, the first pour is always a little foamy and I suspected the temp in the tower was high as its an older model that doesn't have a fancy 'tower chiller'
So I started by measuring the tower temp, tap temp, and first pour beer temp.
Then I poured myself a second beer and measured all 3 again.
I have a tower cooler coming later this week. Basically a fan that lives inside the refrigerator cabinet and has a hose on it that you put into the tower so it helps pull cold air from down low up into the tower.
Also, pictured below is a neoprene tower cover. Insulation and such which I'll be installing as well. To do that, I need to remove the tap itself, which involves disconnecting the keg for a minute or two and thus, leaving the door open.
I started tonight with the baseline tests.
Beer pour #1 Beer itself came out at 50F, tower temp was 80F, after the pour, and Tap Temp was 60F after the pour.
Beer pour #2 Beer itself came out at a crisper 44F, tower temp was still 80F, and the Tap Temp dropped to 53F.
I'll likely need to drop the thermostat temp a bit to get the beer a little colder as it should be pouring around 40-42F for this Mango Cart, otherwise no suprises here -- the first pour is a little foamy usually and the second is much better, third is perfect as the temps keep dropping.
I did leave a glass of water inside of the cabinet itself to get to temp and will grab a reading on that before bed this evening.
Cheers!
K
kppolich
Eastern Iowa
A little 3D printer tool organization today as I ease into a rainy midwest weekend.
I added room in the existing single panel HWS system and added in my titanium tweezers next to the be burring tool and re-designed a quick action blade to hang above the scraper.
Overall, really happy with the minimalist look and feel and the most commonly used print clean up tools are there.
Now to find a place for my small Pick-Set that is easy to access and less easy to poke myself when grabbing at..
Welp, literally seconds later I found this HWS pliers holder that did the job for pick duty.
K
kppolich
Eastern Iowa
Operation Cold Beer underway.
Installed the power cord, had to splice the end back on due to tight clearance under the compressor entering the cabinet.
Cooling hose run up into the tower and secured with a few zip ties.
Cold air fan tucked back by the coldest part of the fridge to draw nice cool air up into the tower.
Back together and installed the neoprene tower sleeve as well.
Will let things cool back down since I had the door open for 20 mins or so and the keg sitting in the 80 degree garage then do some more 'testing' later tonight.
K
kppolich
Eastern Iowa
Decided to swap out the 1 gang for a 2 gang and add some HomeKit smart home ability this afternoon to ye old kegerator cooler.
Now I can set up some routines and such to make sure the tower runs when I need it and stays off when I don't.
Before that I hit some eastern iowa gravel and saw a lady who rear-ended a Ferrari today around 10:30 am at a wide open stop light/intersection about 100 ft before the light. Mind you this is Eastern Iowa. The folks behind me and I had a good chuckle at the light about the whole situation.
Wish I had a better pic, but it was pretty comical-- I can only imagine the insurance guy on the phone -"YOU HIT WHAT!?"
Then I broke my first chain at the quick link, 5 minutes later I was up and running with a new link installed.
K
kppolich
Eastern Iowa
Garage update -- I've always wanted a larger workbench area, and maybe a TV out there since its heated, kegerator, etc.
Currently, I have the (3) 36" Gladiator locker/cabinets on the back wall of our extra 3rd+ stall with a smaller 40" workbench top on the side where my air compressor is currently living.
However, I've decided I'll put a 6 ft workbench in the middle, sell the middle 36" locker and picked up (2) of the 28" wall cabinet uppers next to them.
The wall lockers would be wall mounted as well and actually be mounted up off the ground on the 4" curb that is there.
I'll be mounting them directly to the wall, and not using the gladiator rails.
I'll then put a 6ft x 18" husky stainless workbench top and pick up a cheaper LG 75" TV when Black Friday comes around.
The workbench top comes with L brackets that I'll make work with my Gladiator cabinets. I'll likely put an additional L angle on the back wall to support things.
The Milwaukee m18 vac and air compressor will then move under the workbench top.
I'll also need to run a few outlets. 1 for the TV and then one under the workbench since there isn't a pass through hole.
Mocked up like this with room for my existing lawn mower and slow blowers along the side.
Current Setup:
moab11
Thunder Bay, Ontario
Looks good, I just question hanging the workbench from the cabinets as there isn't a lot of structure in the sides of them, especially if you are also hanging them on the wall with only the back feet on the foundation curb.
Having an outlet above the workbench will be valuable as well if you are already running new outlets in that section.
K
kppolich
Eastern Iowa
Yeah, I have some 90 degree L angle to make some strong support along the back wall as well tied into the studs. The same L angle goes into the locker sides and attaches to the bottom of the workbench top.
Looks like the larger stuff can be wall mounted like so using some slat wall brackets that are bolted to the back of the lockers.
I'll be using some structural NGK screws and finding 2 studs top and bottom on each cabinet as well as the majority of the weight resting on the concrete curb.
moab11
I have some of the larger cabinets hung like you are wanting, but I used the brackets and hung them on the gear wall panels similar to the pic you posted. I also have the back feet on the lip of the block wall. So a very similar setup to what you are wanting to do.
I like the way the brackets spread the load across the back panels, and still used a few large screws into studs at the top. I do have a good bit of weight in a few of them and they have held up great for a decade now. Just all depends on your use case if you will be doing much heavier work on the bench and/or storing heavy items in the cabinets.
K
kppolich
Eastern Iowa
A step in the right direction with both wall upper cabinets assembled.
I also picked up some heavier duty brackets to support the 18" deep workbench top.
Peace of mind for less than $20
Top should be ready for pickup tomrorow/sunday and I'll start moving things around after that.
K
kppolich
Eastern Iowa
Garage Update---
TV ordered, mount ordered, Apple TV acquired, workbench top should be here Thursday.
In the meantime I'll fish the 12/2 through for the new outlet for the TV and put in an old work box.
3D printing & bike update----
Sonos Roam holder that is shaped like a purist bottle so my wife can take it along when she needs to.
2 different versions here:
https://makerworld.com/en/models/33...-bottle-adapter-for-cycling#profileId-3750425
