One of those just sold on eBay.1933 Blue Point Slide Hammer. 10-1 . Only shows up in the 33 cat. Only one I have ever seen. threads on slide are 5/8-18. Hard to find old pullers, they usually had a rough life
I started BP and SO pullers maybe 10 yrs ago. fun to collect, and fun to get them back into good working condition.
I have the same spring compressor. Back in 1978 I rebuilt my transmission in my 1950 Harley-Davidson. I was near Butler, Pennsylvania at the time, staying with a girl I knew. They had a mechanic there named Ken who walked me through it. Fast forward about 45 years, and this spring compressor was on eBay, being sold by that dealership, or whoever inherited it. I bought it, of course!Blue Point (Sturtevant) VT15 Compression Spring Tester, with early Snap on Torque wrench. Would date early to mid 40s
I bet they are two different sizes. The Buick spring shackles for the six cylinder and eight were different. The eight started in 1931, thus the difference. I have both, will get pictures tomorrow.Blue Point BS3436 and S9857 wrenches..
Buick Specials (BSxxxx) and S98xx)
These are basically the same wrench. the BS shows in the 28 cat. the S9 shows in the 32-33 cat, this one has a 31 code. Also has the BS model number, the S9 has a slight difference in the offset. Both were probably started of as a X36X34.
Front spring, rear shackle bolt on 1930 Buick models, 50 and 60 series: also on 1927-29 Master and 121-129 series, (with pan on use 1-1/8" open end wrench for lower nut.)
Rear spring, front shackle bolt on 1930 models, 50 an 60 series. Rear spring, rear shackle bolt nuts and front spring front shackle bolt nuts on 1927-29 Master and 121-129 series. 1-1/16 on straight end and 1-1/8 on offset end 15-1/4 long.
The bend looks pretty good for a Chevrolet starter wrench.I found this wrench in a pile of rust in a trailer at a swap meet Friday. It seems to have the original black finish. The markings, "Blue Point Boxocket" "3/4" and "X24" are faint, but clear. It seems to have had little use.
It started as a single offset wrench, and was bent to a specific shape very cleanly. It was done well enough to suggest factory work. I bought it because it looked so cool, and found the markings after I got it home.
Long before the end of the war, surplus production had rendered moot the necessity of wartime restrictions, and companies anxious to resume sales to the consuming public were chomping at the bit to enter the marketplace competitively. Shortages by the end of 1943 were mostly on paper and designed to keep the civilian market available to the big companies after the war. Reconversion (opening up civilian market and relaxation of restrictions) was anticipated and prepared for aggressively.RX2432 Refrigeration Service Wrench. shown in the 39 and 41 cats. Has a date code of 45. 3/4 x 1". Possible the first Double Flare nut wrench by Snap on. Odd that its chrome, being a 45.
Why would the 146 not be usable? Can’t you grind the tip and get a new profile?
The whitworth one is hard to find.I've been using Snap-on and Blue point for some years now, I recently started to collect vintage tools, so going through all toolboxes I find and found these gems at work
oh really, I was trying to find the WOEX but with little succes, although I haven't been searching long. just alloy artifacts and this. do you know the difference between imperial and withworth, I have heard about it ages ago, also course an fineThe whitworth one is hard to find.
I think imperial refers to American Fractional/SAE. Whitworth/British Standard is a UK measurement.oh really, I was trying to find the WOEX but with little succes, although I haven't been searching long. just alloy artifacts and this. do you know the difference between imperial and withworth, I have heard about it ages ago, also course an fine
yes, I meant American Fractional (SAE?). Wel it never dawned on me the difference with British Standard, thanks for schooling meI think imperial refers to American Fractional/SAE. Whitworth/British Standard is a UK measurement.
That's not a date code. It's a stock number associated with wartime Merlin Packard toolkits.Code is AT8052
