Vernmotor
Yep I got one of them drill doctor also..I do better by hand ..wish I know..I send you mine to play with..before you bought one
Since Drill Doctor is made by the same company (DareX), I was expecting it to grind in a similar fashion to the industrial versions they make with the big difference being in the plastic housing, small grinding wheel, and such. The cam-action is just not the same on the homeowners version. I'm maybe being a little harsh because the bits do come out SHARP, no doubt. It will probably end up being worth the $125 I paid for it (model 750X). I just need to forget the lesson my shop teacher taught me in high school - maybe he was wrong anyway. It is nice that it's portable so I can take it between the city house and Asylum (although bringing the bits to IT may be easier
I'm actually looking forward to some framing construction now that the weather is cooling off.
Boy I like to read that thread !
Yep I got one of them drill doctor also..I do better by hand ..wish I know..I send you mine to play with..before you bought one![]()
I did a search for "drill doctor" and found the one that I commented in. Still looking but haven't found the one with the vendor comments. Some of the people on this forum like them and some don't. Anyway:
http://garagejournal.com/forum/showthread.php?t=93550&highlight=drill+doctor
AHA.... Here's the thread that I was remembering:
http://garagejournal.com/forum/showthread.php?p=940776#post940776
I'm sure it will feel good to start framing again...its the bread and butter of these builds. It is also nice to see something so big come together for the amount of time spent on it VS spending forever on something just to have it look like you did nothing.
I have that feeling quite often![]()
You know C-Red, I've been on the fence for probably five years now on whether or not to cover up those darn beams. Thanks for voicing your opinion - I'm sure there's others that feel the same as you. I actually liked them in natural wood with the giant checkered flag up there. But the wood looks a bit more out of place now with more of the ceiling finished in white. I do, however, like the idea of a contrasting color for the beams to make them stand out, but I just don't know how to accomplish it. I toyed with the idea of making them look like monster aluminum I-beams, but talk about extra work - yikes!I know you like a finished look, but seriously, consider leaving the beams exposed. They look good. Waste of time and material to cover them imho.
Great updates as always. Thx.
). They almost look stained in the pictures. The other big problem is the vertical 4x6's used to support the ceiling purlins actually hang below the rafters by about 1/2". If leaving exposed wood, I would still want to cap off the bottom of the beams with matching wood, so I would need to trim off the 4x6's or add some furring strips to the bottom of the rafters to make it all flush.I was going to ask where exactly this loft is going but then I remembered the index so now I don't have to ask and can look forward to watching it go up and I think this was a run on sentence.
Leave the beams..give it a homey feel..
Ok..here's another of my "hair-brained" ideas for the beams. Paint them black, trim beam corners in aluminum trim and then add maybe a 1/2" to 1" yellow "racing" stripe on each side. That will tie the ceiling into the rest of the shop and add visual interest to break up the expanse of white vinyl.
...just another crazy idea...LOL!
First, the wood doesn't look as good in real life as it appears in the pictures
the one above the jib crane has a number of lift rings built in that will need to be accessible from time to time.
I do love the look of wood beams, but do you have to worry about termites and other wood boring insects in your neck of the woods? Do you have to caulk every nook and cranny of finish materials to keep them away from the wood? Just wondering about that "ounce of prevention"...
I see. I wish the camera would do the same for me. I hate them and mirrors with equal passion.
WOW! I just found this site a few days ago and got hooked on to your build thread. Finally finished all 46 pages. I'm amazed at the details and planning you've put into everything.
I also was hoping you hadn't finalized your plans for the rafters being exposed or covered. Just wanted to vote for the exposed wood look. Until I just saw the suggestion of black stain with a yellow stripe that could be cool as well to break up the white. Unless the ceiling flags go back up? Once again awesome build. Now I need to go check out the Saltwater Hideout I think it was called.
Also the Asylum sign might look good in an oval format closer to your avatar than the house outline, just a thought. Either way I think you could do the yellow as the background with plexiglass and that would make backlighting really have a neat glowing look.
The little details sometimes seem to take FOR-EV-ER. All of us have been there. I think I could give 100's of those examples in the Asylum build (actually, I think I did in this thread). But eventually the little stuff paves the way for the major milestones and then it all seems worth it!
)Yes - Please check out Jeff's Salt Life Hideout. He is well on his way to creating an awesome place!Now I need to go check out the Saltwater Hideout I think it was called.
Yes you can get plexiglass in pretty much any color you want.
Rick
This poster might look good somewhere in the shop.![]()
Yep, it helps to have a vision - that way you can see the end result in your mind when the only thing in front of you is the current mess.
Helps keep ya sane.
(But look what forum we are on. Who am I kidding?)
Helps keep ya sane? - That's no fun!![]()
With sanity, they may kick me out of the Asylum and then I will have to start all over (and I'm not sure I have it in me)!
The hoist looks great! Any idea what max load is?
Knowing that you live in hurricane country, the hoist can serve a dual purpose. Install a shackle plate into your concrete floor and hook the hoist to it; it'll help keep the Asylum from blowing its lid! lol
Did you say it's a 'manual' hoist? Shopnut, how could you do this; HAL will be crushed.
But I have to be in control of a few things, right? Then that is the beam they will find a survivor under when the "big one" hitsI think that just might be enough lag bolts. In case of a national distaster that'll be the last truss standing.
Seriously, always looking forward to the next step of the mad scientist.
Thanks RL. I'm glad you can finally see them. But I didn't do anything different, so it might be something you did on your endAs always, lookin' good.
And the pictures finally showed up!!!
That checklist is either very inspirational, or (remembering all the undone things I have yet to do), very depressing
Good thing I'm the 'glass is half full' kinda guy
Really shows what you have accomplished.![]()
Thanks Shaun.Great job and great write up on the hoist...now I want one of those things TOO! I have not gotten anything done in the last three weeks. Between harvest time, work, kids, and OSU football game this SAT I have been slacking.
Shaun
Although it may work for everyone, most people will benefit from listing out what needs to be done. It helps keep them on track. For me, they are very motivational, they help me focus, and also tend to be a great reminder to make sure materials and tools are in place for the upcoming tasks.
Thanks mithrix. If you want to be efficient and timely about getting your work done, you need to have a plan, and a list certainly comes in handy. Of course, someone has to do the work tooVery nice Asylum! I'd be happy to be commited there! LOL
Haven't gotten through the complete thread, but the index rocks. And your list comment along with Red Leader's statement about having a vision... So true. It's obvious I need to take some time to think about the direction I want to go with my mess. But, I digress.
Great place, i'm particularly intrigued by the guitars. Love the way you did the lounge area
Best Regards,
-C
HEY - No jumping allowed here! (just kiddingI jumped ahead.....still have pages 5-45 or so to go through.
Excellent shop.
BTW, you are going to need a hoist to get that track up to the ceiling!
Thanks Foxxtrot.Haven't been back to your thread in a little over a month! Congratulations on (several) jobs well done!I kind of like it that way, it's almost better to read a few pages in a row than be left hanging on the next installment
