Working with an old wonky building made from fieldstone
JunkBuilt
Hi all, long time lurker here. I've recently purchased a rural property in the UK which has an old fieldstone barn with a slate roof. It's much bigger than my previous 2 car attached 1970s garage, but I'm finding it a bit of a challenge to lay things out in the new space. The main issue is that its got solid field (cobble) stone walls which are really irregular, and the barn itself doesn't have a straight wall. My benches and workshop kit that used to fit neatly along the brick walls of my old shop, now don't really fit anywhere properly, and the walls are so uneven that hanging cabinets isn't really possible directly to the walls. I'd be interested to know if anyone else had a similar building and see what they've achieved.
There's an added challenge at the moment which is damp, but I'm working on improving that by clearing around the exterior and adding some drainage/excavating a slope away from the building.
Thanks
Jim
finn
The UP, God's country
Martijn Doolaard is a Dutch guy restoring a couple of stone buildings, well, really better described as huts, in the Italian Alps.
He’s got a long running YouTube channel that might give you some ideas.
tremiso220
Had the same issue with a stone outbuilding. Gave up trying to mount stuff flush on the walls, just built a freestanding bench a few inches off them, way less hassle and helps with airflow too. For tools, a rolling chest beats wall cabinets when the walls are that uneven. Good you're sorting the damp first though, that's the real priority before anything else goes in.
Stuart in MN
Minneapolis
I haven't watched him in a while, but it's a worthwhile channel if nothing else but the breathtaking view from his property. The buildings are unusual with their stone roofs.
Uncle murph
Harford county
Thanks
Jim
I have the same thing.One wall is compl below grade and it was the wonkiest.wettest of them all, I formed up in front of it and filled it with concrete.Much drier,flatter and plumb.
finn
From what I recall, that’s what Martijn did on the lower part of his cottage.
he installed a drainage system inside, and rustic gutters to keep water away.
