bad_idea
I am building a weld cart 20" deep x 48" wide x 42" high. i have 4 pieces of 10" wide channel 4' long, the web is 3/4" thick. plan on welding (2) together for a top and (2) together for a bottom shelf. 3x3x1/4" angle 36" long (or so) between the top and bottom shelf. put the welding machine and bottle on the bottom shelf and continue pimping from there. anywho, i estimate the whole shebang will weigh in around 600-800 lbs.
i want to be able to wheel it away from the wall into the center of the garage for projects, then roll it back against the wall when not in use. i also want it to be solid on a set of legs for heavy thrashing and the like. i am thinking the threaded shaft of a c-clamp threaded into each of the four corners would do it. just thinking there has to be a quicker/ easier way to do it? (ease of installation and operation) i have seen a couple different setups for this concept, but they are typically for a wooden bench that someone could pick up one end to drop the wheels down. I don't believe i will be able to pick the end of this one up.
btw... i have a 14x20 garage that i keep my 02 z28 in, so space is at a premium. i plan on putting a fold down 12" wide on the front and back to keep it close to the wall when stowed and give me a 44" x 48" table when the sides are up.
thoughts anyone?
thoughts anyone?
