Stargeezer
Added pics of installed G73 below 2/24/09:
Has anyone added a remote thermostat (line voltage type I assume) to your G73 electric garage utility heater. This popular Dayton model comes with a built-in thermostat & control knob. It looks like adding a remote thermostat to this model would be a modification to the internal board; and that voids the warranty.
The Dayton F79 is the same 5KW heater output-has a slightly bigger fan and comes all set-up to wire-in a line voltage thermostat. However the F79 is $200+ more and doesn't come with a mounting bracket either. If I could buy the F79 at a hefty discount, then I would get this model in a snap and install a nice digital thermostat. Anyone have a source for this model @ less than $479 plus freight (another $20)?
Right now I am leaning towards adding a remote On/Off switch at shoulder level on the wall below a G73 heater. This way, once I get the internal thermostat dialed-in, I can easliy switch it on and off without climbing a ladder. Set and forget. I want that.
Input appreciated. Thanks
