Go Back   The Garage Journal Board > The Garage > General Garage Discussion
Reply
Thread Tools Display Modes
Old 07-16-2017, 12:01 AM   #1
jd_1138
Senior Member
jd_1138's Avatar
Default Chain or worm drive garage door opener?
I helped the neighbor replace his chain driven opener -- Craftsman brand. Seems kinda poorly engineered. Are worm drive or belt ones better? I'm going to install one at my house.
jd_1138 is offline   Reply With Quote
Old 07-16-2017, 01:44 AM   #2
Lynden
Junior Member
Default Re: Chain or worm drive garage door opener?
The last one I installed was a Chamberlain belt drive opener from Home Depot. It works well and is very quiet..
https://www.chamberlain.com/garage-d...rs/belt-drives
Lynden is offline   Reply With Quote
Old 07-16-2017, 01:53 AM   #3
rcktsled
Senior Member
I installed a Chamberlain belt drive a few years ago. It's great, very quiet, and has battery back-up for power failures. Highly recommended.
rcktsled is offline   Reply With Quote
Old 07-16-2017, 01:59 AM   #4
mike93lx
Senior Member
Another belt drive user here. My two chamberlain openers are very quiet.
mike93lx is offline   Reply With Quote
Old 07-16-2017, 02:46 AM   #5
ddawg16
Senior Member
ddawg16's Avatar
Belt drive will be the quietest of of the traditional openers.
But if my opener ever dies......I'm going to convert to a LiftMaster 8500 screw jack operner
__________________
John
"Don't try to lead me to temptation, I know the shortcut."
In Progress...2-Story Addition link
2-Story Garage Complete My Garage Build Link
Home for.....
84 CJ7 - With a 'few' modifications.. My Jeep Build Link
And my wife's art Studio...
and 3 kids with more energy than we have...
ddawg16 is offline   Reply With Quote
Old 07-16-2017, 05:43 AM   #6
$Jay
Junior Member
Ive had a Genie worm drive for 16 years not a single issue other then they are a little noisy. Put in a drop ceiling and that helped with noise quite a bit.
$Jay is offline   Reply With Quote
Old 07-16-2017, 06:48 AM   #7
SimS
Junior Member
Check out a Somer Garage Door Opener. Very quiet. 12v DC motor runs over a fixed mounted chain. Unique German design, 3/4 HP.
SimS
SimS is offline   Reply With Quote
Old 07-16-2017, 07:26 AM   #8
LS6 Tommy
Senior Member
LS6 Tommy's Avatar
Quote:
Craftsman openers are made by Chamberlain/Liftmaster, more or less the best residential openers on the market. Chamberlain/Craftsman are the DIY line, Liftmaster is the Pro install line.
Mine's a 3/4 HP chain drive. It works great. I don't see the need of the extra cost of a belt or worm drive unless the garage door is under living space and noise is an issue.
Tommy
__________________
The older I get, the faster I was...
LS6 Tommy is offline   Reply With Quote
Old 07-16-2017, 08:25 AM   #9
Leaflessshadetree
Senior Member
I rarely hear my chain drive openers, mabe for a few seconds when I'm opening or closing a door.
Leaflessshadetree is offline   Reply With Quote
Old 07-16-2017, 09:20 AM   #10
EOC_Jason
Senior Member
EOC_Jason's Avatar
One of my friends has a belt drive that is like ninja silent. I don't know the brand...
I have a chamberlain chain drive. It was kind of noisy but after adjusting the chain and spring tension that quieted it down noticeably.
As for what is the most reliable, I would not know but I bet some internet research might help.
EOC_Jason is offline   Reply With Quote
Old 07-16-2017, 11:05 AM   #11
jmarkwolf
Senior Member
jmarkwolf's Avatar
Genie worm drive here.
Installed it myself 23 years ago, and it's been utterly reliable for 23 years, but is very noisy.
If this one ever gives up the ghost I'll strongly consider something less noisy.
jmarkwolf is offline   Reply With Quote
Old 07-16-2017, 02:43 PM   #12
thejimmy
Junior Member
thejimmy's Avatar
Just went from a worm (hated it, very noisy) to a Liftmaster belt, it's great
thejimmy is offline   Reply With Quote
Old 07-16-2017, 03:08 PM   #13
jbwilkins
DC motors are much more quite than AC....most of the newer higher end openers have gone to D.C. for this reason, Chamberlain is even offering DC in the contractor series now... ....
Iíve got both chain drive ( contractor series) that are AC and an elite series DC....the difference is night and day....one you hear the opener, the other one you hear the door and itís springs creaking, but almost no Norton noise....
jbwilkins is offline   Reply With Quote
Old 07-16-2017, 04:28 PM   #14
Firebrick43
Senior Member
Do the guys with worm drive lube em? Moms got a genie that I put up 10 or so years ago. She complained of noise and 5 mins with a can of spray grease it was back to only hearing the door. Spray those springs to to eliminate popping and binding.
Firebrick43 is offline   Reply With Quote
Old 07-16-2017, 04:40 PM   #15
Hot Rod Grampa
Junior Member
Worm drive run quiet when lubricated. Older Genies were very dependable. Newer have very sensitive circuits that fail easily. Chamberlain have nylon gears inside that should be greased once a year with white lithium on a small brush. Chain or belt same gear. 8500 shaft drive has delicate internals that can shorten service life. Plus spring tension needs to be adjusted to make the door "heavy" to prevent cable jumping off drum. D.C. Motors offer soft start and stop to prevent jerking and battery back up. If your door is balanced correctly a 1/2 HP motor is all you will ever need. Worked on em for many years.
Hot Rod Grampa is offline   Reply With Quote
Old 07-16-2017, 04:53 PM   #16
isb cornbinder
Senior Member
isb cornbinder's Avatar
I had my four panel door taken out an replaced with a roll-up door. I gained 24 inched=s of overhead height. The drive for the new door is inside the roll-up section and nearly impossible to hear. It cost about $1750 USD installed plus tax.
The Lift Master belt drive that came out is less than a year old and very quiet.
__________________
I would rather have tools I do not need than to need tools I do not have
isb cornbinder is offline   Reply With Quote
Old 07-16-2017, 09:39 PM   #17
ford33
Senior Member
I have a new Craftsman belt drive. It is very quiet. I cannot hear it from my master bedroom located above the garage.
ford33 is offline   Reply With Quote
Old 07-17-2017, 12:13 AM   #18
rmmiller
Senior Member
I'm thinking of going with the LiftMaster in our new house, more overhead room if I decide to get a lift!
rmmiller is offline   Reply With Quote
Old 07-17-2017, 04:04 PM   #19
kbs2244
Senior Member
I had a worm drive that the shaft broke where the two halves mate.
Replacement half was $98 and new chain drive opener was $120.
So now I have a chain drive.
I am happy with it.
kbs2244 is offline   Reply With Quote
Old 07-17-2017, 04:27 PM   #20
seanc_mt
Senior Member
Liftmaster 8500 all the way. Have two of them lifting 14x12 insulated doors with windows. Not one issue.
seanc_mt is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
