I’m a Commercial Contractor I service a wide range of clients
so I keep a little bit of everything in my truck tool wise
hardware I keep in Husky tupperware - small parts / screw boxes
I use a rubber made 3 shelf 4 wheel cart to haul in tools and gear - This is harder w/ a residual type work as houses aren’t cart friendly
pack out style storage pro/ cons
I tried to like the pack out gear - Great Ideas for storage
although
the problem is when traveling do you just leave it in the bed of the truck run a chain thru $1,000’s in tools
or running into Depot - Prime Target for Theft or placing inside the cab = more moving them around
what about rain or bad weather …
then
lifting everything in and out of the truck bed all day - ***** !
my advice
buy a commercial truck or Van and set it up use only as a WORK truck/van don’t drive it every day unless working = Money Maker
alarm it
battery kill & vibration / tampering
tint windows
get Good locks ETC for security
set em up for what ever type of work you plan to do !
I bought a hunk of new commercial grade carpet and lined the bottom of all my truck boxes
my truck is a 2005 Chevy 2500 HD extra cab w/ 8ft contractor body 268,000 miles 3 transmissions & 1 motor later it’s still making money - looks Clean and drives Great
small parts screw boxes
Example of truck or van look professional and once set up they are work horses
The truck is similar to mine
although
then
my advice
alarm it
tint windows
