Compressor rubber mounts
enginerd
Ah, cool. I guess you don't need to bolt it down to the ground.
How is that electric valve working for you?
wilbilt
NorCal
Does Enco still do the free shipping code?
I used it several times, and when items shipped from the Nevada warehouse they would arrive the next day.
Can't beat free overnight shipping. :thumbup:
car99r
Charleston, IL
Found these thanks to this board. Swapped out my "wood on rubber mat" mounting system and used these instead. $7.84/each from enco.com. Highly recommended.
My floor is a somewhat uneven in this corner so these helped get the compressor level at the same time.
http://www.use-enco.com/CGI/INSRIT?PARTPG=INLMKD&PMPXNO=5832315&PMAKA=325-6629
BMW,
Do the rubber mounts screw on to the bottom of the all-thread? I am assuming you used these to keep from mounting it to the floor.
I see those are now up to $10.64 a piece. Would these work you think?
http://www.use-enco.com/CGI/INSRIT?PMAKA=325-6646&PMPXNO=5832332&PARTPG=INLMK32
