Butane soldering iron experience/recommendations?
slipjointed
I'm in the market for a new Butane soldering iron/torch.
The only two I've used enough to make judgement on are the little $15 Bernzomatic they sell at HD/Lowes, and the Master Ultratorch.
The little el-cheapo Bernzomatic is a workable iron, but the torch on it blows out even from the slightest movement, let alone breeze. It solders well enough, but has no auto-ignition and is a pain to lite at times. It's a bargain for $15, as long as you don't plan on using it as a torch, and as long as you always remember to carry a lighter or matches.
The Master Ultratorch has been around for a while, and is a well made unit. I really don't think it's worth the cost though. It was what we had at my old work, and I've used more than one unit on a regular basis. The torch worked a lot better than the cheapo that I have, but even with auto-ignition, it was a pain to light, and would never fire up on the first, or even sometimes second, third, and fourth tries. It also had a 4 position heat setting, but it might as well have been an on/off switch, because it had little to no effect on the gas flow.
I've been looking around and it seems that the Portasol units are the ticket. They're made in Ireland from what I can tell, and the kits they sell them in (if you opt to buy the kit instead of the iron alone) come with a bunch of different useful tips.
The pro version comes in 75w ($70 kit) and 125w ($88), that appear identical in functionality, just different in size and total heat and runtime (and cost of course). I would lean towards the 75w not because of cost savings, but because it's a compact unit, and I will use primarily for electronics repair.
There's also a nice unit made by Steinel, and if it's anything like their digital heat guns, it's got to be one hell of a tool. I've had nothing but great luck with Steinel, but their kit also costs twice what the portasol stuff costs.
It's kind of a long shot to see if anyone has experience with the $150+ Steinel unit, but I was hoping at least one or two people here had experience with the Portasol, specifically the 75W. The 125W got good reviews on Amazon, but there are none for the 75W model.
Any other suggestions are welcome also. FYI the must-haves are auto-ignition, point tip as well as chisel tip, and a torch that functions well so I can use it for heat shrink. A heat shrink shield is a plus.
Thanks ahead of time, hopefully I get a couple bites on this thread. :beer:
slipjointed
I've used the Protasol Pros and they're very good. A little bulky but fine, they heat up very quickly too.
I'll be buying one for myself soon. (The 125w.)
Thanks for the reply.
That's exactly the kind of input I'm looking for.
One thing I just noticed is that the 125w Portasol comes with an attached flip-out stand, whereas the 75w comes with a little metal stand that is perfect for getting lost/tipping over/making you angry. :lol_hitti
PrecisionTools
Victoria, Australia
Danglerb
SoCal
I have two of the $15 variety, but mine have a striker just like a cigarette lighter has, and I have no clue how you might blow out the flame that is behind a screen. Never had an issue with them, only use them for small quick jobs, otherwise I drag out my 40 year old Weller magtip and plug it in.
diesel research
gulf coast, TEXAS
I have the $25 benzomatic from HD. It has auto ignite and a bigger flame capacity. Has heat gun/soldering iron tips, but I never use them (and may have lost them)
Use it daily to apply heat shrink to wiring splices, with open flame. Obviously, that is not acceptable for a circuit board or small electronic grade wires.
slipjointed
You might have missed it in my post... I mentioned that the $15 Bernzomatic irons work perfect for soldering. I have problems with blowing out when in use as a torch, which is a deal-breaker for me, as the primary reason to carry a butane iron (other than portability/cordlessness) is so that I can both solder and heat-shrink with one tool.
In fact the reason I am buying a new Butane iron and have made this thread, is because I am replacing the $15 special with something that won't blow out when in torch mode.
slipjointed
The $25 one doesn't blow out so easily unless you are in front of the shop fan. (happens occasionally)
I might take a look at that one then. Most of my environment is pretty sheltered, inside electrical panels and such.
The $15 one is just absurd, like if you move your hand at more than 1 inch per minute, or if you had too much coffee and are shaking a little, it will blow out. The soldering part works like a charm though.
Racr350
Rochester, NY
I've had no problem with my Power Probe branded one. Heats up quick and has multiple tips to use in different scenarios. Think i paid ~$80. Was awhile ago, so not 100% sure. I do know i bought it off the Matco truck.
DrkMtnDew
didn't have much luck with the small $15 one from HD/Lowes. the $25 one is a much better torch.
caseyjw
Go with the Weller portasol. All the guys in my shop have the Master ones and they hate them. They all lust after my Weller. The difference? The master ones don't light very well at all, by the time they get their's lit I am already soldering.
pfbz
I should also note that cheap butane will cause any torch to run crappy.
How exactly do you know if you are buying non-crappy butane?
Getting ready to order a portasol butane iron...
GoBlue
Under a car...swearing
I have this tool. The first one i got went bad the third time i used it. My Snap on guy swapped it out for me and i have not had a problem since. Very nice tool
machine_punk
Napa Valley, California
I had the one from Radio Shack (not sure who builds it). Sound like the cheaper one you guys are talking about. I just always used the heat coming out of the side (at the screened area) for heat shrink tubing.
M_P
ImportTuner
I bought this Bue Point Butane Soldering Tool in 1991 .. still have not used it yet ..
lestat
UK
I can recommend Iroda. I have a Blue Point torch which is a rebranded Iroda solderpro 180 (180W). I was so happy with it I went and bought another one. Really good for thick solder joints. Or you can go regular with the solderpro 120 (120W).
Have a look on their website, it's all laid down pretty well.
Gixerfixer
England
+1 Snap-On agents sell these as there own in the UK :thumbup: gone through a couple of tips with mine but had it for a number of years and it gets plenty of use :) good at curing wire Heat-Shrink too :bounce:
Skyline
I have this one as well, and it is great.
Jim85IROC
I've got the same one, and I've found it very useful for under-dash soldering, and I've never had a problem with it going out, even on windy days.
gt40mkii
That looks identical to my Archer irons purchased from Radio Shack back in the 80's or early 90's. They've been rock-solid. I THINK they take Weller tips. I have a big and small tip for wiring and electronics, respectively. I also have a small heat gun tip for shrink wrapping.
Highly recommended.
pfbz
Looks to me like Weller re-brands Portasol, and even uses the Portasol name on their product...
As far as I can tell:
  • Weller P2C = Portasol Propiezo 75
  • Weller PSI100C = Portasol Superpro 125
Same wattage, same spec's. I just ordered the Superpro.
Weller P2C ($30 on Amazon)
ProPiezo 75 ($34 on Amazon)
Weller PSI1000C ($69 on Amazon)
Superpro 125 ($50 on Amazon)
Weller also has the Pyropen series... Does Weller actually make these, or are they another rebrand?
pfbz
Buy the Snap-on unit. It works the best.
Looks to me like the Snap-on YAS22A is just another rebranded Portasol Propiezo 75/Weller P2C
And the YAS32A is a SuperPro 125/Weller PSI100C
Only a $30 or so premium for the Snap-On logo though...
