Ign
There's plenty of write-ups on the Dmax fuel filter. This one was particularly helpful to me first time I did it on an '08 GMC:
http://www.dieselbombers.com/chevro...es/11766-duramax-fuel-filter-replacement.html
Seems to me on the newer body styles ('07/08+) getting at it from the top is near impossible, so I opted to remove the inner fender.
First time I just used screwdrivers, pliers and Channelocks, and it's entirely fine to do so.
Recently I ordered some of the specialty tools that I didn't already have. I didn't think they'd make that big a difference, but it doesn't matter 'cause I'm a tool junkie. I ordered the three pc body clip set by KD:
http://www.thetoolwarehouse.net/p-14995-k-d-tools-41850.aspx
I found these way more helpful than imagined. I didn't think I'd use the flat blade ones which "pry" open, but quickly realized they are for removing "Xmas tree fasteners," of which there are two on this job. Wow, fastest Xmas tree removal I've ever done with minimal cursing.
I also got the Lisle WIF wrench (hell it's only like $6). I was impressed w just how well it fit the WIF sensor and it did make the job a little easier....or maybe I was just happy to use my new tools.
For a related rant, I just don't understand what GM engineers are smoking. The inner fender is held on by no less than four different fasteners: two Xmas trees, a handful of push pin body clips, another handful of screws which take a 7mm socket and ONE bolt that takes a 10mm socket. Seriously, there's just no need for that. That could easily be reduced to two different fasteners, if not one.
