onetechyguy
- Joined
- Apr 23, 2011
- Messages
- 90
Hi, I have an old house with a 100AMP fuse box in the kitchen and have no room to upgrade to a newer panel box. I am having a new detached garage built in bridgeview, Illinois and am trying to figure out my options for adding electric. Would code allow me to feed a second panel mounted in the garage off off the meter base by changing it to a double lugged base to feed my house panel and garage? I have read that NEC 230.71 would allow that to be done but don't know if bridgeview follows that code or the chicago code. Otherwise I might have to add a 60AMP subpanel box somewhere in the house and feed it from the main panel fuses that the A/C uses but change the fuses to 60AMP & use #6 wire. Then run #6 out to the garage to another box. I could live with 60AMP but would like 100AMP if its possible. I thought about having another service put on the garage but comed said I would be billed at a commercial rate which I want to avoid. Any ideas, advice? thanks
Also, What about the 3/4 pipe that is going to my A/C disconnect box outside, can that wire and box be changed and from there the subpanel box in the garage be fed?
