r6_cannibal
Not sure if i should post this here or in the fabrication area, but anyway...
I'm building a new bench that I would like to last me for a long time.
some numbers real quick first...
the steel
2"x2" @ 1/4" thick = 5.410 pounds per foot
555.5 inches total material for frame = 46.3ft
46.3 * 5.410 = 250.483lb
125.2415lb per side
from the pipe to the contact point of the castors is 5 inches, with a 12" lever to rotate the mass should be about 52 pounds of force to lift the table.
would galvenaized pipe be able to withstand this type of rotational force?
I want to put a couple holes through the pipe and thread them to screw in the stem of the castor. I have this kind of setup on a small wood bench but the weight of this new metal bench is much greater.
I also wanted ideas on what I should put between the castor pipe and the hole cut into the leg of the bench. I was thinking a bushing of some type or another larger pipe that the castor pipe sits inside of and then grease the two friction surfaces so it rotates easily. I'm not really sure if i'm making myself clear here, the 1 year old kept me awake most of the night and we're out of coffee
I'm going with 2x2 square tube for the bench so i can insert a 1 1/2 inch square stock onto the top pieces that run the width of the bench. even the backsplash should be removable so i can have a nice unobstructed work surface when i need it.
the T-track isn't in it's final location, and there's going to be a removable piece in the center where a miter saw will sit flush with the bench, as well as a plate where an inverted router will sit for use as a router table. I'm open to ideas and suggestions of course!
Thanks in advance, I can't wait to get the design on this bench finalized so i can start building it.
the steel
125.2415lb per side
