Hands on new Earthquake line: 1/2" Impact
pipsters
USA
I picked up the 1/2" Earthquake impact today from HF. $100 + 20% off. I'm sure it will go on sale later for $90 but the $8 I'd save, I wanted and needed it now.
I have owned and used hands on: Kobalt 1/2", "old" Harbor Freight 1/2" Earthquake, 2135QTiMax, 2135TiMax, and Aircat 1100k, and now this "new" 1/2" Earthquake (made in Taiwan for those wondering).
My impressions....this thing rocks. As much possibly slightly more power than the old Earthquake (11/29/2011 edit: it is more powerful than the old one, on a side by side comparison), but MUCH quieter, a little lighter, SMOOTH, and settings so easy to use a cave man could do it. The folks who got screaming deals on the old line, well, I'm glad I didn't buy it then. I much prefer to pay another $40 and have this new one. It's just ergonomically better.
It beats all my other impacts hands down, including the 2135qtimax AND the Aircat 1100k. Yes you read that right, I don't care what specs say, but it hits harder than both of them. How do I know? I used a 30mm crank pulley bolt and went to town. I know it's not scientific, and will probably be thrown out in a court of law, but my new Earthquake could tighten the 30mm nut down to where the Aircat 1100k could not take it off. My 1100k, when going flat out for 20-30 secs, could not stop my new Earthquake from being able to undo that nut. Plus, just holding on to the end with the socket, the Earthquake hit noticeably harder and I could not keep my hand on the socket. The 1100k, I could (barely though). I think both are very close in torque output. This was at 90 psi at the tool, 3/8" line, and high-flo connectors.
The Aircat 1100k actually was stronger than the 2135's, but the 2135's felt better built and were much smoother and lighter. So pick your poison I guess. After handling the Aircat 1100k, I would prefer to use the 2135 series daily, and this Earthquake would be tough to use daily to do it's higher weight over the 2135 series.
So to sum it up, in terms of power (most powerful to least):
  1. Harbor Freight 1/2" Earthquake
  2. Aircat 1100K
  3. 2135TiMax series
In terms of ergonomics (better to worse):
  1. 2135TiMax series
  2. Aircat 1100K
  3. Harbor Freight 1/2" Earthquake
In terms of noise (quietest to loudest):
  1. 2135QTiMax
  2. Harbor Freight 1/2" Earthquake
  3. Aircat 1100K
  4. 2135TiMax
In terms of value (most to least):
  2. Aircat 1100K
  3. 2135Timax series
Matt018
Nice review, I'm gonna be picking up a 3/8 earthquake soon (new kind) and some craftsman deep impact sockets to replace using my old 3/8 to 1/4 hex adapter so I could uSe sockets in my cordless screwgun. To be honest I am glad I waited on buying a 3/8 so long the cheap 20$ one has so so reviews and looks really old fashioned yet dumb and I just couldn't get over the silly color scheme of the old earthquake but the new ones have that great IR look and have more power and for my application I would be using this almost as much as a mechanic. So I'm happy to see an affordable tool with better quality
P
pipsters
USA
Thanks! I did look over and handle the 3/8" version too. It was also just as nice, light, and seemed as well built as the 1/2", and I was tempted to also pick up the 3/8", but stopped short. I can buy the 1/2" and 3/8" for as much as I paid for my Aircat. I wanted US made guns but the only true US made one is the Snap-On, others are "assembled in the USA" which is fine but they perform worse than this Earthquake. I'm OK paying more for the same performance, but not more for LESS performance.
DrkMtnDew
In the store it looked like HF copied another IR design... then added a couple pounds.
fordbroncodave
Website says 6 lbs. Seems accurate.
I wonder which IR gun they copied this time, I would love to try them out side by side.
tried to copy the titanium series but it might be similar to the quiet series that isn't very popular
P
pipsters
USA
I am blown away that with my compressor setup (25 gal 150 PSI) these Harbor Freight guns are better than IR. You would think the IR would be better as they are the OEM. I really wanted to keep that 2135QTiMax, but I just couldn't justify it.
DrkMtnDew
i don't think it is a copy of the 2135 series. if anything it is a mix of the Thundergun and the older 2131 series, minus the forward/reverse buttons.
Wesley B
No where
What weight is the IR timax? I REALLY want a mg725, but I might have to buy this one instead. :(
P
pipsters
USA
The TiMax is around 4 lbs. I have read that the 2135TiMax and MG725 are of similar power, if that is the case this might even beat both of them...if not it will at least run with them neck and neck. I waited patiently for an MG725 on eBay but couldn't touch 'em for under $300, I just wasn't willing to buy a used gun for that much.
woody 73
The Great State Up North
I was just curious but could you tell me how hard/easy is it to fix if it stops working?
The IR air tools are fairly simple to get kits for,(not sure about the other two brands).
P
pipsters
USA
I have no idea. Honestly, guys have used the older Earthquakes for years without issue. They are fairly simple. I read a review on Harbor Freight that someone said they bought an Earthquake and used its parts to fix their IR gun so you might be able to interchange the parts!
IR would probably be better prone to rebuilding, but to rebuild it with hammers and seals and such you are looking at the price of a new Earthquake...
I doubt Harbor Freight is really in the parts business, but personally I have never tried.
pcpro15
I paid the extra $10 for the 2 year warranty on the clearance 1/2 hf for my father. When it kicks the bucket, i'll have to try out the new one :)
Wesley B
No where
Yeah, maybe I'll just wait out for a MG325 and just buy the cheaper 1/2" drive hf.
DrkMtnDew
i would imagine that HF never intended for these to be rebuilt, just replaced. i guess when one craters, hopefully the owner will try to rebuild it and post their success/failure story for the rest of us.
P
pipsters
USA
Out of curiosity, what is the typical failure/wear point in an impact? Hammers?
DrkMtnDew
You are right it would be cheaper just to throw it away and buy another air gun. I don't seem to have much luck with the HF air tools.
That makes two of us. longest time i've had one was year and a half.
smogtech
i still have a warranty on my old hf eq gun. think they would give me a new one for exchange?
Danglerb
SoCal
One of the reasons I bought the old HF 3/8 impact was the guy on ebay selling tune up kits, set of new seals and orings, for $3.
Some impacts have had issues with anvils, and replacement is like half the cost of a new gun, but I've seen a lot of beat to **** IR 231's that are good as new with seals. So far we have not seen enough HF impact fails to guess what might go bad.
Wesley B
No where
How hard is the knob to turn for forward/reverse? I need to go and put my hands on this thing.
earlthegoat2
SE GA
Not trying to take anything away from your new tool but ALL impacts hit harder when they are brand new. They lighten up a bit with use. Maybe an update would be in order after it has been put through the paces.
P
pipsters
USA
I'm not the one to do that, I don't use it that much
mrholeshot
MEMBER EMERITUS
Power is one thing durability is another. Lets see how well it works in a busy shop a year from now. Dont like it take two hands to change direction. Poor design
Ign
Butte Peak ND
Agreed here. I've had plenty of low-dollar tools where I thought I got a screamin' deal after the first use. Skip ahead a couple of months and I'm wishing I had bought a better brand.
Damian
Auburn, Georgia
Exactly what I was going to post.
My IR 2115ti 3/8" has been taking daily abuse for 7 years now. My 2135ti has been taking it daily for 5 years.
Let's see an Earthquake gun make it that far reliably and still have full power, then we'll talk. The problem with a lot of these cheaper guns that are strong out of the gate is that they don't last. My partners Aircats were STRONG when he first bought them. 3 years later they're worn slap out and need rebuilds.
back2class
Sounds like a great gun for a DIY guy. Time will tell if it is as good as the pro level ones.
RangerDaleXp
Commiefornia
I have not personally used the new line yet. I also would not call something a DIY tool because it is not stamped "IR" or "Snap On" as well. There have been many professionals that have ran the old EQ line for a number of years in the professional fields with great success and considered the EQ line to be Top notch. There is a Tire shop in my area that have some of the EQ 1/2 drive models that have been running for several years now. They are so beat up you could barley tell who made them. This shop runs 6 days a week.
It is very true that it is way to soon to tell on how well the new EQ line will hold up until they get some more time in the field....
P
pipsters
USA
I didn't take it like that. I think he was being genuine. He is also 100% correct. The old Earthquakes were proven, reliable, and durable. However they were heavy *******!
We won't know for at least a year or so if these guns are durable. However, just handling it, it feels very stout and well made to me. I'm glad I got it, and for my occasional use I doubt I will ever encounter any issues.
After owning several guns, including the venerable 2135TiMax series, and the Aircat 1100k, I can say I really like the new Earthquake the most.
finley31
Huntington, WV
When you say it is lighter, does that mean the body is now plastic? What I really liked about the older style was the abuse it could take physically. We have a few of the older 1/2" and 3/4" drives we beat on in a fab shop and in steel mills all the time and they have held up great. That's not to say I haven't seen them break, but the break/use ratio is so lopsided that we can't justify spending more on a higher end model that is gonna get thrashed anyways.
