I've already copied your stairs & am getting ready to add ceiling fans in the main part of my garage....just read an article that said ceiling fans should be at least 14" from ceiling to provide maximum efficiency uplift/downforce of air. Though you'd like to know that also.
Thanks for sharing, Autoist.
Unfortunately in my office, the fan is stuck between a rock (my head) and a hard place (the ceiling)
The downrod that came with the fan kit positions it at a good compromised height. I don't feel the need to duck when I walk under it. The blades on the low side of the ceiling are about 8" from the ceiling, while the high side is about 16". If it was a 52" fan, I would be worried, but with this little fan, there is virtually no chance it can swing far enough for the blades to hit the ceiling (I tried it).
I totally agree with the efficiency comment, though. If too close to something the energy of the fan gets converted to noise/friction instead of actual air movement.
Never expected that! Luckily, I fixed all the oil leaks on the Chevelle last year so the sheet pan was basically clean. That could have been a disaster two years ago when the ****** was leaking like a sieve. I was also surprised when he managed to get himself out too.
Excellent thread, on an excellent project.
I'm really enjoying your pictures/place and all the information provided. Thank you, so much for taking the time to share it.
