Mounting a Flat Screen TV in a Metal Building
tez929rr
Welfare, TX
So our 5 year old Samsung started acting up. We bought a Sony replacement; I figured if I could fix the Samsung it could move to the shop. Well, it turned out it took two capacitors and some soldering to fix the Samsung (total cost $3.46). So now I have to figure out how to hang the Samsung (it's a 43 inch) in the shop.
This is a picture of the shop building when it was first built (and empty) I'd like to mount it high on one wall - probably between the girt and the purlin near the middle window in the picture.
Any advice? I figure I can modify a wall mount or celing mount to make it work. Maybe use some angle iron or bar stock between the girt and purlin to hang the mount.
carap
OKC
I would do just like you said. Run 2 pieces of strut vertically between the purlin and the girt. Attach the tv wall mount to the strut.
hh76
NE Wisconsin
beam clamps and strut. Look through the B-line catalogue, can pretty much fit any situation with their parts.
DoyleDee
North Texas
Sweet!! It's amazing that you can fix tvs cheaply sometimes. My 27 tv in my bedroom failed a few days ago- but caps won't fix it- I need to replace the drive/video board. I bought the tv second hand from my neighbor that fixes them- that is where it is currently at.
I hope you get many good years more from that tv!!
99SVT
swing arm wall mount, in one of the corners, on the column:
It's mounted like this now, with same mount, just to the plywood:
isdavyy4u
90% of your electronic AV equipment failures are due to CRAPPY CHINESE capacitors.
Most only have a 2-5 yr life. Why the manufacters continue to use them instead of the high quality Japanese ones is beyound me. Guess they know we'll run out and buy a new TV every 3 or 4 years.
T
tez929rr
Welfare, TX
I hate to admit that I worked on tube electronic equipment as a young Airman in the late 70's
