Hi all,
As the title states, I'm looking to build a loft area over my garage door (really just a big shelf). I have a lot of unused space up there and really want to get as much stuff as possible off the floor and cleared out of my way.
I've searched and found some interesting ideas of how to design the area, but what I'm not exactly sure on are the specifics on the specs of the build, i.e. what lumber to use, types of mounting hardware, bracing, etc. I'd appreciate the help of people with more experience and expertice. I've built shelves and workbenches for other areas, but this will be hanging over the cars and motorcycle, not to mention people, so I'd like to be as confident as possible in it's construction.
My plans are to do something like this:
or this:
But instead of the threaded rod I'd just mount a 2x4 across the joists and then use 2x4 to secure the loft, like this:
I want to the dimensions to be about 20' x 4', and maybe even deeper (might go as deep as 5' or 6' depending on the clearances with the garage door track).
The current plan is to build two 10' x 4' foot 2x4 box sections, with braces every 16", and 3/4 OSB as the floor, mounted to the back wall and side walls.
How far apart can I reasonably space my vertical supports? What type of screws/lags/nails should I use? What about my plans so far? Are they workable? Comments or criticisms?
Thanks for any input you can provide.
or this:
boxes, you end up with tires, etc. and the weight is alot more than your loft will comfortably handle.
