Questions about restoring my tool chest.
1Garageman
Columbus, Ohio
I just bought the base of my tool for $20!! I already have a top that will fit it. I want to give this a fresh coat of red paint to make it look better and match the top piece that I have. I started sanding and using a wire brush attachment for a drill on it. I have a few questions.
1. How much of the old paint do I have to take off of it before I can paint it?
2. What kind of paint do I need to use on it? I'd like to use my air compressor's painter to paint it instead of stuff from a spray can.
3. The silver strip that lines the outside draw is missing on the first one. Can you buy these things?
Thanks a lot guys:beer::thumbup:!
1st Pic is the one before I started on it.
2nd is the silver strip that I need for it.
3rd is the sanding/wire brushing I have done so far.
Granite Guy
Florida
no idea about the silver strip replacement.....but maybe find something that looks similar, and just replace both so they'll match.
imo only remove the paint that is rusted or heavily scratched......just a light sanding and thorough rub down with some xylol and spray away. To stay cheap, buy enamel door paint at Lowes or HD....a quart ($10) should do it fine
Granite Guy
Florida
oh, and thin the paint down with xylol before you spray....it will be a much better mist....just be sure to not coat it on too thick on your first few passes or it'll run. I usually will mix 2:1 paint to xylol
1Garageman
Columbus, Ohio
I am going to have to get some xylol. I have never heard of it before. I am a virgin when it comes to restoring these things, but i'd love to get into it!
Thanks for your help Granite Guy!:beer:
csp
Franktown, CO
You'll need to feather in any scratched/rusted areas unless you take the entire thing to bare metal if you want a consistent, smooth finish.
A wire wheel isn't the best tool for the job either. A dual orbital sander would be much better, finish wise.
1Garageman
Columbus, Ohio
I wired brushed and sanded it some more. I don't see any big scratched on it. I hammered in the edges that were sticking out and a couple of uneven edges. I think I am ready to start painting it.
rickairmedic
louisville ,Ky
Garageman if you have a tractor supply nearby I would recomend using tractor and implement paint from them . You should be able to get a quart of Massey ferguson red and a pint of Naptha and a small can of enamel hardener from them for less than $30.00 . There will be mixing directions " suggestions " on the cans . I would also suggest shooting a coat of primer on the box before painting it to cover the bare metal first . This you could do with rattle cans real quick no more than 2 cans to do the whole box let it dry then lightly sand with 320-400 grit paper wipe down and then shoot the red on it .
Rick
1Garageman
Columbus, Ohio
Rick
I have a tractor supply company about 1.5
miles away from the house :bounce:
and I just got a $10 coupon if I spend $25.
So I might just do that. I had no idea that they sell paint and stuff like that.
Thanks for the info:thumbup:
1Garageman
Columbus, Ohio
I did some research on "Enamel Hardener Paint" because I have never used it or heard of it. It sounds a little bit to dangerous for me to use. On some websites guys are saying if you inhale it that it sticks inside your longs and thickens them and stuff. I only have/use a regular air mask over my mouth and nose. And I already have asthma! LOL.
I might do everything but that.
TeamTruett
Mid Hudson Valley NY
Ive been down this road. Found an early 70's craftsman 10 draw cabinet at a garage sale for 30 bucks. I prepped like you did and primed with rustolem "professional" gray and top coated with Rustolem "Hammered" finish. I got a little carried away sweating the details and filled and sanded small dents. I painted the body one color and the drawer faces another. The hammered texture of the paint hides imperfections. Those metal strips will brighten up nicely with compound followed by polish.
rickairmedic
louisville ,Ky
Garageman I use a regular cheap mask when painting and have never had a problem . This is a painters mask mind you not one of those cloth dust masks . They are cheap at Harbor Freight and do the job if your not sure about the hardener then just get 4" foam rollers and roll it on it will still look great when done.
Oh yeah if you cant find a matching drawer pull just look at your local autoparts store for the stickon chrome trim :D.
Rick
1Garageman
Columbus, Ohio
Rick
Thanks for the tips on that Rick!:thumbup:
1Garageman
Columbus, Ohio
Very nice! I just bought a box that is similar to that. Keep up the good work!:thumbup:
Thanks!
Here is the tool box I have restored that I am going to bolt put on top of it. I can't wait:bounce:
I restored it earlier. I got it at a estate sale for $30! So together this will be $50 for the storage units. I'll add the rest up later.:thumbup:
BigAl62
suburbs of Chicago
Your box looks like a Craftsman homeowners model, try Sears Parts Direct for the missing trim.
1Garageman
Columbus, Ohio
OK, I finally got a FREE weekend where I could put 3 coats of paint on it and join the two tool boxes together. Check it out! I flat out love it:bowdown:
I am going to use this tool box mainly for my air tools and drill bits and stuff. It has so much room I can put everything in there and organize it nicely.
Thanks for your help everyone.:thumbup:
