Go Back   The Garage Journal Board > The Garage > Garage Gallery
Reply
Thread Tools Display Modes
Old 02-10-2015, 04:24 PM   #4081
Jlbc212
Senior Member
Jlbc212's Avatar
Default Re: Winter Warning: Carbon Monoxide Poisoning
Even though a car, such as a BMW, may be clean burning, it is consuming oxygen. Jack may have a "leaky" garage allowing enough O2 in, hence no change in the carbon monoxide level. If the available oxygen level becomes depleted, insufficient combustion can occur resulting in the production of Carbon monoxide. It is always a good idea when running an engine inside a garage to keep a door open and to have a carbon monoxide detector in the garage.
Jlbc212 is offline   Reply With Quote
Old 02-10-2015, 04:52 PM   #4082
charlie v
Not to scare folks, but if I could add......
CO is something not to be messed with. It is odourless and tasteless. Prior to retirement, I work a few decades for a local natural gas utility. Responding to gas emergencies, I have been involved with and witnessed far too many incidents where people have suffered from CO poisoning due to lack of maintenance, faulty appliances, venting, etc.
One needs to be careful with CO. This shit can kill you.
My experience has been that CO is lighter than air. We always detected slightly higher concentrations at the ceiling. Our business rule was, we do not enter a home if the concentrations at the front door were above 100 PPM. I had to give a few of the guys shit for trying to be the bloody hero and entering a building with higher concentrations. Our business practice was to turn off the gas supply, encourage the people to leave the building and hire a qualified gas contractor to make repairs. Believe it or not, some people would just turn on the their gas without repairs. If we had a subsequent call for CO, the gas meter was then removed.
As an example, a home with a modern high efficiency boiler exhausting out the side of a home. The appliance was over sized for the application and it was short cycling. The appliance was very "dirty" until it was at full operation temps - high CO levels being dumped out the exhaust. The neighbor immediately adjacent always had their second story bathroom window open because they didn't have a bathroom exhaust fan. With the house having a slightly negative air pressure, it sucked the CO right in the bathroom window. Same floor as the bedrooms. CO detector was on the first floor. Luckily, this family only ended up spending the night at the local hospital because the entire family of 4 had CO poisoning. Neighbor didn't care about the exhaust and the only practical solution for the homeowner was to have their bathroom window closed.
Note - children are more susceptible to CO poisoning.
The above example was a prefect storm, but shows you how easily CO poisoning can happen.
Please be careful with CO.
Carbon Monoxide (CO) Exposure Limits
PPM, Time, Comments
35 – 50, 8 hours, The maximum allowable concentration for continuous exposure in any 8 hour period, according to OSHA.
200, 2 to 3 hrs., Headache (mild)
400, 1 to 2 hrs., Headache (mild)
800, 10 to 15 min., Dizziness, nausea
1600, 20 min., Headache, dizziness, death within 1 hour
3200, 5 – 10 min., Headache, dizziness, death within 1 hour
6400, 1 – 2 min., Headache, dizziness, death within 1 hour
6000 – 8000, 5 min., Incapacitation
12,800, 2 – 3 breaths, Unconsciousness
12,800, 1 – 3 min., Death
charlie v is offline   Reply With Quote
Old 02-10-2015, 05:06 PM   #4083
Strouty
Senior Member
Strouty's Avatar
Every year we have people who run generators in the garage so they don't have to go outside to refuel it during a storm. Sadly it will kill an entire family if the garage is attached to the house.
__________________
A link to my mess: The Salvage Garage
Strouty is offline   Reply With Quote
Old 02-10-2015, 07:02 PM   #4084
Charles (in GA)
Senior Member
Charles (in GA)'s Avatar
After I installed my Lanair Used Oil Furnace (LINK HERE) in my shop I bought a CO detector and plugged it into an outlet in the shop. The furnace is a typical oil furnace design but I had concerns about the combustion chamber leaking or CO leaking out of the flue pipe joints or barometric damper in the event of a reverse flow for some reason.
Charles
Charles (in GA) is offline   Reply With Quote
Old 02-10-2015, 07:50 PM   #4085
1redTA
Senior Member
it is important to have CO detectors in any room where sleeping may occur and CO is slightly lighter than air
1redTA is offline   Reply With Quote
Old 02-10-2015, 10:39 PM   #4086
Jack Olsen
Jack Olsen's Avatar
I went with this advice on placement:
Quote:
Getting the Height Right
You must ensure you get your carbon monoxide detector installation height right. While some guides might recommend placing your detectors on the ceiling, we don't agree.
The specific gravity of Carbon Monoxide is 0.9657 (with normal air being 1.0), this means that it will float up towards the ceiling because it is lighter than regular air. However, when a build up of dangerous levels of CO gas is taking place, this is nearly always due to a heat source that is not burning its fuel correctly (motor vehicle exhaust fumes are an exception). This heated air can form a layer near your ceiling which can prevent the Carbon Monoxide from reaching a ceiling detector.
For this reason we suggest that it is best to mount your detectors on the walls at least a couple of feet below the height of the ceiling. If your detector has a digital read-out, then we recommend placing it at about eye level so you can easily read it. Or if you have some other structure, like the exposed beam in this photograph which is positioned below the ceiling level, then you can attach your carbon monoxide detectors to it instead.
Jack Olsen is offline   Reply With Quote
Old 02-11-2015, 08:42 PM   #4087
Jack Olsen
Jack Olsen's Avatar
Default Re: The 12-Gauge Garage
And since I was out running some errands today, and since it was 79 out, I took the carbon monoxide generator out for a spin.
Old 02-11-2015, 09:01 PM   #4088
wasfast
Senior Member
Very warm day with the Santa Ana's. Was 85F in San Diego today...........!
wasfast is offline   Reply With Quote
Old 02-12-2015, 09:16 AM   #4089
Huxley
Senior Member
Huxley's Avatar
Subtle 1:26 on the license plate frame. Approved. Much better than the old Yosemite Sam mud flaps.
Huxley is offline   Reply With Quote
Old 02-13-2015, 12:17 AM   #4090
Modern Jess
Senior Member
Modern Jess's Avatar
Quote:
Originally Posted by Jack Olsen View Post
For all of you who have closed windows and/or god insulation for the winter, make sure you think twice before running an engine or heater without monitoring C0 levels.
No way am I painting my shop green. But I'm following Jack's lead on this one.
__________________
Check out my Scooter Workshop (build in progress)
Modern Jess is offline   Reply With Quote
Old 02-13-2015, 09:13 AM   #4091
ATK305
Wow! That garage is incredibly well thought out. Nice. I'm interested in that floor lift. Can you provide some info on that? I have been looking at the portable types but they pose storage issues when it won't be in use. That unit being built in to floor is great.
ATK305 is offline   Reply With Quote
Old 02-13-2015, 09:46 AM   #4092
Trey T
Senior Member
Trey T's Avatar
I'm a Illustrator user. For light duty stuff, PDF is a universal "container" for both Illustrator editing and delivery format for print. If you can set it up for print, PDF would be a very good format.
The guy who did the block grinder ID plate artwork agreed to let me share it with people. Unfortunately for most of you, it's in Adobe Illustrator format and requires some specific typefaces to be installed in your Mac computer for it to work. Obviously, that's a problem for just about everybody. But I think I can work out a kind of form where a guy can submit a request with the information they want on it and I can email them a high-resolution file that they can then get printed out as a decal or a metal plate or whatever they can figure out.
Give me a few days, and I'll see what I have in the file in terms of logos and such and I'll try to present some choices, and then I can make up some labels for anyone who wants them.
Trey T is offline   Reply With Quote
Old 02-13-2015, 11:53 AM   #4093
bazzateer
Senior Member
bazzateer's Avatar
Quote:
Not sure which page but it's all covered in this thread.
__________________
If I told you I was a pathological liar, would you believe me?
My garage story: http://garagejournal.com/forum/showthread.php?t=50588
Quote:
Originally Posted by Abbott View Post
I think the cop made a good decision.
bazzateer is offline   Reply With Quote
Old 02-13-2015, 12:08 PM   #4094
Senior Member
Outlawmws's Avatar
Quote:
Yup, get busy and read all 205 pages!
Seriously; it's worth it...
__________________
Outlaw's Camp Gear Thread
Outlaw's Shed Thread
Outlaw's Garage Sale
- For sale or trade... Last Update w/new items 8/21/2012 - P9, (More auto books)
Outlaw's Garage sale - Feedback
"It might be for sale or trade, it never hurts to ask..."
Outlawmws is offline   Reply With Quote
Old 02-13-2015, 11:19 PM   #4095
Squankum
Senior Member
Squankum's Avatar
More than you wanted to know!
http://en.wikipedia.org/wiki/Carbon_monoxide_poisoning
I had read in Circle Track magazine 10+ years ago that getting CO poisoning that didn't kill you could make you a lot more susceptible to getting sick during later exposures. I didn't quite see confirmation of that in my skim of the above, but I saw enough other things to scare me.
Speaking of German vehicles generating carbon monoxide:
http://en.wikipedia.org/wiki/Carbon_...ning#Holocaust
ATK305, while I, too, recommend you read the whole 12 Gauge Garage thread -- the gateway drug to Garage Journal -- for quick answers to your questions about Jack's garage, he built a website to give a more coherent overview.
http://12gaugegarage.com/
__________________
"I don't vouch for this, but merely repeat what the Libyans say." - Herodotus
Underground Lair of the Squankum
http://www.garagejournal.com/forum/s....php?p=1796399
Squankum is offline   Reply With Quote
Old 02-14-2015, 07:38 AM   #4096
Mpower5266
Senior Member
Mpower5266's Avatar
I have CO detectors hard wired in the basement and house but I really should get something that will tell me the levels in the basement. Im honestly not that worried since the basement is pretty leaky and I dont run the car in there for more than a few seconds but it couldnt hurt to monitor the levels.
__________________
My Basement Garage Thread
Mpower5266 is offline   Reply With Quote
Old 02-14-2015, 07:45 PM   #4097
Matt J
Junior Member
I finished it! 205 pages. Dec 17th, 2014 to Feb 14th, 2015. Thanks Jack for the inspiration, ideas, and entertainment! Looking forward to more to come.
Matt J is offline   Reply With Quote
Old 02-14-2015, 08:21 PM   #4098
Zeke
Senior Member
Zeke's Avatar
The installation starts on page 35. I can't find the post where Jack explains where he found it.
Zeke is offline   Reply With Quote
Old 02-14-2015, 10:24 PM   #4099
Makoto
Senior Member
Makoto's Avatar
Send a message via AIM to Makoto
sweet grinder dude.
__________________
My shop build: The Shepherds Wrench Garage
Makoto is offline   Reply With Quote
Old 02-16-2015, 10:04 AM   #4100
bluebolt
Senior Member
Hey Jack sorry to hear you are sick just let me know when you want to stop by.
"Edsal steel top workbench
craigslist reply b3b3
To
jjgmq-4874805041@sale
"Greetings , I would love to see it and buy it asap or within the next 48hrs.I have an appointment with my doctor later in the day and i dont know how long am staying in the hospital i would have loved to check on it today.
Email me at Jackrh4@XXXX.com and let me know your arrangement when we meeting for the deal
Jack Olsen"
__________________
Wanted
OTC 949 1/2 bearing splitter
OTC 915 steering wheel puller
Wilton Date Thread
https://docs.google.com/spreadsheets...M60/edit#gid=0
bluebolt is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
