Why 20mm???
HubbaBubba
Saw a post for a 20mm wrench and was thinking....why?
I have never seen or come across a 20mm nut.
Please prove me wrong and tell me about why a 20mm socket or wrench is needed (other than having a full set) in the REAL world.
Here we go...
Stick
Alaska
20mm wrench is needed for line nuts on GM fuel filters.
I've used 20mm sockets on heavy equipment fasteners before.
andrew_94
Central NJ
...might be making myself look silly, but my metric wrenches go up to 19mm. i tried to change the flapper valve in the toilet and 19mm was too small
greasemonkey44
memphis
in the last week a gm fuel filter; ended up using an adjustable on it and turning the nut with the right flare nut wrench
Fedwrench
Valley of the sun
In addition to GM fuel filters, the AC fitting where the orifice tube goes on some GM trucks is also 20mm. I have never used a 20 mm socket though.:wtf: You could also ask the same question about 23 and 25mm too. Most tool makers offer a topper set consisting of 20 to 24mm. I could never justify the 23mm wrench. I guess it's like those Hansen socket racks, some prople just hate to skip sizes.:beer:
malibu101
Walnutport PA
FWIW- I have a 20 that's seen some use although I don't know exactly what it was used on. I also bought a 22 at some point in time that I used for something too.
I don't have a 21 or anything over the 22 and guess I never needed any.
Macneil
Sudbury, ON
Pitman arm retainer nut on Jeep steering boxes are 22mm.
I have a 20mm socket and open end wrench and they show some wear but like another said, I haven't the slightest clue as to what I personally would have used them on!
BerninicaCO3
I'd swear that the oil filter wrench for newer volvos, requires in turn a 20mm socket to turn the larger filter wrench.
I used to think the same thing about 18mm a couple months ago. There's always *something* that will take that oddball size.
djb2
Redwood forests
BMWs use 22mm on the M14 subframe fasteners and a few other locations. Asian cars tend to use 23mm and sometimes 21mm.
wheats71
ontario can
20 mm wrench also needed to hold brake caliper guide pins from spinning when removing
caliper bolt on 07 and newer trucks
eyeboltman
MA>
Good call Guys ....I hve used american for years now at my new job it's metic . don't think I used a 20 mm have use 18 ,19 ,22, 24 ,27,30, 36 .46 mm
on bolt and nuts all the time . 9 mm 1-2 time and all so used all the small ones these are on steel rolling machines . THE 18 mm is now fitting on the 12 mm thread nuts that used to be 19 mm now I dig in the new box of nuts 300-500 just to find the 19 mm? I read so place that this is done over seas as a cost saving ? and it OK .The bolts still see to be the same size The 28-29 mm ,20 years old in the box still looks new !!! I see that the car guys used different wrenches that I use in building machines and we have more room to work in them , not like a BMW or MB .. Thanks guys
hhuytho
MD
I did the same thing last week, an adjust table wrench for the filter nut and a flare nut wrench for the line. It worked fine. I'm hunting for a 20mm wrench though...
cotjocky
I know this thread is a couple months old, but...
I changed the radiator in my 1997 Chevy 3500. It has 2 oil cooler lines that go in to the drivers side of the radiator. Those two lines require a 20mm line wrench. Luckily I was able to break it loose with a 20mm open end wrench. My snap on line wrench skips 20mm (19mm-21mm). :-(
FergusonTO35
Winchester, KY
In my experience, a 20mm is just what you need for a 21mm or 13/16 lug nut that has lost its chrome cap, is rounded but still hex shaped, or is undersize from the factory. Some of your older Toyota one ton trucks use a 23mm lug nut. At the first dealership I worked for the parts delivery truck used 23's.
Notwerk
Slightly off topic, but has anyone ever generated a list of wrench/socket sizes and common uses for them? Might be a heavy list, but it would be cool to see which sizes have odd uses, etc.
honcho
Near Sodom & Gommorah (aka Wash. DC)
A bit off the 20mm topic, but related.
I know designers and engineers pull things out of the parts bins to use in their creations and manufacturers purchase sub-assemblies from other companies to integrate into their products but it sure would be nice if they would engineer their products to use a minimum number of faster types and sizes.
Recently, I changed the shocks on my Ford F250 and I was surprised by how many different size hex wrenches / sockets I had to pull out. If I remember correctly I used three different sizes on two separate bolt/nuts for the rear shock. I don't think there's any reason they couldn't have used one size for all the bolts and nuts.
Before the program was killed by the Defense Department, the Commanche Helicopter project touted that all unit level maintenance could be performed using a small toolbox with about 10-15 different handtools. Aviation techs will probably roll their eyes at that claim but designing equipment that will require maintenance and repair to use a minimum of different tools and hopefully no special tools would be appreciated by the folks that have to repair the equipment.
bgott
Houston, TX.
And WTF kind of an idiot designs a cooling fan that's run off the power steering system?
Lexus.
And Lincoln used to use power steering pumps that bolted onto the end of the crankshaft. Then they quit making parts for it so you had to adapt a regular P/S pump onto the engine. Plus they used to drive the wipers off of the P/S pump. I bet they did it so they could feel sophisticated.
tbobbo
Bismarck, ND
My 20 mm stuff is not really used all that much, but i use ot once a week. My 23 mm socket is used everyday. Fits the best on alot of new dodge lugnuts, 1/2 pickups mostly.
jvitez
Big Sky Country, Canada
Wrenches on lugnuts? Why scrape knuckles when I can use a long handled ratchet? I've never used a wrench for lugnuts.
And, AFAIR I've never used a 20mm anything. Larger sizes on my Dodge 3500, yes.
greasemonkey44
memphis
I have a Jeep Grand Cherokee ******* me off right now with 20mm fittings on the power steering lines.
automotive engineers, heard of it on a lexus....never seen it
its a cool idea; spins up with the engine; spins down with the engine
terrible execution
theres a reason everyone; even 1/2 ton trucks are changing over to electric fans
MattPersman
Indiana
i gotta tell you I have no idea why they made the hydraulic steering/fan setup. it was pretty reliable however. expensive when it does fail
