4 Barrel barn build.
W
Woodboxkiwi
After yesterday's debacle I was happy to get the high wall fabricated on the deck.IMG20260826164202.jpg
I braced it up temporarily to move it into position.
I then set about standing it up against the existing wall with a chain hoist.
I added more bracing to hold it upright while moving it into its final position.
I pulled it sideways with a load strap and a bit of good old leverage.
In position ready for the top and bottom plate extensions to tie it all in, along with a couple of permanent braces at the top back onto the other walls.
Another pile of sticks closer to the finish line!
W
Woodboxkiwi
It was a funny old day today, equinox weather is kicking in. Every time I headed out to get something done a rain squall would blow through and get everything wet and cold.
I did manage to get the diagonal strap bracing onto the high wall that I finished framing last week.
The rest of the day was spent writing a list of and doing sketches of all the flashings that we will be needing soon, also doing some research on dimensions for the roller doors. I will be framing up the walls that the doors hang off next, so better be sure of sizings before we start chopping up lengths of timber.
I also made contact with the guy that will be manufacturing the continuous spouting for us. He will be here later in the week. I figured that I would rather have the spouting made and sitting around until I need it, rather than have water running all over the ground making a big muddy puddle.
