Patrick Boyle
I'm shopping for a in/lb wrench to cover the lower scale, so I'm trying to make sure I'm covered. My confusion is related to what is actually meant when manufacturers say "x% accurate to 20% to 100% of range." With my understanding, if you were looking at a 5-75 ft/lb wrench, it's only accurate above 19ft/lb. The scale actually covers a total of 70ft/lb, therefore 20% of 70 is 14. So the bottom 14ft/lb of the range that the wrench covers is not accurate to spec.
I've seen a lot of people calculate the percentage starting at zero no matter what the wrench actually starts at. For instance, I've heard that a 20-100 ft/lb wrench is accurate across the entire range because 20% of 100 is 20. I've also heard that a 10-80ft/lb wrench is accurate above 16ft/lb because 20% of 80 is 16.
I hope I'm explaining this well enough. Which is correct?
