Please school me on swivel rivets
Wamsutta
Amarillo, Texas
There's this mailbox I told a lady I would fix for her. The little door that you lift up to insert your mail has had one rivet come out on the right side, so now the door hangs from the rivet on the left side. The left side rivet is on its way out too. These are those hollow pop rivets we've seen on stuff like drill index boxes that allow the lid to open and close. I need a source for the rivets and the install tool.
The mailbox sheet metal is real thin like 20 gauge and the holes are somewhere around the size of a #10 machine screw. The rivet would need to go through both pieces of sheet metal and allow them to rotate so that the door can open and close. Gravity closes the door. Google is no help. When I search for swivel rivets, it thinks I'm looking for a rivet tool with a swivel head.
Beerhippie
Far NE Oregon
Really? A replacement is $15-20. I like fixing and reusing as much as practical, but you've got to figure your time is worth more than that.
Or, maybe you're just looking for an excuse to buy another tool?
W
Wamsutta
Amarillo, Texas
Change over to a #10 screw, two washers and a locknut. Just don't tighten down too far and let the door flap.
I thought about that. There's barely enough room for a #10 jam nut. A nylon lock nut might be too thick but would be ideal if it would fit in there.
This kind of stuff is outside my comfort zone. I'm far more comfortable with mechanical stuff and welding material together.
I've never replaced a mailbox with a chute that goes through the wall. I think the mail lands on the floor inside the house.
I did see the two nails one on each side of the chute that holds the chute in. The nails are right smack by the door that I need rivets for.
I'm not very exited about a rivet install tool. Especially a tool I may use one time and that's it.
The lady says that when the mailman leaves the mailbox door hanging by the left corner, mosquitos enter her house through the mailbox and bite her.
gahrajmahal
Cincinnati, Ohio
Your examples show four screws on the outside holding the door on. That would make the repair easy. Is her mailbox door held on by four screws from the inside? Or possibly two or more screws at an angle once you open the door?
Looking at your rig in your Avitar I’m Surprised you don’t already own a pop rivet gun. I thought that was a requirement for every GJ member to join. Here’s mine.
And when I worked for U-Haul as a young man we were all the time repairing the van bodies of the trucks. Here is my tool box bottom I built on my lunch breaks from old van body panels and a stick or two of 1 x 1 square tube. All attached with pop rivets.
JradM
Alberta
I imagine the rivets in question are behind the flappy door and hence not visible in the photo you posted.
Assuming the rivet goes through both the frame and the door but shouldn't be pulled tight or else the door won't open and close, you could still use a regular rivet gun but you'll have to use a spacer you subsequently remove to preserve the gap - like a washer cut into a C shape.
If you don't have a rivet gun, you could simply grab a piece of brass rod (or brass rivets I suppose, if you can find them in the hardware store), and rivet it the old fashioned way. I.e. mushroom one end with a hammer, then push it into the hole and tap-tap-tap on the other side to mushroom that too. You'll need a backer of some sort so you're not just tapping it back out of the hole.
You can adjust how tight the rivet holds my how much extra length you leave and how far you tap it. Ideally the rivet should basically fill the hole and you're just mushrooming the ends so it doesn't come out.
Edit: watch this guy make rivets for his Swiss Army Knife, for example.
W
Wamsutta
Amarillo, Texas
I got it all figured out. The rivets in question are called semi-tubular rivets.
They are set by using a rivet squeezer like a TATCO.
The rivet squeezer uses a series of replaceable dies like you would use with a ratcheting electrical crimper.
One die acts as an anvil to hold the head of the rivet while the die on the opposite side of the squeezer holds the hollow end of the rivet.
But there's other tools for setting the rivet. There's a C-clamp style tool and a punch style tool that you strike with a hammer.
The main thing is to have a die or a punch with a spike in the middle to keep the die on center with the hollow end of the rivet.
Semi-Tubular Rivet 4.jpegSemi-Tubular Rivet 6.jpegSemi-Tubular Rivet 9.jpegSemi-Tubular Rivet 11.jpeg
308guru
Usually installed with these, but you can buy hand tools as well.
JradM
Alberta
Interesting. I've heard those called "Cutlers rivets". I mention it in case it helps you source them easier.
signcrafter
I'm usually all for buying whatever tool is needed to do a job, even if it's expensive and not going to use it often. Also even if the tool costs as much as just replacing something but I will have the tool to use in the future. But these tools all seem pretty expensive and guessing since you, and me didn't even know about them before this thread it won't get used often. Think I would just buy a new one.
W
Wamsutta
Amarillo, Texas
I got the lady's mailbox door fixed. I used a 10-32 x 3/8'' machine screw and a 10-32 jam nut. Works perfect now.
The mailbox door has an "ear" for the rivet to go through and the mailbox chute has a matching ear for the same rivet to go through.
The mailbox chute ear is real close to the wall of the chute leaving just enough space for the jam nut to slide in between the ear and the wall of the chute. The mailbox door ear meshes with the chute ear. Both of these ears are at 90 degree right angles if you can picture that.
whateg01
doo dah, kansas, usa
It's too bad nobody has come up with a way to produce a graphical image of a thing that's hard to describe that could be uploaded to the Internet.
