Show your new tool arrivals
Squankum
Southeast
When I swapped the engines on my previous Vanagon from the stock 1.9 to a later 2.1L, I had to borrow a timing light from a friend. The timing mark on the 2.1L was not right for the ignition I used, so the retard/advance function of the digital timing light proved critical.
I've been there! Also, this other ancient technology is helpful:
Squankum
Southeast
P.S. A refresher on the historical timeline:
1950's: Bettie Nesmith Graham invents Liquid Paper correction fluid.
1966: Her son, Michael, is hired to be a member of the Monkees, a TV show/band that eventually became a real band
1980: Mom dies, leaving half of her $50M estate to her son
1984: Michael is now a producer and the movie Repo Man gets made. Other projects and adventures continue.
2021: Michael dies
What surprises me is that both Liquid Paper and Wite Out, the imitator, are still out there in liquid form! Who's typing? Also, the tape version is just so slick nowadays. I used that for a decade or so at work, and in the laser printer era. (shrug)
Beerhippie
Far NE Oregon
I use Wite Out pens for metal marking. It shows up nicely against dark cold-rolled metal and it's pretty much heat-proof for things like free-hand plasma cutting. It's also pretty permanent on prepped metal and works great for things like highlighting markings on tools.
ChefRex
My Deremel has been leaking some smoke for a bit and the other day it let it all out.
So on to the Big River and find one with a hard case and a flex shaft, I find the hard case easier for dealing with accessories and having borrowed a flex shaft recently I wanted one.
Shows up today, seemed small for a hard case and sure enough it's a soft case and no flex shaft.
A little pissed that I'll need to drive to drop it off and dealing with their customer service trying to get a chat but very happy when they told me to keep it and they will issue a refund, score.IMG_3780.jpeg
Lumberjack_bw
Southeast Tennessee
Harbor Freight.
Badlands 48 inch Farm Jack. A replacement to a cheap "Reese" branded one that's a piece of junk.
My plans were Hi-Lift and Hi-Lift only, but Rural King has sucked with keeping the things in stock. Also, this was $30 cheaper.
PS: also got some 3/8 impact sockets, but will return them due to Walmart not having the HT 12V impact in stock; and I'm back there anyway to pick up a workbench with a truck.
Walmart. Hyper Tough 800 Lumen Slim EDC Pocket Flashlight.
It has a "tall" worklight type lamp on the side, a "regular" flashlight on the front, and a UV bulb as well. All in something inexpensive (under $15 with tax--Walmart lists at at $14.97, it's $13 something at my Walmart on the shelf) and slim for what it offers. It also has a pocket clip.
Maker is listed as "NINGBO FUTAI ELECTRIC". Looks like they sell on Amazon, Walmart, and a few other places as "FORTOLIGHT".
Modes--"long side bulb"--single press mid, press again for low. Hold--red. press again after that--flashing red. "short side". Press once, low--press after that, medium. Hold--full "HOLY **** I'M BLIND" 800 lumens. Double press, UV.
Replaces quite a few lights I have, and I know I'll lose it, so I bought two at that price. These had originally came out in May-ish, and my store sold out of 'em quickly. They finally restocked in the past week or so.
Fiskars "garden scissors'. These were in the garden stuff on clearance for $8, and I got them for my new shop scissors. They cut great!
They slide into a plastic scabbard with a sharpener. Could've sworn it had a belt sheath before; but I swear that's Lowe's version of this.
I have had that flashlight for about 2 weeks. For a $15.00 light i love it.
jd_1138
NE Ohio
In an estate sale $3 Penncraft small metal toolbox in great shape, I found this little bag of Fuller metric combo wrenches. It says on the bag it has 7mm, 10mm, 11mm, 12mm, 13mm and 14mm, but the 10mm is missing and in its place is an SK 8mm. I'll add a 9mm and 10mm and put the set in my everyday portable general toolbox. I don't have any wrenches in it just sockets and 2 sizes of adjustable wrenches.
Durasharp US made scissors from are also going in that box. From same toolbox.
neophyte
Pennsylvannia
2021: Michael dies
Laundry bluing is still being sold, likely mostly for non-laundry tasks.
lund
that white out type stuff is great for marking the timing marks on engines. i always keep a bottle in my tool box.
Also such things are good to paint a mark to indicate the "Top" side of plastic clamshell cases. It is surreal how many cases are made where the top and bottom sides are not clear. Don't ask me how many times I opened the wrong side dumping out contents till I started marking the up side on all cases where it was not very clear!
Squankum
Southeast
I think I labeled a special tool I had rented from the auto parts store for just this reason! Heavy parts, too.
bugnut
Central Ohio
I keep several colors of nail polish in the shop for just this reason, and of late i've take to marking keys and locks, so I know instantly who mates to whom. Much easier, and my sis was dazzled when i showed her the colors and uses!
neophyte
Pennsylvannia
Wikipedia tells me this:
"Solid bluing is sometimes used by hoodoo doctors to provide the blue color needed for "mojo hands" without having to use the toxic compound copper(II) sulfate."
Soooo... what other uses?
Squankum
Southeast
"Reduce Algae Growth in Fountains / Animal Bird, Fish Ingestion
Mrs. Stewart's Bluing is often used in fountains, bird baths, and fish ponds to make the water more beautiful in appearance. This brings up many questions regarding the effect of MSB on fish, birds, and plants. Here is an article with more information. PDF"
To the capitol!
Squankum
Southeast
I just realized I could have used some Wite Out on my "vacation" recently, at a friend's place having to charge truck and tractor batteries that are kept in the workshop. Normally I have colored felty rings helping me. Lots of squinting and double checking for + and - on those black plastic cases!
Squankum
Southeast
i've never seen a lawn mower or bike shop throw a scope on while using one of these. usually this is what i'm seeing used instead, https://tarylfixesall.bigcartel.com/product/taryl-s-spark-plug-tester
I used a simple Lisle spark tester last week on a friend's riding mower. Sad little orange spark jumping the gap, engine not starting. I replaced the plug because it was an unknown (not my mower) and it started and ran roughly. Not using the tester at this point, I then removed the engine cover to inspect the entire spark plug wire, which, at its advanced age, might have issues.
Yep. Rubbing against engine/head, either worn or melted and grounding out. Insulated it in a temporary way (electrical tape, split fuel hose) and the engine ran happily. (As long as I held the seat switch in one hand and squeezed it at all times, but that's another story. It's not always one problem...)
That Briggs & Stratton motor is just not a diesel.
ChefRex
Flex shaft and a small Dewalt parts box delivered today, I will have to make do.
Tarantula
Picked up some blades and the extremely scary seasonal bucket from Home Depot. Then a beater square from Harbor Freight because I was already there to get a couple of their 55gal bags for someone.
The Diablo stuff makes me think I'd been previously cutting with Ea-nāṣir's finest copper blades.
Etchase
Hawaii
I bought this because it was $10, and I was surprised someone like Performance Tool, would go after such a small market. They sell 700 of these a month on Amazon apparently, so not as small as I would have guessed. No idea what is patented on this 24 tooth ratcheting adapter. Apparently, I way over paid, because it frequently goes for $7.00 delivered. Garage sale type pricing to your door. The center position locks the rotation by engaging both Pawls with the cam machined into the red piece. I doubt I will ever use this but it was interesting to take apart. Responded well to some light lube.
L.Cheapo
Great timing. I thought I needed one today, and that got me wondering if there were U.S. made versions available. I will check it out.
I wonder if it is made here...or just owned by Americans but produced elsewhere?
I may be wrong here, but everything I've looked at from RHINOUSA was made in China.
I have a 3"x30' US made tow strap I bought from Mac's several years ago. Unfortunately, I can no longer recommend them to to being bought out by a conglomerate and a subsequent degradation in quality and service. There's probably someone else out there making them.
willf650
Everything I’ve bought from Rhino USA has been foreign made and so so quality. It’s flashy colors though.
They do have a good warranty but I would prefer not to use it. I have had to warranty 3 of their retractable tie downs at different times. Basically after first use they won’t retract.
I do probably have about 12 of various tie downs from them and atv/dirt bike soft hooks.
There are higher quality options out there.
