The stone work has extended around the front of the clubhouse.
The have started putting the studs up in the clubhouse. One odd feature. There is a door like feature from the clubhouse into the next unit. When I looked at the other units getting studs in place that same door was located in the same relative space. I don't know if that is to allow movement back and forth during the build or if there is actually going to be access between units somehow....
The view down the courtyard is starting to look nice with the doors in place and the stone work getting in place.
They have pulled the support poles down in the center building. The pictures show that things are quite wet in there today. The roof decking looks to be attached but it obviously is not waterproof yet.
I noticed that they are caulking both the outside and the inside of the tilt slab joints.
The stone work on the center building is clicking along and is more that halfway done already.
One last piece of architectural archaeology. I saw these bricks a couple days ago and wondered what they were for. I thought maybe they were for the tops of the stone work as a cap. But, the bricks had holes through them so I couldn't figure out how they would make that look correct. Today I found the bricks in the dumpster. It appears they might have come to the same conclusion....
Then again, who knows. Makes it fun to guess what happened from small snipits in time.
