Macnaught K32 Grease Gun
milkovich
Akron Ohio
Hi gang, no one seems like they make quality grease guns anymore especially if you're a pistol grip type. I'm not sure why but on Macnaught USA's website and on their ebay store, they appear to be clearing them out for $28. These are made in Australia grease guns, not the made in india or china grease guns everyone else sells. The only comparable options are well over the $100 mark and these are K32's are usually about $90. Not sure if they'll be around for a long time, so it might be worth buying more than one. I literally spend more on a tube of grease than $28
https://www.ebay.com/itm/236773729586 (cheaper shipping)
elcom
Houston, TX
According to AI, the K32-2 (link to the US site) has a different thread than the K32-1 (Ebay item). K32-2 thread is more common in the US. Just FYI.
quinlan06
NoDak
I presume they're implying the body (where the hose attaches) is BSP threaded. IMO, this should only be a concern if/when you need to replace the hose as the other end of the hose should still have the zerk attachment on it to work with (most) any grease zerk.
Also, BSP to NPT adapters do exist, I believe.
Firebrick43
West central Indiana
Just so people are aware, 1/8- 27 is NPT. 1/4-28 is BSP
1/8-27 NPT will screw in well about 2.5 threads and starts getting tight, but not enough that people won’t get a wrench and happily **** up the threads, not only because of the difference in TPI but also the difference in thread angle (55 vs 60) and whitworth profile
German G 1/8 is also 1/8-28 BSP
I have had to repair dozens of holes over the years from people just jambing things in holes without looking wa what they are
MichaelP
IL/WI border
Shipping for two of them from eBay is just above $9 if you choose USPS. UPS is $13+
Any actual users? Is this gun really good or we're just assuming that an Australia made one should be better than Chinese and is definitely worth $90 regular price?
M
milkovich
Akron Ohio
Right now I’m just assuming, but I bought a LockNLube gun and it was India. No better than a modern Lincoln. I was about to buy an SAE but their website only tangentially says made in USA. I'm desperate for a grease gun that will last as long as me (20-30 more years) so this one is worth a shot.
NOEYEZ
NOVA
I have one of these guns. Best gun I have ever owned...and I have owned every make that was both USA and non USA made. This one does not leak or bypass internally. Have had it since it was imported into the USA. There simply is no comparison to anything made....PERIOD!
M
milkovich
Akron Ohio
I received it but it only says "designed and engineered in Australia" not "Made in Australia", that said it does seem to be pretty high quality and I can't complain for $28, I'll see if it holds 0 weight grease.
