I posted about this in my main garage thread, but I'll put it here for those who might just assume the thread is only about the garage.
I've never had a band saw. Or rather, I've had an old inoperative one sitting on a table for a few years, now. It's never been run. I got a motor and the right belt and pulley for it a while back, but I never found the time to get it up and running.
I'm making a pair of new wing uprights for my race car, and -- not having a decent aluminum cutting blade for my jigsaw -- I decided I would do the bare minimum to get the old Craftsman three-wheel working. I took a scrap piece of plywood and made a base, using a pair of old hinges so the motor's weight would keep tension on the belt. Then, since this is the internet, I put together a belt guard so people wouldn't chew me out. I used scrap from an underbelly piece I recently made for the same car.
I don't have a really good 'before' picture. But here's the saw brought up to the bare minimum to to turn the belt. The tires for the three wheels disintegrated as soon as I got it turning (it's a 1951 saw). But amazingly, with a little adjustment, it actually cut.
Wood or aluminum:
Belt guard -- temporary and embarassing:
Here's a plywood model of what I wanted to make. It's an upright to support a wing -- I wanted one a little shorter and a little wider than the previous version.
Now, I deliberately cut larger than the final piece. Which I'll explain next. But the cool thing was, the band saw worked. (The inside island pieces were done with a jigsaw -- by then, I got the right blades).
Now here's the oversized aluminum piece stuck to the correctly-sized aluminum model. I used two-sided tape to hold them together.
And here's the trick, which I read about in a thread on this forum. I used a router to trim the aluminum down to the exact domensions of the model. Aluminum shavings got everywhere, and I needed to wear a face shield and long sleeves, but it worked really well.
By my (low
) standards, that's a very clean cut.
And here's the piece, ready for some form of finishing (which I haven't decided on yet).
Wood or aluminum:
By my (low
