How Harbor Freight Tried to Kill Me Today
Status
Not open for further replies.
williaty
Harbor Freight is the only local source for brass hex ******* (hex ******* are male-to-male close ******* with a hex section in the middle to us a wrench on). I figured that, since they were simple threaded castings, it'd be safe to buy them from HF to get the convenience of the hex ******.
Boy, was I wrong.
Over the week, I've been plumbing in my new compressor. Thursday, I got it up to pressure for the first time and left it sit with the switch off to see if it would leak down over time. 48 hours later, it was holding pressure perfectly. So I bled the little bit of water out of it and stood back up. I could hear a tiny hissing noise. Very annoyed that the system had suddenly developed a leak, I started hunting the noise down. I quickly localized it to the ****** between the tank and the shutoff valve. Sighing, I began to pull my head back with the intention of opening the drain valve and the safety valve so that I could blow the tank down and fix the leak.
Then it blew apart.
There was a tremendous noise, something hit me in the head, my glasses were ripped off my face, chunks of brass plumbing were shot across the garage hard enough to pierce the 5/8ths drywall, and I hit the deck like I was under fire. Once on the ground, I realized that the tank had let go but I figured I was either already dead the tank was going to hold and nothing I was going to do was going to change that outcome. Thankfully, the tank blew down via the now large hole without rupturing.
I honestly don't know if the ball valve hit me in the face as it was shot across the room or if it was just the force of the rushing air. I assume that if it had been the ball valve itself that had hit me, I'd have been killed at that range, given how weak the skull is in side of the temple. My glasses are bent to hell and gone, the side of my face hurts, and my ears took about 8 hours to stop ringing.
When I finally found all the pieces, the hex ****** had sheared cleanly at the transition between the threaded portion and the hex section. It looks for all the world like it was cut with a pipe cutter. Perfectly clean. I replaced that hex ******, and all the HF hex ******* in the system, with generic close ******* from Lowes. Out of curiosity, I cut one of the Lowes ******* in half at the same point that the HF ****** had failed. The wall thickness of the Lowes ****** was at least twice, possibly three times larger than that of the HF ******.
Needless to say, anything to do with compressed air is now on my list of "Things I Won't Buy at Harbor Freight Because the Commies Are Out to Get Me"
W
williaty
your first mistake......harbor freight...I wouldn't buy a turd there....
A lot of stuff from there has served me well, used professionally on a daily basis. There's definitely a list of stuff it's not wise to buy from them, and it's growing.
W
williaty
Figures. The lowe's fittings were probably from the same COO too though.
Yeah, I had the same thought. Even if I ordered them from McMaster, who knows where they were made. I'm considerably more at ease with the Lowes stuff, though, due to the MUCH higher wall thickness.
nate379
Palmer, AK
Literally almost got messed up at a Harbor Freight.
They had a big vice (biggest they sell) on a display shelf and it wasn't secured at all. It had been pulled right to the edge apparent because someone bumped into it as I was standing next to the shelf and it fell about 4ft onto the floor. I moved my foot out of the way so fast that I lost my balance and face planted right into the vice. Had I not moved my foot it would have landed right on top of it.
AND it happened to be my left foot, the one I had got surgery on just a few months prior (exploded my toe when something else fell on it)
I did get a $50 certificate out of it though. :)
Danglerb
SoCal
I'm having a hard time understanding what happened. You wanted a male npt where you had a female npt, and used a male/male hex ******.
What exactly broke?
Why did it have so much force, I'm thinking 165 psi on the tank, 3/8 NPT, force pushing out maybe 30 lbs?
torqueman2002
Man that was a close one! :shocking:
Reading it brought home the thoughts I have each time the Campbell Hausfeld is powered up in my 2.5 attached garage and I'm working nearer than 50' from it; that's almost always!
Sure wish I had room for an enclosed room for it.
Be safe, your family needs you. :)
VWandDodge
In other words, you place price above value and are determined to continue wasting money and time in an effort to discover everything that's inferior.
Morrisman
Angeles City, Philippines
What exactly broke?
The force would be the 'equal and opposite' theory, with the air rushing out like a small rocket taking off, not just the 35 pounds loaded on it statically.
Sounds like it fractured on tightening and the air pressure simply worked on the cracked material until it popped.
We've had a few brass ******* break here offshore, on a cooling system, but it was because they were NPT screwed into BSP valves and had been tightened down to the end of the thread, because NPT and BSP aren't compatible, so it basically levered the final thread open until it cracked.
NWphotog
Much better to waste large amounts o money on severely over priced products that are sometimes junk too. DOH! :shocking:
Sterff
PA
That's another reason why I used all copper fittings when I plumbed my airlines.
bobadame
Brass has a grain structure similar to cast iron. Thin sections fail exactly as you experienced. This doesn't limit that kind of failure to just the things you buy from Harbor Freight.
timesrgood?
Good wake up call, buy only name brand American fittings. At least when they make them in China they have some sort of QC and design requirements. Chinese businessmen will cut corners on anything to make more profit. Brass is expensive. If they can put plastic in baby food to make money, what else you think they will do?
I never been to a HF and never will, it is repulsive to me in this economy. Yet people flock to them like lemmings going over a cliff.
transamfan
I hope you avoid Walmart then, too. It's the HF of every non-tool item.
:bowdown: perfect!
I too have had brass failure from HF. a simple ball end air chuck, the whole ball end broke off right in front of the piece of brass the quick connect fitting threaded into. it was very thin walled, I bought a Milton to replace it. I will never buy any air tool or fitting from HF. They do have some stuff though that is functional at a value. I try to buy american but its very hard these days, at HF and at wal-mart
RangerDaleXp
Commiefornia
It really don't matter where the part came from. It could have come from Home Depot or the corner hardware store and sometimes parts just fail. I have had mostly good come from HF but have had a few bad things as well...:thumbup:
padronanniversary
Minesooooooota
MrMark
Southern Cal.
I don't see how you could have done that. I am unaware of copper *******, for example. If you have a flex hose connection to a metal airline you are going to need brass or steel ******* and couplers. Maybe you used red brass. It looks like copper.
timesrgood?
What I buy at wm is all made in USA.
HF and tools are not the same thing at all.
If you use brass from a reputable American maker it will be OK. Of course it can be weakened by overtightening, but the American fitting is designed for the purpose. The name is on the fitting if there is a problem. The Chinese businessman selling to HF makes it to save money, if you die too bad so sad.
archirelic
texas
again with this tired, old mantra? well then I sure hope your computer you're using is not chinese, or your router, or anything else under your roof.
get out of here.
Lookin4'67Galaxieconv
Atlanta, GA
Yeah...I understand 355 Americans died in April alone (the last month figures are available) from weak Chinese made fittings. :spit:
Status
