I have begun work on my garage. Pictures will follow. I'll try to document what I do (and what I should have done when I have the benefit of hindsight). Perhaps others will learn from my mistakes and successes.
So far, after buying my 15 year old house, I have installed some shelves, moved everything out of the garage that doesn't have to be there (a garage is NOT for storage, in my opinion), and have generally cleaned up.
My plan:
1) Fill cracks and pits in concrete floor.
2) Rent a "buffer" machine from Home Depot and get some abrasive pads, and go over the entire floor grinding a solution of TSP with the buffer. Some areas of the floor show water beading from a previously applied sealant that has mostly worn off, and other areas are worn and pitted, other areas are oil stained.
3) Rinse, and apply Muriatic Acid solution to etch the concrete.
4) Rinse, and make sure floor is clean.
5) Apply epoxy (I'm planning on using the Sherwin Williams Armorseal).
I've never done anything like this before, so we'll see how it goes.
- Patrick
My plan:
- Patrick
