Another Wilton vise is restored
Swan
Winona, MN
I just finished restoring my new Wilton C1 #1845 vise (c. 1955) 4.5" jaws. My friend gave it to me for photographing, listing, selling and shipping 20 of his vintage vises. Here it is before:
After:
All said and done it took 8 hours of my precious free time, but the price was right. It was functional, but I completely broke it down, cleaned, degreased in parts washer, wire brush on disc grinder, soap and water, lacquer thinner, automotive self-etching primer, Rustoleum Hammered Verde Green spray paint and two coats of Krylon clear. The jaws and pipe holders were bead blasted and I installed and peened over two new handles for the swivel nuts, greased the main screw and swivel points and oiled the large body pipe. It looks good and works beautifully. I left the main handle as is even though it is slightly bent because it has character and history. It is overkill for my little work room and I am going to buy or make two aluminum jaws for I mostly work on vintage motorcycle parts.
There are many helpful Wilton restoration threads on this forum and my restoration was fairly straight forward with the exception of the two pins holding large threaded tube inside and the jaw screws. The two pins took much soaking in penetrant then heat but could not be drifted or pressed out, so I ended up drilling them out. They were replaced them with two 1/4" diameter 1" length pins. The jaw screws an pins were a nightmare and after a week of PB Blast, ATF/acetone and Marvel Mystery oil treatments, heat, impact driver, etc . I ended up having to drill the screws out; a very slow process with lots of cutting oil, but I managed to keep the original threads, chased them with a 5/16th tap and fitted new allen head bolts and pins.
I did register it on DavidB's Wilton Bullet Vise information page here on GJ forum.
Another vintage American made tool ready for a lifetime of service. I love it.
Displaced Hokie
Western NC
Very nice job! I've done two, and I always take them totally apart and down to bare metal like you did. As you've shown, it pays off in the results. That hammered paint is awesome, isn't it!
Kirbot
New Jersey
Great looking restoration, but what really impressed me are the pictures!
Excellent photography.
What are you using as a background?
Swan
Winona, MN
The grease was not as nasty as others have found. Someone had been inside before me and the grease was relatively clean and new.
Swan
Winona, MN
What color paint was used?
I like the color
Thanks, it is Rustoleum Hammered Verde Green spray paint. There is much chatter about this paint on this forum. Most agree it is extremely close to the OEM color of the early Wiltons. Some have questioned its durability, chip resistance and failure when exposed to cutting oil and other solvents. I decided to add two coats of Krlyon clear coat to protect the paint. I am using the vise and and can always touch it up in the future if need be.
gilbo
what chips, u mean u actually suppose to USE the vise, i thought it was only for show only after u restore it
:bounce::bounce::bounce:
Swan
Winona, MN
The pipe jaws came with the vise and I used cold rolled steel from a welding shop.
Hchris348
@Swan did you ever find a date stamp on the slide pin on your Wilton ? Just curious because I have acquired this same vise but can not find a date code stamped on my to save my life and it’s kinda driving me mad lol
Jayman17
Seattle, Wa
FYI,
Don’t know if you realized it but you posted in a 10 year old thread
