Old Craftsman Radial arm saw I restored
afx
Houston Tx
This is actually my second restore although this one took me considerably longer, probably because of the effort I put into it and partly because I was remodeling my garage concurrently.
The shape of this saw was much better than the last one I bought (the 113.29002) since it was about 10 years younger (1968). while the condition was a bit better the motor was nearly unusable, thanks to the help of OWWM I was able to dissemble the motor, replace the starting solenoid, both rotors, most shims and the baffle plate which had come lose and was making a nasty rattling noise.
When I finished the motor and put it all together I like how well it worked so much I decided to use it as my primary RAS and sell my other one. While lurking the photo depository I came across someone who had built a RAS table that I fell in love with, unfortunately there were no plans online so I winged it but it came out nice, the table is removable and replaceable, you can remove the fence and use a miter saw with riser blocks as well as replace it easily for dado's etc. its also the same height as the table saw I built a drawer below to hold all my blades as well as RAS accessories I have collected over time.
While my last restore I went for a little more modern look, this one I wanted to keep it as close to how it looked when it left the plant as possible, although I did take a few liberties like the logo and polishing all handles chrome. For some reason, you cannot find the CRAFTSMAN "CROWN" logo ANYWHERE so I had to re-draw it myself to cut the mask for the paint.
I just finished tuning it and it cuts really well, I think i'm going to buy another blade for it or get the ones I have sharpened, i'm excited to use the accessories, as you can see I have the drill chuck on, I'm going to see how well the planer attachment works tomorrow.
Zrexxer
Pflugerville, TX
Ya mean like this one? All ya had to do ws ask! lol! Nice work - nobody loves RAS's much anymore, but that's a classic.
Packard V8
Spokane, WA
Those old Emerson-built RAS were solid. I've been using one for forty years. Glad you are taking such good care of yours.
jack vines
Ric in Richmond
Richmond...duh
Dad has one of those....at least 40 years old since thats as far back as I can remember!!!
I need to do that too it if I inherit it one day....Take your time dad!!!!
BlindViper
York, PA
If you get a better quality blade you will be 10x happier with how it cuts. Very nice job btw!
justanengineer
Motor City
There has been one of those in the sawmill since new. Its been used largely for cutting up "stickers" for spacing/stacking lumber to dry, day in and day out. Works great, but cant remember ever having a use for it other than that.
Nice resto btw.
Virgil Cain
Did you have the vertical and horizontal arms plated or are we just looking at the result of a lot of polishing?
rcsec
Tampa Bay Area
My hat is off to you & your work...that is just BEAUTIFUL!
I picked up one of these and it's in the queue for a restore. I may contact you offline for some tips or advice. That aluminum cover on the arm...was it stripped completely and repainted/labeled or were you able to save it? As for the logo you recreated - I'm stuck on another tool with the logo recreation.
Let me know how you make out with attachments & thanks for posting!
A
afx
Houston Tx
Woofabear, a lot of replying to do!
Where the hell were you when I was looking for it! Where did you find it?
That is actually a junk blade, when you calibrate the saw you have to run the blade over a metal t-square over and over which trashes the blades. That being said, I do have a few dewalt blades that I really like.
a BUNCH of polishing.
Shoot me a PM anytime, im more than willing to help with any questions, As for the plate cover, I masked off the measurements and buffed everything else off besides the sears logo on the front and the measuring marks.
Is that a drill chuck on the end of the motor?
Yup, it has a 1/3 arbor on the other side that you can use to attach all kinds of stuff.
Thanks for the kind words guys!
VWandDodge
How did you clean the arms? I have a similar saw (circa 1967) I inherited from my dad. Unfortunately, he stored it in a pole barn for 15 years or so, causing the arms to rust. I've used it a couple of times, but it really needs to be torn down and thoroughly cleaned and rebuilt.
rockchucker
Seattle WA
Wow! She's a beaut!
We used to have that exact Saw as the "Little Guy" in my Wood Shop in High School. Or very close to it at least. It always cut true. Not much play in it at all.
A
afx
Houston Tx
Well first you're going to have to get rid of the rust, you can use marine gel or what I did was just sprayed it down with wd40 and took an abrasive brush drill attachment thing to it. once the rust was completely gone I took it to my buffer and spent about an hour going from white to green on the compounds. It was nearly a mirror finish when I was done with it.
Here is a picture of it
file.php
A
afx
Houston Tx
Now as I said before, this is my second restore, the first one was WAY worse shape wise and rust. Here is how that one turned out.
Bull
I have a lot of respect for what you are doing.
Do us a favor: on the next restore, take a mountain of pics, and do a step by step for us. I'd sticky that.
Kirbot
New Jersey
Very nice job!
I've done a few similar restorations (most notably an atlas 10" metal lathe) but I've never tackled a radial arm saw
VWandDodge
file.php
Yes, I realize I'll have to completely tear it down, which is the plan. I figured Naval Jelly would help with the rust. Thanks for the hints and extra pictures. Your saw looks great. I actually had someone tell me if I ever wanted to get rid of the saw he'd gladly take it off my hands. I laughed, and told him there was no way I would get rid of it.
GunnieB
PA
I know this was from 2008 but I recently received an old craftsman radial arm saw and the locking bracket in the collar that allows the arm to lock at different angles is broken and I cant find a replacement. Seeing that you have restored them I thought you could point me in the right direction.
Take and post pics of the part you need: I'll see if I kept that when I stripped a couple of recall RAS's
jywilli69
Raytown, Missouri 64133
I am in the process of picking one up similiar to yours. I really could use some pointers on how to fix it. Not a mechanic, but really wanting to learn. If you can give any help, that would be awsome. Here is a picture of the one I am in the process of getting.
:bowdown:
Thank you for your time.
Jayson
