Priariecanary
This is a thread about a garage I built about 10 years ago. Nothing special on the inside just lots of space and a storage loft. I tried to match the exterior design of the house. I have since moved and will be building a new garage this summer. I thought I would post this one in the mean time.
The house. Note the shingle detail on the gable ends.
Better pic of the gable end. Each row of shingles has a different pattern and the pattern repeats every 4 or 5 rows.
Site prep. Digging the hole for the foundation.
Trench for the footings.
Footings in place. I had subcontracted all of the work to this point.
My brother and I framed and sheathed it in about a week. Getting started here.
Titling up a wall section.
Those microlam beams over the garage door openings were heavy. It about killed us getting those walls tilted up by ourselves.
We hired a crane to set the roof trusses. Took a couple of hours on a saturday to get them all in place.
You can see the storage loft taking shape here. I would have preferred 10 foot walls on the first floor and 12/12 roof pitch to match the house but had to use 8 foot walls and 10/12 pitch due to local height restrictions.
Sheathed and wrapped. I hired a guy to wrap the building and build the stairs. He didn't do the best work as you can see.
View of the stairs. I wanted to put the stairs on the outside to save interior space but that turned out to be not such a great idea given the minnesota winters.
View of the loft. Floors were 3/4 plywood, glued and screwed to the floor joists, 24 O.C.
Exterior trimmed out but not painted. I used cedar lap siding like the house.
Testing out shingle patterns. I found an old-school lumber yard that still sold bulk cedar shakes. I ripped each shingle to width on my table saw. I then cut in the end detail on each one using a custom angle fixture and a radial arm saw. I think it took about a dozen bundles of shakes to do the whole garage. I had a regular production line set up. I must have cut shingles for the better part of the summer. I had to pre-drill the nail holes in each shingle to prevent splitting. Each shingle was nailed using a copper roofing nail. I painted the first coat before nailing to make the second coat easier once they were installed.
Getting "help" from my dog.
A pic showing the finished gable end with the shingles in place and painted. I must have run out of warm weather before I had a chance to paint the soffits!
I will start a new thread once work gets going on my new garage.
