Vegaman_Dan
A new addition to my collection of unusual toys arrived yesterday.
A FREAKIN' LASER BEAM! (No sharks attached though)
Yes, it's a China built laser, but that's where they all are built so that's not really much of a choice. These units used to be $2500 just two years ago. Last year at $1800, and I just bought this one for under $600.
It's really well packed. Complaints about these imported units were that the laser tube would arrive broken, bolts/screws missing, connections loose or missing, etc. This reseller is in the US and brings in a large quantity, then goes through each one tuning it up before shipping it out. They actually make sure it WORKS before they ship it. That's huge. It also comes wrapped in about 5" of bubble wrap.
Honest, there's a machine under there:
This thing is big. I had to double check the dimensions listed to be sure it was correct. 32" wide, 19" deep, 11" tall. It has to be that wide because the laser tube in the back is that wide.
I prepared for its arrival early by picking up a simple HF service cart for $30, assembled it with the top shelf upside down to provide a smooth solid surface that I can mount the cutter to. A 5 gallon bucket with a water pump (supplied) has hoses running to and from it through fittings I put in the lid for routing the coolant to the laser tube (I just like saying laser tube. Cooooool)
I figured if it's on a cart, I'd like to keep a laptop handy to drive the unit, so I repurposed a spare single monitor arm mount (Most people have dual monitors these days, so a single arm is cheap) by mounting it to the cart, then welding up a bracket to go on the VESA mount on the arm's end. To that I attached a cutting board. I would have preferred white or red, but I could only find green and purple for the board. Oh well. I added a couple of U bolts at the front so it could hold the laptop. The ball mount of the VESA mount to the arm is retained, so it can tilt/pan in any direction. The whole arm can move readily around where I need it.
I've added on board power for an outlet strip and will be adding a permanent extension cord and storage next.
So what are the specs of this laser?
40 Watt CO2 Laser
Water Cooled
Cutting area: 8"x10" (Unmodified), 10"x12" (modified)
Software: Moshidraw 2014 (which is much better than the earlier despised versions)
What can you DO with it?
Engrave / Cut non-metallic materials including acrylic, plexiglass, wood, cloth, leather, styrene, plastics, glass, human flesh (if you're not careful!) up to approximately 1/4" thick. Thicker materials can be cut with multiple passes.
Metals *can* be engraved, but requires the use of a metal marking spray (MMS) that you coat the area to be marked then run it through the machine like normal. The laser will react with the coating to etch the metal below. The spray is NOT cheap at around $70 per 12-16 oz spray can!
What sorts of things can you make?
Engraving: Edge lit acrylic signs. Dogtags. Key fobs. Plaques. Labeling. Signage. Pretty much anything you'd normally engrave.
Cutting: Thin plywoods and acrylics work great for cutting shapes precisely and easily. Flat gears, spacers, any 2D shape you can think of. If you put in a piece of gasket material, you could cut out gaskets cleanly. You know how hard it is to cut cork without getting ragged edges? Easy with the laser. Want styrene or other material circles for gauges? Done. Want some scroll work for some decoration? Done. Reversed versions too.
I'm still getting the software set up, but the tests were successful. I'll hopefully be able to get some items cut on Saturday to test out the properties. I am pretty sure this is going to get used a lot as I come up with more uses for it. As long as you have a pure black and white image saved as a BMP file, you can cut it. That has some real possibilities.
40 Watt CO2 Laser
Water Cooled
